#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
Blower motor doesn't work
Reply
Thread Tools
Old 04-18-2007, 08:47 PM   #1
repodad
Chester, Pa
93 xlt sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Hello all, first the blower motor only worked on high now it does not work at all. I have replaced the blower motor and still no go. any help would be grateful. Also my 4low does not work 4high does but the 4low light does not light up, any ideas? The vehicle is a 93 explorer sport. Again any help is grateful Thanks Victor
repodad is offline   Reply With Quote
( Join the Elite Explorers )
Old 04-18-2007, 09:28 PM   #2
Minivek
Quebec, Canada
'03 Limited Ex silver
Vehicle Specs
Quoted: 0 Post(s)
Most likely culprit is the blower motor resistor. It's the little platic housing on the main blower fan housing, they tend to crap out after that many years, symptoms are loss off fan speeds, mine only worked on high and low. You would also want to check the blower motor relay, just switch it with an other relay, if it works, wou've found the problem, if not, than its your resistor.
As for the 4x4 lo, I'd suggest searching here as it has been adressed, meanwhile you can check to see if the brown wire going into the Tcase is still attached, it allows the transfer case to go into 4lo...
__________________
Lifted and sold 94 sport.
New baby 2003 4.6 Silver Limited Explorer!!
Minivek is offline   Reply With Quote
Old 04-18-2007, 09:42 PM   #3
DeRocha
NEX Vice President
Brockton, MA
DeRocha's Avatar
'93 XLT 4x4
Vehicle Specs
Quoted: 2 Post(s)
Quote:
Blower motor: start with the obvious and pull Fuse #30 (see Fuse locations for diagram). The blower motor resistor acts like a 3way light bulb to change the power for the low med and high speeds. When one of the filaments burns out it prevents that speed from working.. MAX speed on the other hand will always work since it by-passes the resistor pack and sends full power to the blower..
4low: You indicate 4high works, but 4low does not.. Has 4low ever worked, or is this vehicle new to you? Do you have the vehicle's operation manual and know how to engage 4low?
__________________
John D-"Search first, Ask questions later" & "You can have my Explorer when you pry the keys from my cold dead hands." <<<Forum Rules >>>*My Truck*
4x4 Trouble Shooting Guide
See how cars work Axle and tire calculators U-joint replacement info/pics
Repair info NEX-New England Explorers NEX: Club Events
DeRocha is offline   Reply With Quote
Old 04-18-2007, 11:06 PM   #4
pugsy
Toronto, ON
'92 XLT 4x4 (4 door)
Vehicle Specs
Quoted: 0 Post(s)
To see if the blower motor works, jump it with a direct 12V source. That's what I did when I replaced mine with a junkyard one to make sure it worked before I bought it.
Then if it works with a direct power source, then check/swap the relay and resistor as mentioned above. I also replaced these with scrap yard parts and have had no problems since.
4 lo....as mentioned above....probally the brown wire not attached, or the sensor attached to the brown wire gone bad. Try cutting it off and replace/solder a scrap yard one on to see if that fixes it. If it doesn't, maybe the control module in the rear drivers side wheel well is on the fritz.
pugsy is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
