Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Ford Explorer - Ranger Tires & Wheels
Notices
Ford Explorer - Ranger Tires & Wheels Want to know what size tire or wheel combo will work with your Ford Explorer or Ranger based vehicle? Interested in Beadlocks or Dubs? Learn all about them here.
The Definitive Wheel Stud Article...
Reply
Thread Tools
Old 05-06-2009, 08:23 PM   #21
bigblockford
Vehicle Specs
Quote:
Originally Posted by Iceking007 View Post
Yeah I've had problems with mine one day I'm driving home and yes my brakes are getting alittle long in the tooth and my wheel starts making some noise you know different than usual and I find out that not one... two... but three (3) of the five wheel studs came loose and now I can't get my wheel off to fix them... after hours of trying everything from drilling to grinding to pulling ect I got a welder to drive to my house and torch them off.. k a cheap $100 dolar bill later good to go replace both front Discs n pads grease and clean hubs and lockers and vala.. the same passenger siede disc loosened off as soon as tightened it but only one... so I drove to annother welders shop and nobody wanted to torch it so we pounded the stud with a sledge to bend it and it pulled tight then just unthreaded the nut... problem solved ... luckily the second NEW disc I bought worked out ok! Cheap Junk! lol
been there had the same trouble thank god i was not far away from home ended up having to drill out 4 studs 1 bit at a time all the way up to 1/2 inch not alot of fun,but could have been alot worse i guess, but sence that i make sure i check those aluminium rims that have a habit of loosining of quite often .
bigblockford is offline   Reply With Quote
Old 05-09-2009, 02:40 PM   #22
turbotimbo
Warkwickshire
2000 NorthFace (UK model)
Vehicle Specs
Wow thanks a lot Fredness!!!
I've just had to replace a stud today and after drilling out the stud to remove the wheel I wasn't sure how to get the new stud in there. If I hadn't have read this post I wouldn't have thought there was room to get the new stud in with all the parking brake bits in place.
cheers,
Tim
turbotimbo is offline   Reply With Quote
Old 07-03-2009, 09:13 AM   #23
offroadjosh
Kila Montana
1997 XLT 4.0 SOHC 4wd
Vehicle Specs
Thank!!! Had to replace 2 studs today made it easy!
Josh
offroadjosh is offline   Reply With Quote
Old 11-02-2009, 07:07 AM   #24
CaptainComet
Clearwater, FL
1998 Sport
Vehicle Specs
Thanks for posting this ... I just upgraded to Elite Membership ... knew I would eventually, but this post saved me enough time and grief, I was glad to offer my support right now.
Just got my 98 Sport a month ago. This weekend, I was changing over to some alloy rims and tires I got. In the distant past, some butt monkey with an air wrench screwed all the wheels it waaaaaay too tight ... at least 150 ft-pounds. I am very surprised that my brake rotors seem OK. I could barely turn the lug nuts using a big breaker bar.
My right rear axle ended up looking just like the first pic posted by Fredness... two snapped studs. I live in Florida ... no road salt. In 30 years of wrenching on cars, I have never broken one ...much less done it while removing a lug ... slowly
I had to walk away from "Sporty" for a while ...
Calmed down ... found this post. What a time-saver! I was sure that I was going to be popping the axle open and taking the axle shaft to a shop to have studs pressed in. Instead, I had two new studs in there in about an hour, and wasn't rushing to do it.
I wanted to add a couple of tips ...
Got the new studs and lug nuts from NAPA ... less than $2 each and they are definitely grade 8 hardware. The local Ford dealer did not have any in stock ... (probably ran out .... )
Not sure about the markings on the original studs ... "CH" and no bars ... does that mean "case hardened" or "China"?
Bring a lug nut with you to the store ... they list two different varieties.
I don't have a stud installer ... got good results by this ...
Got the stud in place by sneaking it in there from the bottom and using a long skinny needlenose pliers to basically line it up. Could not get it directly in there, but jacked up the other rear tire (limited slip rear) and had my wife turn that just a bit, the side I was working on followed, and the stud popped into place.
Lined up the splines, and put a 1/2" stack of Grade 8 washers on the stud. Grade 8s fit tighter to the bolt and help assure that it is going into place straighter. They also won't gall like softer ones. Then, I turned the lug nug around backwards so that the flat face was on the washers, lubed it all up with PB Blaster, and started turning it all into place, using a 3/4" open end wrench.
