#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Clicking Noise in Front end
Reply
Thread Tools
Old 03-20-2007, 07:41 AM   #1
Frdxplrr
Green BAy, WI
1997 XLT 5.0 AWD
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I own a '97 Exlorer, 5.0, AWD XLT. ok, I am getting a clicking metallic noise in my front end. I have replaced both hub assemblies over the past three years. This noise goes away when I put the truck in neutral and let it coast. It happens in reverse, also. It also is more pronounced when I turn. Could this be a CV Joint issue? Something in the transfer case? AWD not dissengaged? Ball Joints? I did check the U Joint and everything appears to be in good shape. I also greased the U Joint last night. Truck is still making noise. I have become somewhat of a 'do it yourselfer' over the years. If it is any of these issues, how difficult is it to repair/correct on your own? Thanks for all and any feedback.
Frdxplrr is offline   Reply With Quote
( Join the Elite Explorers )
Old 03-20-2007, 09:26 AM   #2
slpdave
Lenoir City, Tennessee
2000 XLT
Vehicle Specs
Quoted: 0 Post(s)
This may sound silly, I had a ticking noise on another vehicle, it was a small stick caught underneath the front end acting like a playing card stuck in the spokes of a bicycle tire. I doubt this is your problem since you have done a bunch of work up there but I wanted you to know the users of explorer forum do read and answer when we know the answer.
BTW if you want immediate professional help from the board then register. with your $20 you get to post into the 911 forum for quick professional help.
David
slpdave is offline   Reply With Quote
Old 03-20-2007, 09:41 AM   #3
Bigg_billy
Westford Mass
2000 Explorer XLS 4L AT
Vehicle Specs
Quoted: 0 Post(s)
CV joints yes...and it's free advice...
Bigg_billy is offline   Reply With Quote
Old 03-20-2007, 10:56 AM   #4
Frdxplrr
Green BAy, WI
1997 XLT 5.0 AWD
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Quote:
David
Nothing silly about that. As a matter of fact, it was the first thing I thought of, actually. Thanks!
Old 03-20-2007, 10:57 AM   #5
Frdxplrr
Green BAy, WI
1997 XLT 5.0 AWD
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Quote:
Thank you for the advice. More is welcome, guys!
Old 03-20-2007, 11:32 PM   #6
nssj2
Vehicle Specs
Quoted: 0 Post(s)
Sounds like a simmilar problem i had, turned out to be a bad bearing on drivers side. replaced them both just to be sure. $300 bucks installed at brakes plus, and they even gave me a free loaner while they did it!
If you decide on bearings dont take it to a dealer, they will take every last penny you have, because ford claims them to be nonreplaceable.
__________________
-Jim
--97 Mounty (SOLD)
--2007 Volkswagen MKV (daily driver)
--05 Honda Shadow
nssj2 is offline   Reply With Quote
Old 03-21-2007, 04:54 PM   #7
explrths
Va Beach
'96 x
Vehicle Specs
Quoted: 0 Post(s)
sounds like your cv/half shaft
__________________
Ummm......PA853 3"bl, TT and shackles. gibson exhaust, Pioneer h/u, mtx seperates front/rear, mtx 3404, 2 RF Punch 10" with kenwood 800. Other then that, missing a few body trim pieces from stubborn hills( And almost rolling it) ITS NOT SCRATCHED ITS SCARRED
explrths is offline   Reply With Quote
Old 03-22-2007, 02:16 AM   #8
Frdxplrr
Green BAy, WI
1997 XLT 5.0 AWD
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Still Getting a Clicking sound up front
I have a loud metallic clicking/pinging sound coming from the front driver side of my 97 Ford Explorer 5.0 AWD. Sounds like it's right under my feet. I took the advice from some of you on this forum and replaced the Halfshaft/CV Joint on the driver side (that was a real treat, I tell ya'!).It's still making the same sound. Again, I replaced both hubs (3 months ago driver side, and passenger side two years ago). I also checked the U-Joint and it seems fine...not loose or damaged. I also greased it. It's consistant with vehicle speed. It seems to dissappear in neurtal. IT also is more noticable when I turn corners. I'm getting nervous as I think this may be getting expensive (one more payment in April and she's all mine...go figure, eh?) and also I suspect it might now be a transfer case issue or tranny. ANy other thoughts?
Old 03-22-2007, 02:21 AM   #9
section525
sextion525
Red Bluff, Ca
section525's Avatar
1975 Ford Bronco 4x4
Vehicle Specs
Quoted: 21 Post(s)
Pull the front driveshaft and see if it still does it?
__________________
Support the Forum
'13 3.5 Explorer
'75 5.0 Bronco
'04 6.0 Super Duty
section525 is offline   Reply With Quote
Old 03-22-2007, 07:48 AM   #10
Frdxplrr
Green BAy, WI
1997 XLT 5.0 AWD
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Quote:
Ok, I'll give that a shot. Couple things....is there any special tools involved to do this? Also, am I correct in thinking that if I disconnect the drive shaft, I can start the vehicle, throttle it and the truck won't move? I'm just thinkin'...AWD..I know that doesn't kick in unless it sense the vehicle slips. Finally, how would the clicking sound increase due to turning, if it's the Drive Shaft, as It's not really connected to any steering or suspension?
Thanks.
