| Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. |
Thread Tools |
#1 |
Wannabe Elite Explorer
oregon, usa
1995 explorer xlt
95 explorer heater problems, plz help
I have a '95 explorer and about 2 or 3 months ago, the heater started messing up. Air comes out of the defroster and the rear air works fine, but if i select floor , mix , or vents it still blows out the defroster and wont change. Any ideas on what might resolve this problem?
#2 |
Human-Animal Hybrid
Carmichael, CA
'97 Sport 4x4
My recollection is that the air diverter door (controls whether the air is sent to the defrost vents or panel or floor) is vacuum controlled. You may have a vacuum leak somewhere that doesn't allow the door to work.
#3 |
Aerostar Forum Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
Welcome to this forum! Plastic vacuum lines are known for cracking at the base where they attach. Follow the vacuum diagram which is under the hood.
#4 |
San Jose, CA
95 XLT, 96 XLT, 97 Mounty
in case you're still confused, open the glove box. pull the sides together to allow the box to drop free exposing the dash behind it. Then check on the left. You will see some of the vacuum hoses that control this setup. Good luck!
__________________ 1995 4WD XLT 4.0 OHV 263k (sold) 1996 AWD XLT 5.0 160k 1997 AWD Mounty 5.0 123k 2002 Kawasaki Vulcan 1990 Four Winns 200 Horizon |
#5 |
oregon, usa
1995 explorer xlt
any ideas on where to start looking first, where does that vaccum start? manifold etc. could the switch be bad?
#6 |
Human-Animal Hybrid
Carmichael, CA
'97 Sport 4x4
I would start at the switch and see if you have vacuum present. If so, it may be the switch. If not, then you will need to start looking at the hoses to see if they are cracked or broken. Like Brooklyn said, its common for the ends of the hoses to crack when they get old and brittle.
From the 97 manual. Yours should be very similar or the same. |
#7 |
Old and in the way
Humboldt, Kansas
2000 Mounty
Check the lines on the vacuum reservoir bottle.It is a black globe, about 5 inches in diameter, located in the passenger wheel well area--toward front of tire. There are 2 hard lines connected to it-one is supply vacuum (black) the other one goes to the function door (grey)--they run along the passenger wheel well, and can get broken.
Also-check the bottle for water inside-(condensation) by removing it, and shaking it out. good luck |
| Thread Tools | |