Once the splines are about 1/2 way home, it starts getting a bit tighter, and you need more leverage. I took the washers off and scrounged an old spindle nut that I had here. It is probably a 3/4" thread and 1/2" thick. The conical end of the lug nut fit into it well, so I turned the lug around and used a breaker bar on it. Again, make sure everything is oiled... have a small puddle in the lug nut. Turning the lug around also makes use of some other thread area on the stud, hopefully not over-using the same ones you started with. This got the stud home. You can watch your progress and right as the stud gets there, it all snugged up and really did not want to turn any more.
Take your time ... if the lug nut starts feeling warm, let it cool down. Be slow and deliberate about this, and you will get-er-done.
Again ... thanks for starting this post!
I was really thinking this was going to be much more of a job than it ended up being.
CaptainComet is offline   Reply With Quote
Old 08-19-2010, 12:59 AM   #25
Fredness
Sasquatch Country!
Fredness's Avatar
'05 Sport Trac Adrenalin
Vehicle Specs
(Original Poster)
Glad to be of help!
__________________
'05 Explorer Sport Trac Adrenalin, 4.0L SOHC, 5R55E, 4.10 open, 265/70R17's on Unique Matte 297's (TT, no lift, slight rub turning), Volant Intake, X3 tuner, CVB with Sonnax Mods, External Trans filter and B&M SuperCooler. 16 city/19 Hwy/14 E85 baseline.
My Garage
"Like" me on facebook
Fredness is offline   Reply With Quote
Old 10-14-2010, 09:20 PM   #26
tjfly
Washington
2000 EDdie Bauer Expolrer
Vehicle Specs
Fredness,
I am a bit slower than some of these guys with cars, but on my 2000 Explorer 4x4 (first American car in 30 years, Ford earned it by not taking bail out money..) the tire shop broke a rear wheel stud and didn't say anything, so I was going to replace it myself - except since it is a 4x4 it sounds like I need to remove the caliper & rotor and hub - right? These directions seem to be only for the 4x2? Appreciate any help, thanks
tjfly is offline   Reply With Quote
Old 10-15-2010, 08:31 AM   #27
CaptainComet
Clearwater, FL
1998 Sport
Vehicle Specs
Rear wheel studs should be the same 4x2 or 4x4, unless someone knows something I don't (got a 4x2)... It is a tight squeeze but definitely better than popping the axle out. You need to take the caliper off and rotor and maybe back the parking brake off.
When fitting the new stud in, I angled mine into place and had to rotate the axle a bit to get it to line up. Used a new wheel lug nut turned around backwards and a stack of large washers to pull the stud into place. Lube it up good, too.
Old 10-19-2010, 08:13 PM   #28
BonesDT
Westchester, NY
BonesDT's Avatar
Red '99 Sport SOHC 4x4
Vehicle Specs
Quote:
Originally Posted by tjfly View Post
Fredness,
At first I was thinking you should send it back to the tire shop to fix their mistake, then again, if they are that incompetent, you should do it yourself, which you should do anyone with safety components like a wheel stud.
Anyway, if you are going to install the stud w/o removing the axle shaft, then you need to PULL the stud into place. I HIGHLY recommend an impact gun and the stud-installing-bearing tool, as well as lots of lubricant and careful slow patient use with the impact wrench. Anything less would stress the new stud and compromise it's safety, which is the whole reason you are doing this. Buy 2 or 3 studs in case you stress the first 1 or 2 too much and need to start over.
The other option is to pop open and drain the differential and remove the axle shafts. Doing it this way, you can hammer the stud in through the backside of the shaft, eliminating the need for the tools and patience above, however, you have to deal with the diff fluid.
