| Stock 2006 -2010 Explorers Stock 2006 -2010 Ford Explorer Forum. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Talbott TN
2000XLT
Oil change light
Still having trouble getting my "oil change" light to go out .I have set the oil change period to 60% as the oil change period is 3000 miles but the change oil light keeps coming on. How do I set it when you change the oil as the dealer has changed it the last two times. You help would be appreciated
Jim
#2 |
Grove City, Ohio
2010 Sport Trac Adrenalin
When you go through the menu into system check, there is an option to Reset the Oil Change Life to 100%, that'll fix the problem...
#3 |
Lynn, Ma.
2007 Sport Trac
If you change it to %100 will that never make the light pop up again??
#4 |
Rancho Cuc,Ca(home) SLO,Ca(school)
1997 E.B.
no the percentage decreases according to the number of miles driven...it would be pointless if it stayed at 100% continuously
__________________ '97 5.0 V-8 2wd, SpinTech, K&N FIPK, Front:Camburg 6.0 with Radflo 2.0x8.5" coilovers, Rear: Deaver's, 33x12.50 BFG AT's, 15x8 Rockcrawlers, 4.56's. |
#5 |
Portland, Or
'06 XLT
Many people stumble with this, including me. It helped me to understand there are TWO menus. The first lets you change the frequency of oil changes, which you did to 60%, and the other menu is the SYSTEM CHECK menu as stated earlier. You need to hold the selector button down at the initial(?) point to select the second menu, before going into the primary menu options. Ford really messed up with the whole computer menu and use analysis. Obviously designed by engineers.
| Thread Tools | |
