Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Offroad Tech Forums > Offroad Explorer - Ranger Projects
Notices
Offroad Explorer - Ranger Projects Big projects... Lifts, Swaps, etc... IMPORTANT As the subject use your name, or the name of your truck, and the name of the project. Such as Superlift 5.5" installation, Dana 44 conversion, etc.
colindo94 fullwidth swap
Reply
Thread Tools
Old 04-24-2007, 06:12 AM   #81
sn0border88
Master Apprentice
Souderton, PA
sn0border88's Avatar
1992 XLT
Vehicle Specs
the d44 does, the 9" dosent I believe.
__________________
My Photos---Emily Rose---SAS Thread---My Mug
1992 4dr XLT. SAS'ed HPD44/9" 5.13's Locked F/R 36" SX
1999 4.0 5spd sport on 31" BFG Muds
sn0border88 is offline   Reply With Quote
Old 04-24-2007, 06:37 AM   #82
zainyD
Lakeland, FL
zainyD's Avatar
'96 Ranger 4x4 XLT
Vehicle Specs
Quote:
That is correct. The D44 uses a different carrier for 3.92 and numerically higher gears(4.10, 4.56, 4.88, etc). The 9" uses the same for all gears.
__________________
'96 Ranger 4x4 XLT with some stuff....and more to come when I actually have some money
zainyD is offline   Reply With Quote
Old 04-24-2007, 07:06 AM   #83
jrgaylor
Power through it!
onalaska, Washington
jrgaylor's Avatar
1988 BroncoII
Vehicle Specs
Quote:
Originally Posted by jrgaylor View Post
I have been talking with Jim at Cage offroad about their radius arms. The Duff and Cage arms look the same but the cage arms have several improvements in construction and material and Jim is the original designer of the arms.
They are making new frame brackets for their arms to fit rigs that have a channel frames like our explorers and full size F150/Broncos. So now we won't have to modify the frame brackets that where meant to be used on a early Bronco that was a boxed frame rig
These new brackets should be available this Monday, as soon as they are available I am going to order a set for my explorer
The arms and frame brackets will come together as a kit, the new frame brackets are being made of 5/16" instead of 1/4" and will fit the frame of Explorer, the new brackets should be ready by end of the week. I will keep you posted
__________________
88 BroncoII 4.0/C5/1350/1354/D44/9"
72 Bronco 302
I have a matched set of early bronco axles for sale D44 and 9" for sale PM me for price and details.
jrgaylor is offline   Reply With Quote
Old 04-24-2007, 09:23 AM   #84
'97 V8
Lima, Ohio
'97 V8's Avatar
'97 mounty 5.0 4x4 baby!!
Vehicle Specs
Sweet.
__________________
1997 Mercury Mountaineer 4x4 V8
3" bl, manual t-case.
Dana 60/14 bolt combo with 36x13.5x17 iroks on H2 rims. 5.13's.
Future plan: 3.9 or 5.9 Turbo diesel cummins
'97 V8 is offline   Reply With Quote
Old 04-24-2007, 08:21 PM   #85
lifeguard379
sacremento,ca
lifeguard379's Avatar
93 eddie bauer 2 door
Vehicle Specs
colindo94 thanks for asking about the Carrier. i didn't think there was a dif, but now i know .
__________________
93 2 door eddy Bauer HP44 and Big bearing 9 and 4.88 My elite registry
http://www.explorerforum.com/forums/...d.php?t=153392
sas thread
http://www.explorerforum.com/forums/...d.php?t=165147
sas registry
http://www.explorerforum.com/forums/...d.php?t=244780
lifeguard379 is offline   Reply With Quote
Old 04-24-2007, 08:59 PM   #86
Mud Bug 94
Bloomingdale, N J
Mud Bug 94's Avatar
94 XLT-367k miles
Vehicle Specs
just soits been said...dana 60 has two carriers...and thick and thin gear sets...
__________________
94 xlt 4 door, 32's 4 inch shackles and custom tube bumpers with tire carrier
Mud Bug 94 is offline   Reply With Quote
Old 04-24-2007, 09:57 PM   #87
SuperEx91
Toledo, Ohio
SuperEx91's Avatar
91 XLT EB
Vehicle Specs
2 things...
first, what is the differecne between the two carriers? i ran into the same comment. i have 4.88's for my d44 and was planning on using the factory carrier but was told not too.
second, off subject. i want to keep updated about this attica run 97 V8 and mynameisaric are talking about. i live in perrysburg, ohio(1 hr north of lima) and hope to have my sas done for the spring jamboree next month.
__________________
'91 EB, Axle Build-up/Parts gathering in progress
'05 F-150 SC 4X4- leveled, intake, exhaust, edge programmer, 35's
95 Grand Prix- currently getting head job
SuperEx91 is offline   Reply With Quote
Old 04-24-2007, 10:38 PM   #88
mynameisaric
with an A
Bolingbrook, IL
mynameisaric's Avatar
98 XLT
Vehicle Specs
well i know i wont be done next month, but i will keep you informed on the run when it happens. the more the merrier.
__________________
-Driveway Ornament (aka 98 explorer)
-05 F150 3V 5.4L Supercab
mynameisaric is offline   Reply With Quote
Old 04-24-2007, 11:39 PM   #89
SuperEx91
Toledo, Ohio
SuperEx91's Avatar
91 XLT EB
Vehicle Specs
thanks. you ought to try going to the jambo. i went last year. it was crazy. i am hoping to get a deal on some tires. national tire and wheel takes a semi full of tires and sells them for decent price. cheaper than the normal magazine prices anyway. if i already have my tires by then, i plan on looking for a winch.
