Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
need order for spark plug wires for 99 explorer sport
Reply
Thread Tools
Old 04-26-2007, 01:17 PM   #1
nmaranda23
Encinitas, CA
1999 Explorer Sport
Vehicle Specs
(Original Poster)
Angry need order for spark plug wires for 99 explorer sport
Help! I am trying to change the spark plug wires on my 99 explorer sport, and forgot to keep track of the order of the old wires.
I purchased a Hanes manual, but the diagram doesn't seem to match my car configuration. The illustration shows the cylinders as follows:
3 4
2 5
1 6
However, the other side of the wires that plug in to the distributor cap shows the numbers in 3 rows of 2. When I am looking at the engine block, the distributor holes are lines up in 2 rows of three. Here is how my distributor cap looks:
(h is a hole)
H H H
H H H
The diagram shows it lined up in the following manner:
1 4
2 5
3 6
Any help would be tremendously appreciated!!
You can email me at thenextdon23@hotmail.com if you think you have an answer. Thanks!
nmaranda23 is offline   Reply With Quote
Old 04-27-2007, 09:30 AM   #2
kythri
Lebanon, OR
1999 XLT
Vehicle Specs
Which engine do you have? I think they're hooked up differently, but I could be wrong.
I just looked at both my Haynes and Chilton books, and can't seem to find anything on it, other than "helpful" hints on how to remove the wires.
Thanks, Haynes & Chilton!
kythri is offline   Reply With Quote
Old 04-27-2007, 09:52 AM   #3
nmaranda23
Encinitas, CA
1999 Explorer Sport
Vehicle Specs
(Original Poster)
I have a v6 SOHC, 4 cylinder.
Old 04-27-2007, 02:06 PM   #4
Lazzman
Massachusetts
1998 Sport 4wd- V6 Sohc
Vehicle Specs
The Sohc Is A 6 Cylinder.
Lazzman is offline   Reply With Quote
Old 12-20-2007, 06:11 PM   #5
jhuggins
Vehicle Specs
I made the same mistake and I need to know which plugs to connect to my distributer.
jhuggins is offline   Reply With Quote
Old 12-21-2007, 08:08 AM   #6
gijoecam
Village Idiot
Trenton, MI
98 ExSport, '00 F-150
Vehicle Specs
According to the '99 service manual, the coil pack is set up like this:
4 6 5
3 2 1
(connector on this side)
The cylinder arrangement should be...??? I can't seem to find it, so I'm sure the experts will be along shortly, but I *think* it should be
3 6
2 5
1 4
Front
-Joe
__________________
-98 Explorer Sport, 4.0 SOHC, K&N drop-in, LEMON in progress!
-'00 F-150, mucho mods
"We need to allow Darwinism take it's course and let the idiots weed themselves out of existance." ~ Rick Horwitz
We must believe in free will — we have no choice.
~ Isaac Bashevis Singer
I'm not smart, just a resourceful idiot. ~ Me
gijoecam is offline   Reply With Quote
Old 12-21-2007, 11:11 AM   #7
nmaranda23
Encinitas, CA
1999 Explorer Sport
Vehicle Specs
(Original Poster)
If your set up is vertical, it's this:
3 4
2 5
1 6
If its horizontial, just turn the set up above on its side, with 1 being the first connection on the top left.
This contradicts what you said gijoecam, but I got this answer from my Pepboys local "expert," and this was how I completed my installation and I have been running just fine ever since.
Old 12-21-2007, 11:16 AM   #8
ZBlackBeast
Plymouth, CT
1995 Ford Explorer/SHO
Vehicle Specs
I forget exactly how the coil pack is set with out my manual (im in ct for the hollidays)
But the firing order is this. now i believe the cyl num is the same too.
5 6
3 4
1 2
ZBlackBeast is offline   Reply With Quote
Old 12-21-2007, 01:46 PM   #9
gijoecam
Village Idiot
Trenton, MI
Vehicle Specs
5 6
3 4
1 2
That's DEFINITELY not correct...
nmiranda, I just copied what was written in the '99 service manual for him. I'm not saying it's right or wrong, just what the manual shows.
For the heck of it, I went out and looked at mine... Mine is set up like this:
(Connector)
1 2 3
5 6 4
front
...which coincides with what the manual shows and I posted above, just flipped over.
The #1 cylinder in a longitudinally mounted Ford is always the front passenger side, counting down that side, then coming to the front driver's side for #4,5, or 6 depending on the total number you have. To my knowledge, all Fords are like that.
__________________
Old 12-22-2007, 01:13 AM   #10
cjones101812
Avondale, AZ
06 Explorer EB
Vehicle Specs
here you go.
NOTE: this is for VIN code 'E'. 8th digit of VIN.
4x2 and 4x4 are the same
cjones101812 is offline   Reply With Quote
Old 12-22-2007, 09:56 AM   #11
ZBlackBeast
Plymouth, CT
Vehicle Specs
my bad. Like i said, thats what i thought. I couldnt remember off the top of my head!
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