__________________
Mazda M5OD-R1HD, Ranger FX4 shifter, BorgWarner 13-54 M, Aussie Locker rear, PA 3" body lift, 2" TT, Warrior shackles, hybrid leafs, Monroe Reflex, Goodyear DuraTrac 33x12.5x15, AR Mojave Teflon 15x8, Flowmaster Dual 40 Originals -> 50 SUV, Power Slot Cryo, Hawk LTS, Smittybilt Outland grille guard, APC clear lenses, Mustang FR500 steering wheel with Cobra airbag, Kenwood DNX9140, Valentine One, Dynamat Xtreme, Autel MaxiDiag US703
1989 Shelby Dakota Convertible 5-Speed under restoration
BonesDT is offline   Reply With Quote
Old 10-19-2010, 08:36 PM   #29
RaveDigger
Groton, MA
2000 Sport 5 speed manual
Vehicle Specs
My impact wrench wasn't able to torque the stud enough to pull it all the way into position. I had to use a cheater bar and a wrench to get enough torque. I also didn't use a stud installer, so maybe that was part of it. I just put a bunch of washers on the stud, then used the lug bolt to draw the stud through.
RaveDigger is offline   Reply With Quote
Old 10-19-2010, 11:19 PM   #30
tjfly
Washington
Vehicle Specs
Wheel stud - thanks
Thanks BonesDT and Rave and everyone - I really appreciate it.
I will attempt the replacement this weekend. Wish me luck!
TJ
Old 10-20-2010, 11:39 AM   #31
RaveDigger
Groton, MA
Vehicle Specs
I was also fixing the parking brakes as well at the time, so that gave me a bit more room behind the hub to work. I'm not sure how much more difficult it would be without the extra space, but you might have to wrestle with it a bit.
Old 10-20-2010, 01:16 PM   #32
BonesDT
Westchester, NY
BonesDT's Avatar
Vehicle Specs
Quote:
I used a Harbor Freight electric 1/2" impact wrench (probably the weakest 1/2" impact in the world). It certaintly didnt zip the studs on in one try in a second, it took many short bursts, taking cool down & re oil rests in between. Its even controversial to use an impact at all. I think this is the most force you should use. Im sure your gun was at least as powerful as mine (assuming it was a 1/2"). It waa prob the lack of the bearing tool. I tried your breaker bar & washers and i broke several lugs. I got a few on, but, after i invested in the bearing & impact wrench, i redid them because im sure the lugs stretched to some degree.
Also, buy a bunch of extra lug nuts. I threw a nut out each time i installed 1 lug. The threads on both the lugs & nuts still get chewed up a bit from the install, so a new nut will also help straighten out the lug's threads.
__________________
Old 10-20-2010, 08:08 PM   #33
tjfly
Washington
Vehicle Specs
Happy Ending
Well, I didn't have to replace the broken stud!
The owner of the shop that broke it called me for a customer feedback, and I told him how they broke it, wrote it on the slip and said nothing. He verified, and called me to come in - and they replaced it for free.
Glad to see there is some pride at some shops. It was a "Firestone" dealer in Oregon...
Tom
Old 11-20-2010, 02:56 PM   #34
freakinwacko
Colorado Springs, CO
98 XLT 4x4
Vehicle Specs
New (improved?) way to pull the thread in nice
I used a huge (and I mean huge) nylon nut with the nylon facing toward the lug. The nylon protects the lug from digging into anything.
freakinwacko is offline   Reply With Quote
Old 01-02-2011, 02:24 PM   #35
nanuck
boston
2004 eb explorer
Vehicle Specs
Dk Exp 2004 Eddie B Explorer REAR wheel stud replacement
On my explorer I removed the rear wheel/ caliper and disk. then i removed the self adjuster but left the spring and pads for parking in place. Next block truck and put truck in neutral..now you can turn the hub I had to turn hub so that broken stud is in the 7 o:clock position...there is a cut out in the metal approx in that spot..the head of the stud will not clear if not in that position....removal of broken stud should be easy in that position with needle nose or simular plyers....Now the problem is the stud is too long to install. You must punch out the quarter size access plate in the back dust shield...This part is located directly behind the adjuster.... from here you can insert the stud from behind the plate.....Most cars/trucks have an oval/pill like opening to adjust brake shoes with a rubber oval plug...the explorer has a quarter size round hole that must be punched out and good luck trying to find the quarter size rubber plug.....hope this helps...i could not find this info anywhere but it is the easiest way to change broken studs....GL
nanuck is offline   Reply With Quote
Old 01-02-2011, 07:11 PM   #36
tjfly
Washington
Vehicle Specs
Thanks!
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
