kymadan
- September 26, 2006
- Eustis, Fla
- '87 4x4 Ranger
Does any one know the specs? I mainly need the length.
My 4x4 1986 Ranger has an A4LD, if I put the 5R55E in.... will it match up to the stock mounting holes and transfer case (BW1350)?
I know the A4LD was replaced by the 4R44E (Stronger version of A4LD), then it was upgraded to the 4R55E(Stronger version of 4R44E), and the 5R55E is for the most part identical to the 4R55E.
I will be using a 4.0/5R55E out of an 01 Explorer.I know the insides of the 5R55E are thicker and stronger, and it is electronically controlled, and has sensors that will need to be hooked up, that is why I am going to use the explorer harness.
