Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
Radiator Cap Stuck
Reply
Thread Tools
Old 04-20-2007, 09:04 AM   #1
MikeP
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Radiator Cap Stuck
My radiator cap appears to have gotten cross-threaded and is stuck (not able to remove it and difficult to lock it in place). Any hints on how to remove the cap? One approach is to break it and replace it with a new one.
1991 Explorer with about 220,000 miles. Got it new in July 1990.
Mike
MikeP is offline   Reply With Quote
( Join the Elite Explorers )
Old 04-20-2007, 10:55 AM   #2
Tony H
New York, Wading River (that's on Long Island)
'91 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
Are you pushing down hard as you turn it?
__________________
1975 CJ5 with fiberglass body and 350/345Hp chevy power:bought it in '79
1985 chevy stepside pickup, 300K on the clock: Original Owner
1989 Volvo 240 300K on the clock: Original Owner
the 1991 X is my newbie with 331K on the clock: bought OCT.'03 with 183K
http://home.lyse.net/brox/TonyPage4.html
Tony H is offline   Reply With Quote
Old 04-20-2007, 11:57 AM   #3
mikeinri
04 Explorer, 94 XLT (RIP)
Vehicle Specs
Quoted: 8 Post(s)
If you try to break it (or cut it somehow), just be very careful, as it is screwed into the plastic housing of the radiator. If you damage that, you have to replace the whole radiator.
If you could somehow get to the "teeth" of the cap, you may be able to bend them enough to free it up. Again, be very careful if you're prying against the radiator neck (plastic).
Mike
mikeinri is offline   Reply With Quote
Old 04-20-2007, 12:00 PM   #4
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
Quoted: 3 Post(s)
there are no threads on your rad cap, it is a simple push and turn like asprin, try again it should not be stuck
__________________
96 Explorer daily driver build-1996 XLT 5.0L AWD to 4x4 conversion complete on 33's
88 BII 5.0L conversion - BII 5.0l drivetrain thread
My Bronco II - 1988 Bronco II 4x4 V8 on 35's - registry and updates
Wifes 07 FJ build - 2007 FJ cruiser locked and lifted
410Fortune is offline   Reply With Quote
Old 04-20-2007, 12:06 PM   #5
marragtop
balt, md
91, 92, 95, and 2000 xlts
Vehicle Specs
Quoted: 4 Post(s)
Agreed, it's not threaded. Push down with the palm of your hand and turn at the same time. You need to lean some body weight into it with straight down force.
__________________
'88 F150 4x4
'91 Explorer XLT 4x4
'92 Explorer XLT 4x4
'95 Explorer XLT 4x4
If it don't = 16 (4x4), it ain't worth driving...
marragtop is offline   Reply With Quote
Old 04-20-2007, 02:57 PM   #6
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 414 Post(s)
Don't open it when the engine is hot.
BrooklynBay is offline   Reply With Quote
Old 04-20-2007, 03:02 PM   #7
JIGAWHAAT
Vehicle Specs
Quoted: 0 Post(s)
Give mental a call. He will come over with his hammer
__________________
MY MARTIN TRUEX FORUM
JIGAWHAAT is offline   Reply With Quote
Old 04-21-2007, 12:00 PM   #8
MikeP
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Unstuck Radiator Cap
Thanks for the advice.
The cap is not actually threaded but it has those two locking tabs that sort of act like partial threads.
I think I got the cap "tilted" when I tried to replace it after checking the radiator fluid level and those two locking tabs were not located properly (the cap was "tilted"). It would only rotate about 60 degrees and pressing down it just would not release it.
I started up my engine and let it warm up about 5 minutes (it was freezing temp on Friday morning). Then I shut the engine off. The radiator had warmed some. I was able to rotate the radiator cap and remove it and install it correctly. I am guessing that the warming of the cap expanded the cap sufficiently to enable it to be removed. Yes, the message here is to be careful when replacing the radiator cap because it might not seal properly. There is some writing on the cap, something about lining up the arrows with the drain tube, etc. which implies that it must be possible to not replace that radiator cap propertly.
I have removed that radiator cap lots of times. The "cheap" plastic parts on the Ford Explorer radiator will develop leaks and so I check the fluid level frequently. I have never gotten around to replacing this defective radiator with a "real" metal radiator.
By the way, sometimes I drive out in the "boondocks" a considerable distance from anything and I like to be able to repair something that might go haywire. I have had stuff go hayire with my Ford, but luckily only once while I was out in the "boondocks" and that was a battery wire came loose after driving on the rough roads and I was able to find and fix it (not the battery cables but one of those other wires). In my former GMC 3/4 ton 4x4 I used to carry a number of spare parts so I could fix stuff like a broken radiator hose, fan belt, 2 spare wheels, etc. and it helped alot. My Ford Explorer is not nearly as tough as that GMC but it has survived about 17 years now which is not bad.
Mike
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