__________________
Old 04-25-2007, 12:52 AM   #90
'97 V8
Lima, Ohio
'97 V8's Avatar
Vehicle Specs
I'll be at the jambo as well. I'm hoping to get a sick deal on tires and what not.
__________________
Old 04-25-2007, 01:04 AM   #91
colindo94
Cameron Park, CA
94' XLT
Vehicle Specs
(Original Poster)
I did more researce and found that we do need new carriers. For the 44 there are two different carriers. Numerically lower then 3.93 and Numerically higher then 3.93. SO the stock one is the lower then 3.93 gears and the one we need for those of use running 4.88, 5.13 we need the numerically higher then 3.93 carrier. I have found the same info for the 8.8 so I will be buying new carriers for both axles.
__________________
Full width Dana 44/8.8, 36x12.5 TSL radials
Ostman Bros. Fab Shop
colindo94 is offline   Reply With Quote
Old 04-25-2007, 02:03 AM   #92
colindo94
Cameron Park, CA
94' XLT
Vehicle Specs
(Original Poster)
now that I started looking for 8.8 cases I can only find one sized case. So does anyone know if I need to get a different sized case for the 5.13 gears that I am running for my full width 8.8 rear end? I need input asap so I can order the parts.
__________________
Old 04-25-2007, 06:25 AM   #93
zainyD
Lakeland, FL
zainyD's Avatar
'96 Ranger 4x4 XLT
Vehicle Specs
You don't need a different case for the 8.8. My 8.8 had stock 3.55 gears and I switched to 5.13's using the same carrier.
__________________
Old 04-25-2007, 06:53 AM   #94
mynameisaric
with an A
Bolingbrook, IL
98 XLT
Vehicle Specs
they make gears that work with the lower carriers if i'm not mistaken. i know for the d60 they offer the 5.13 and 5.38 for "4.10 and numerically higher" and "4.10 and numerically lower" i am guessing it works the same for the dana44 since they are pretty similar and have equal aftermarket support.
__________________
Old 04-25-2007, 07:11 AM   #95
james t
moderation
Texarkana AR/TX
james t's Avatar
94 SAS sport
Vehicle Specs
As far as i know, you can get "thick" gears that will allow you to run say 4:56's on a 3-series carrier for a low pinion D44, but not for a high pinion.
__________________
my rebuild
"It started as a hobby, slowly turned into a lifestyle, then spiralled downward into mental illness. My lawnmower has tree rash on it."
james t is offline   Reply With Quote
Old 04-25-2007, 08:55 AM   #96
95exploderboy
Locked and Loaded
Annapolis, MD and Lebanon, PA
95exploderboy's Avatar
1995 Sport
Vehicle Specs
I have never seen or heard of a carrier break for the 8.8. The only thing you will need is a notched cross shaft for the spiders or you might need to do some grinding on the gears to get the shaft to fit.
If your gear guy keeps insisting on needing a new carrier for the 8.8, you may want to find someone who knows the 8.8 better.
__________________
1995 Explorer Sport: Dana 44/9" Locked, Air Shocks, Stubler and more to come...
2004 F250 Powerstroke
95exploderboy is offline   Reply With Quote
Old 04-25-2007, 09:49 AM   #97
redranger4.0
Salem CT
2000 Ranger XLT
Vehicle Specs
All the ford axles do not use a carrier break. 8.8 9" sterling
__________________
Join the Resistance
redranger4.0 is offline   Reply With Quote
Old 04-25-2007, 11:42 PM   #98
Mud Bug 94
Bloomingdale, N J
Mud Bug 94's Avatar
94 XLT-367k miles
Vehicle Specs
sweet!?!?
__________________
Old 04-27-2007, 05:40 PM   #99
colindo94
Cameron Park, CA
94' XLT
Vehicle Specs
(Original Poster)
SAS is underway
Alright my plan changed a little so I will write up everything that I plan to do. I change my mind a lot so none of this is set in stone, but you get the idea.
Dana 44 from a 67 F-150
-5.13 yukon gears/master install kit, bigger carrier
-lockright
-warn primium hubs
-timkin wheel bearings
-stock axle shafts with new spicer u joints for now
-new hub and rotor assembly and spindle.
-Stock f-150 calipers
-ford explorer skyjaker extended brake lines
-stock 76-79 f-150 tie rod
-stock 91-94 ford explorer drag link
-superlift adjustable track bar
-stock f-150 track bar bracket
-wildhorse 5.5" coils
-energy suspension 7* axel wedge bushings
-new balljoints from broncograveyard
-stock f-150/bronco lower coil seats and retainers
-stock f-150/bronco coil towers
-f-250 shock towers
-bilstien 5100 14" travel shocks?
Full width 8.8 from a 88 fullsize bronco
-5.13 yukon gears/master install kit, stock carrier
-lockright
-notched crosspin???Not sure if I need the notched crosspin for the lockright
-stock axelshafts for now
-new drums,shoes
-ford explorer skyjacker ext. brakeline
-new spring perch, u bolts, shock mount kit for a 8.8 install on a XJ?
-add a leaf
-custom shackles
-timkin axle bearings
Wheels and tires
-36x12.5 TSL Radials
-15x10 steel rock crawlers
If any sees a problem with my plan please speek up.
Heres some pics of progress
I got most everything painted and apart. I'm waiting on the dana 44 carrier to get the gears and lockers installed. I plan to start taking the front end off the explorer this weekend.
__________________
Old 04-27-2007, 05:56 PM   #100
JTX
Rollin...
New Mexico
JTX's Avatar
94 xlt
Vehicle Specs
Any way you could possibly measure the distance from the upper ball joint to the other upper ball joint? Trying to get an estimate on how much DOM tubing i need to buy for my steering.
Thanks
__________________
-=Elite Registry=-
JTX is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