Old 03-22-2007, 11:53 AM   #11
Frdxplrr
Green BAy, WI
1997 XLT 5.0 AWD
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
update.....re: clicking
I did notice when driving, I put the vehicle in neutral and when rolling to a stop at an intersection, the sound is still there, just alot more quiet. Further, when using an off ramp this AM, I was 'rolling' in neutral, while turning (it's curved), the metallic clicking/banging came back and is as pronounced as it I was in Drive or reverse. Again, I have elimnated the CV/half Shaft arm and Hubs. I replaced both hubs (passenger side three months ago, driver side, about 2 years ago) and put a new CV/half shaft last night.
Old 03-22-2007, 12:19 PM   #12
Dan Whitaker
One fast putty tat
Raytown MO (Kansas City suburb)
Dan Whitaker's Avatar
No Mounty no more.
Vehicle Specs
Quoted: 21 Post(s)
When in drive & you let off the gas does it stop breifly then continue? Then does it get worse after coasting & you get back on the gas?
If so I will garantee it is the CV joint on the drive shaft (transfer case end)I mentioned in your other thread.
There is a rubber boot that will tear letting the grease to spin out as the drive shaft turns. You need to crawl under your Ex and feel the boot for tears.
If torn stick your finger in to where you can feel the CV. I'll put money on it that you feel no grease at all.
__________________
P r i c k me, do I not bleed Ford Blue.
Dan Whitaker is offline   Reply With Quote
Old 03-22-2007, 12:41 PM   #13
Frdxplrr
Green BAy, WI
1997 XLT 5.0 AWD
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Hey Dan, thanks for the reply. I appreciate it. when I drive it, in forward, excellerating or at a constant speed (35 mph today on the way to work) it makes the noise. When I let off while in drive, it doesn't stop, but is less noticable. It does make a fluttering sound..obviously because of the speed. When I put it into Neutral, the sound dies way down...when I roll to a stop sign, I can hear it. I actually replaced the entire CV Joint/Half shaft assembly on the driver side where the noise is coming from, last night. It's still making noise. SO....
Old 03-22-2007, 01:33 PM   #14
Frdxplrr
Green BAy, WI
1997 XLT 5.0 AWD
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Quote:
replaced Driver side CV/half shaft last night. It is still making the noise.
Old 03-22-2007, 01:38 PM   #15
section525
sextion525
Red Bluff, Ca
section525's Avatar
Vehicle Specs
Quoted: 21 Post(s)
You can pull the front shaft and it will still drive fine. You may get a little better mileage. Just make sure you always use your e-brake because the truck will roll (even in Park) while on an incline with no shaft.
__________________
Support the Forum
'13 3.5 Explorer
'75 5.0 Bronco
'04 6.0 Super Duty
Old 03-22-2007, 05:13 PM   #16
Frdxplrr
Green BAy, WI
1997 XLT 5.0 AWD
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
roger that! I'll let you know what happened.
Old 03-22-2007, 05:21 PM   #17
JDraper
Somewhat Functional
McVeytown, PA
JDraper's Avatar
'11 XLT
Vehicle Specs
Quoted: 30 Post(s)
Combining your threads into one.... Please don't post two threads on the same thing..
__________________
Moderator..Home Improvement/Explorer 911/2011 Explorer Forum
You took my breath away....and now I want it back....
'66 Mustang Coupe, '04 Mustang Mach 1, '08 Focus, '11 Explorer XLT
"Ex"plorer's: '92 Sport, '94 Sport, '01 XLS
Our Crappy Website
JDraper is offline   Reply With Quote
Old 03-23-2007, 07:42 AM   #18
Frdxplrr
Green BAy, WI
1997 XLT 5.0 AWD
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
ok..Update...LAst night, with the vehicle up on a jack, I was able to grasp the front driver side tire and turn the front tires. No sound out of the ordinary. I checked the level of fluid in the transfer case, added some fresh Mercon to it. No change. In ny inexperienced opinion, and feel free to chime in...it's either an issue with the drive shaft (wasn't able to pull it last night..limited time) or my tranny. I am contemplating bringing it in to a shop, today. Currently, the vehicle has acquired a vibration, and now I get a sound (has become very loud and I liken it to a helicopter) when I go straight, it dies down or dissapears when I turn or come out of a turn, but then returns.
Old 03-25-2007, 08:51 PM   #19
Frdxplrr
Green BAy, WI
1997 XLT 5.0 AWD
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Ok, progress, but still not finished.......
..after taking a break from it on Saturday, I got after it today. While following the front Drive shaft down to the 'second transfer case,' I begin to inspect where the drive shaft comes into contact with the 'second driveshaft.' I notice, there are remains of a boot, and I can see silver inside....bearings. AHHH!!!! I was able to remove the drive shaft, took the truck for a ride...no noise! SO, I checked at Advanced auto and Autozone. The part needs to be ordered. I drove to Autozone to order it,.....the part is not available from the vendor. Went to Advanced Auto...same thing. Went to Checkers...they were closed. I am gonna call them, but am getting concerned that the part is no longer available. I gonna contact some junk yards, parts vendors,Checkers, and.....sigh...the local Ford Dealership and see what happens.
Old 03-25-2007, 09:57 PM   #20
Dan Whitaker
One fast putty tat
No Mounty no more.
Vehicle Specs
Quoted: 21 Post(s)
Post it in the wanted forums. There is always someone with a used one for sale.
I know that NAPA has them. They run about $225 for a remanufatcured one.
__________________
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
