#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
Find your key pad number - 2002 - 2004 - its easy!
Reply
Thread Tools
Old 03-29-2007, 11:54 AM   #1
Curtis
Orlando, FL
04 XLT 4x4
Vehicle Specs
Quoted: 6 Post(s)
(Original Poster)
After researching here I found out that the code to the door is on the key pad module located in the piller behind the rear passenger door.
Well today I got some time so thought Id try it.
Step 1 - fold the rear passesnger seat
Step 2 - pull the rubber seal out (rear upper section only)
Step 3 - The upper panel where the seat belt adjuster is can be easily pried out, you'll see the clips after you remove the rubber weather stripping
Step 4 - There is a clip on the lower part of this panel that can be easily popped out
Step 5 - Now you can pry easily on the lower panel, you'll see the module when you look down inside after prying open the upper panel.
Step 6 - I used a small mirror, and found a 5 digit number on the black module box. The white sticker has black text and is is facing the drivers side so without a mirror you'd really need to get the lower panel loosened to pry it out more.
It was easy - 5 mins tops.
Step 7 snap everything back together - no tools required - except the mirror.
__________________
Curtis
2008 Expedition EL Limited
2004 Explorer XLT 4x4 4.6
1970 Buick GS 455 Silver Mist
Curtis is offline   Reply With Quote
( Join the Elite Explorers )
Old 04-09-2007, 10:09 PM   #2
Philly37s
2002 Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
What about on the 2002 Explorer Sport (2-door version)?
Philly37s is offline   Reply With Quote
Old 04-10-2007, 02:32 AM   #3
Critter92X
Lake of the Ozarks Mo.
Critter92X's Avatar
92 xlt 4x4, 02' EB 4x4
Vehicle Specs
Quoted: 0 Post(s)
Quote:
I think it may be behind the dash on the right hand side.
__________________
92 Explorer XL 4x4
02 Explorer EB 4x4
92 Harley Davidson XL 1200
Critter92X is offline   Reply With Quote
Old 04-16-2007, 10:35 PM   #4
xartic
Brazil, Indiana
02 awd v8 mounty
Vehicle Specs
Quoted: 0 Post(s)
i found this code for my dads 2004 explorer, and 2 days ago i purchased a fully loaded v8 awd mountaineer, and the location of the code isnt in the same spot
xartic is offline   Reply With Quote
Old 04-17-2007, 10:27 PM   #5
rrgone
Tucson, AZ
'02 XLT
Vehicle Specs
Quoted: 22 Post(s)
Quote:
Do you mean that the code is not on the security module or the module is not behind the trim panel on the RH C-pillar?
rrgone is online now   Reply With Quote
Old 04-18-2007, 01:36 PM   #6
Critter92X
Critter92X's Avatar
Vehicle Specs
Quoted: 0 Post(s)
The security module on a 02 mounty is in the same spot but maybe they changed it by 04.
__________________
92 Explorer XL 4x4
02 Explorer EB 4x4
Old 04-18-2007, 07:46 PM   #7
rrgone
Tucson, AZ
'02 XLT
Vehicle Specs
Quoted: 22 Post(s)
Just reread xartic's post and he never IDs what year Mounty he's talking about. I'll bet it's a newer one.
Old 04-23-2007, 01:42 PM   #8
xartic
Brazil, Indiana
02 awd v8 mounty
Vehicle Specs
Quoted: 0 Post(s)
yeah my mounty is an 02, and i did find the code, it was on that computer thing, but the print on it was really small, compared to my fathers 04 which was largely printed
Old 06-06-2007, 04:58 PM   #9
sledneck9
Duluth, MN
2002 Mountaineer
Vehicle Specs
Quoted: 0 Post(s)
i just did it on my 02 mounty. it was there. finally i was able to set it to what i wanted. i never new the factory code. thanks
__________________
2002 Mercury Mountaineer V8
20" Chrome w 275/55/20 Zeon LTZ's
Flowmaster 50 Exhaust
K&N FIPK Intake
MTX Subs Eclipse Amp
Chrome Tube Steps
http://www.cardomain.com/ride/2583273
sledneck9 is offline   Reply With Quote
Old 06-02-2009, 08:42 PM   #10
computers01
douglas
2002 Ford Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
Dk Exp Factory Code
where to find factory set code for 2002 ford explorer 2 door
please email the answer asap computers01@gmx.com or ferrelljholar@aol.com
computers01 is offline   Reply With Quote
Old 06-02-2009, 09:45 PM   #11
XtremeRanger
Columbus, Ga
'95 Ranger XLT
Vehicle Specs
Quoted: 5 Post(s)
Sport (2dr) owners use the '95 - '01 forum.
^^^^^Or you can just use the search button and look here.....^^^^^
__________________
Mine: 2005 XLT A4X4 V8 -171k - Railgrabs/Yakima Megawarrior, Full HID's - Steelcraft Grille Guard
Hers: 2002 XLT 2WD 4.0 Black everything but a sunroof., Manik Grill Guard, Mounty Cluster, Tint, HID's 137k
My Registry:http://www.explorerforum.com/forums/...d.php?t=388806
XtremeRanger is offline   Reply With Quote
Old 06-02-2009, 11:31 PM   #12
Curtis
Orlando, FL
04 XLT 4x4
Vehicle Specs
Quoted: 6 Post(s)
(Original Poster)
Gesh...
__________________
Curtis
Old 06-02-2009, 11:34 PM   #13
Fox Fader
Columbus, GA
searching
Vehicle Specs
Quoted: 0 Post(s)
I did the samething on my '97.
Rear driver's side.
__________________
_______________
2005 XLS 115k not even side steps (sold)
2001 Sport-Trac 131k Wife's
Fox Fader is offline   Reply With Quote
Old 06-30-2009, 10:33 AM   #14
L8RBRA
STL MO
2002 XLT
Vehicle Specs
Quoted: 0 Post(s)
Good info!
L8RBRA is offline   Reply With Quote
Old 08-04-2009, 02:43 AM   #15
raul94
PA
raul94's Avatar
1998
Vehicle Specs
Quoted: 0 Post(s)
found mine on the rear passenger door pillar 2002 mountaineer thank you..
raul94 is offline   Reply With Quote
Old 01-30-2010, 07:12 PM   #16
sjj62
Algonquin, IL
02 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
These instructions were exactly right for finding the master keypad code on my 2002 Explorer EB that I recently purchased. I found the 5 digit code and it works. Thanks so much. I am glad I found your instructions before looking in all the other spots that would've been a big waste of time.
sjj62 is offline   Reply With Quote
Old 04-24-2010, 02:46 PM   #17
mercracing
Kaukauna, Wisconisn
2002 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
Thank you so much!!! You saved me 25 bucks and a trip to the local Ford shop.
2002 Eddie bauer... Passenger side, rear door
mercracing is offline   Reply With Quote
Old 04-28-2010, 11:12 PM   #18
sdparker40
Houston, Texas
2002
Vehicle Specs
Quoted: 0 Post(s)
where to find factory set code for 2002 ford explorer 4 door.
please email the answer asap parkay46@gmail. Thank you
sdparker40 is offline   Reply With Quote
Old 04-28-2010, 11:13 PM   #19
sdparker40
Houston, Texas
2002
Vehicle Specs
Quoted: 0 Post(s)
please email the answer asap to parkay46@gmail.com Thank You
Old 04-28-2010, 11:28 PM   #20
fodowvovo
Buffalo NY
2002 XLT 4.6
Vehicle Specs
Quoted: 0 Post(s)
i made a thread with pics for this already
fodowvovo is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
