| Offroad Drivelines Ford Explorer and Ranger Transmissions, Transfer Cases, Driveshafts and Axles. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Toledo, Ohio
91 XLT EB
Bastard U-joints
I have searched the site for information on this and all i have found is references but no details. i kinda caught that thay are not liked but they may be stronger than some stock apps.
i am swapping in dana 44's and want to get a little more onformation on this subject before i setup my axle with the original yokes. also. instead of having to reclock the front C's for my caster correction, could i swap in a single-joint driveshaft(as opposed to the stock double cardon) so i can leave my diff flat, horizontal, whichever,(not pointing at the tcase) and maintain(or close to) the original caster angle? it will probably need to be lengthened anyway. __________________ '91 EB, Axle Build-up/Parts gathering in progress '05 F-150 SC 4X4- leveled, intake, exhaust, edge programmer, 35's 95 Grand Prix- currently getting head job
#2 |
Germantown, MD
The problem with running a single-cardan U-joint on both ends of the driveshaft on the front is that it limits the angle significantly.
Lets say you did run a single-cardan system, and because its a single cardan, the pinion should be about parallel with the transfer case. Well in most situations, this means the U-joints are already at maybe 6 or 8 degrees. Well lets say the limit of these U-joints are 15 degrees. This means the U-joints only have 15-8=7 degrees of driveshaft droop before they're maxed out. With a double cardan U-joint system (or CV), you typically clock the "C" (or inner-knucle) which means the U-joint is typically within a degree or two from zero.. which means you have at least 13 more degrees of movement before the U-joints max out. The rear driveshaft is pretty long so one would think that the angle wouldnt be THAT bad. But if you look at my rig, the rear driveshaft's angle doesnt look so "optimized" and I wish I had gone with a double-cardan in the rear while I was at it. And since I'm using a 14-bolt rear axle, the U-joint at the axle-end of the driveshaft is a 1350 series so it has even less movement than the 1310 series which you're using on the Dana 44. __________________ »»»»»...how'd the moon get there, how'd the moon get there? Last edited by IZwack; 04-25-2007 at 12:27 AM. |
#3 |
Lakeland, FL
'96 Ranger 4x4 XLT
Anybody know the part # for a 1310/1330 conversion joint. I'm gonna need one when I swap the 9" rear axle under my Ranger.
__________________ '96 Ranger 4x4 XLT with some stuff....and more to come when I actually have some money |
#4 |
Toledo, Ohio
91 XLT EB
I dont even know what ujoints i have. what is the stock one? i think i read 597-x or something like that. plus i have to weld the Dana44 ends on the stock drivshafts for the other axles don't i? when my friend cut them out, he left me about 6 inches of the driveshaft after the ujoint on the axles. i figured i would just have those put on when i get the dshaft lengthened. and if thats the case, what series ujoint are used with the dana 44?
#5 |
Indianapolis, Indiana
1993 XLT
I'm putting in a d44, stock front drive shaft. You can get the correct castor from the C bushings, 3*, 5*, or 7*
http://broncograveyard.com/bronco/i-...gree_black.htm |
#6 |
Toledo, Ohio
91 XLT EB
im using D44 out of waggy. doesnt use those.
My axles __________________ '91 EB, Axle Build-up/Parts gathering in progress '05 F-150 SC 4X4- leveled, intake, exhaust, edge programmer, 35's 95 Grand Prix- currently getting head job
#7 |
1993 XLT
Ah 10-4...
#8 |
Germantown, MD
The Dana 44 uses two U-joints in two places. The one shared with the pinion and the driveshaft is a 1310 series -- which is the same that the Explorers uses. The ones at the axle shaft is a Spicer 297-X which has larger bearing caps than the 1310 series.
__________________ »»»»»...how'd the moon get there, how'd the moon get there? |
#9 |
Toledo, Ohio
91 XLT EB
awesome. that helps. how hard is it to change the dshaft joints to 1310/1330? what axles use those?
#10 |
Toledo, Ohio
91 XLT EB
found this...
U-Joint Upgrade? Anybody heard about these? sounds like a direct replacement and an improvement at that. no details though. __________________ '91 EB, Axle Build-up/Parts gathering in progress '05 F-150 SC 4X4- leveled, intake, exhaust, edge programmer, 35's 95 Grand Prix- currently getting head job
#11 | |
Germantown, MD
You can't just swap driveshaft U-joints w/o swapping out the yokes on both the driveshaft and the axle and transfer case so its quite involved. And the U-joint is not the issue when it comes to strength because there are other things that usually give/break before hand.
Quote:
__________________ »»»»»...how'd the moon get there, how'd the moon get there? Last edited by IZwack; 04-25-2007 at 08:22 PM. |
#12 |
Toledo, Ohio
91 XLT EB
i understand that but i figured if i am gonna have the dshafts modified anyway, y not look into a larger ujoint? but as they sit, i shouldnt have to change the axle end of the stock dshaft to bolt up to the new axle. so are all 5 of the dshaft ujoints 1310 series? all 5 of them? and the 2 in the front axle are 297-x.
#13 |
Germantown, MD
On a stock Explorer, yes all 5 are 1310.
#14 |
Toledo, Ohio
91 XLT EB
whats the deal with these?
1310 to 1330? __________________ '91 EB, Axle Build-up/Parts gathering in progress '05 F-150 SC 4X4- leveled, intake, exhaust, edge programmer, 35's 95 Grand Prix- currently getting head job
#15 |
Germantown, MD
those are conversion joints.. allows you to run say a 1310 driveshaft to an axle that runs 1330.
The difference between the 1330 and the 1310 is not the bearing cap diameter but rather the length/width of the U-joint itself. So that joint will be slightly taller on the 1330 side than the 1310 side. __________________ »»»»»...how'd the moon get there, how'd the moon get there? |
#16 |
Toledo, Ohio
91 XLT EB
no real strength increase though?
#17 |
Toledo, Ohio
91 XLT EB
There you go ZainyD-found your joint on Ebay
1310-1330 __________________ '91 EB, Axle Build-up/Parts gathering in progress '05 F-150 SC 4X4- leveled, intake, exhaust, edge programmer, 35's 95 Grand Prix- currently getting head job
#18 |
Germantown, MD
Not really. But like I said, typically its something on the axle that breaks because the torque multiplication happens at the ring and pinion gear. So components after the ring and pinion (like the axle shafts), experience an amount of torque proportional to the gear ratio in the differential.
So say you're running 4.56 gear ratios and theres 100 ft/lbs of torque coming down the driveshaft and therefore the same amount at the U-joint on the driveshaft. Well the U-joints on the axle shaft will experience 100x4.56 = 456 ft/lbs of torque. Of course there are two axle shafts so this torque is distributed evenly or unevenly to the two U-joints depending on whether or not you have locker and locker design. But again, this is why axle-shaft U-joints break before the driveshaft U-joint. __________________ »»»»»...how'd the moon get there, how'd the moon get there? |
#19 |
Toledo, Ohio
91 XLT EB
So in your opinion, how important are aftermarket axles if i am only planning on playing in the mud and on trails? i dont have any rocks around so none of that. i cant see too many high stress issues when in the mud.
#20 |
EF Late Night Crew
Memphis, TN
1991 Explorer/2002 F-250
Yep. I broke a axle shaft joint pulling a friend out of the mud. It happens. The ujoing in my front axle was the one i used to mock up the front suspension with. It has not had a grease fitting in it in a year. I really need to replace it. Now that i think of it.
| Thread Tools | |
