Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
What kind of grease/lubricant to use in ball joints/tie rods???
Reply
Thread Tools
Old 04-11-2007, 11:30 AM   #1
bennettcl
Olathe, KS
1998 Explorer Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I am replacing all my ball joints and outer tie rods on my 98 explorer AWD V8. Right now the only grease I have is a Super Tech Multi Purpose grease I got at Walmart for a $1. I am not sure if that is the correct grease to be using. So I need to know:
What kind of grease should I get and where should I get it? It says I should get chassis grease. Is there a grease that I can get that can be used on all my ball joints and tie rods as well as other applications? Please be sure to let me know where you get the grease.
Also I am putting all brand new bushings in my upper and lower control arms. Do the new bushings need any kind of lubricant on them such as silicone grease?
Also I have to remove my torsion bars to take off the lower control arm. Do I need to put some kind of dry adhesive on the torsion bar adjuster bolt when I put it back in?
And do any other bolts such as the frame bolts that hold the upper and lower control arms on. Do they need a dry adhesive or do I just tight them tight.?
bennettcl is offline   Reply With Quote
( Join the Elite Explorers )
Old 04-11-2007, 01:44 PM   #2
badge49
Humboldt, CA
badge49's Avatar
'97 XLT 4X4
Vehicle Specs
Quoted: 0 Post(s)
Heres a bump, I want to know too
badge49 is offline   Reply With Quote
Old 02-27-2012, 09:31 AM   #3
jbwilli
marietta ga
1997 XLT & SPORT
Vehicle Specs
Quoted: 0 Post(s)
Ford ball joint grease
NLGI N0.2 lithium based grease containing polyethylene and molybdenum disulfide is recommended by Ford for front wheel bearings, automatic locking front hubs, front spindle and thrust bearings (4Wd) AND ALL CHASSIS lubrication. Ford OEM balljoints are sealed with no grease fitting and therefor Ford recommends no grease specifically for their balljoints.
The NLGI number system categorizes greases according to their hardness, from an NLGI No. 000 through No. 6, with an NLGI No. 2 being the most common.
NLGI No.2 appears to be the what Ford would recommend IF their balljoints had grease fittings.
jbwilli is offline   Reply With Quote
Old 02-27-2012, 09:42 AM   #4
drdoom
VA
2005 Eddie Bauer 4.6L 4X4
Vehicle Specs
Quoted: 350 Post(s)
I use the Valvoline Ford-Lincoln-Mercury grease, bought it at Advance.
drdoom is online now   Reply With Quote
Old 02-27-2012, 10:38 AM   #5
steadyhand
Missouri
99 Mercury Mountaineer
Vehicle Specs
Quoted: 7 Post(s)
Quote:
+1
I have used this stuff on all of my vehicles, most recently on my 99 Mountaineer and my 91 Mustang GT. I haven't had any problems.
__________________
99 Mountaineer 5.0 2WD 4 door
steadyhand is offline   Reply With Quote
Old 02-28-2012, 08:50 AM   #6
jbwilli
marietta ga
1997 XLT & SPORT
Vehicle Specs
Quoted: 0 Post(s)
Yes, the Valvoline Ford-Lincoln-Mercury grease is NLGI N0.2.
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
