Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Modified Explorations!!
Notices
Modified Explorations!! Closed to new posts. Place new posts in our new model year appropriate forum
OHV, SOHC, DOHC....Let's have a lil discussion
Thread Tools
Old 08-16-2000, 09:21 AM   #1
SeanM
Annapolis, MD
1995 XLT 4.0L OHV 4WD 4dr
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Talking
Ok....I know that DOHC means Dual OverHead Cam, and SOHC means the same, but Single. What does OHV mean? What are the major differences between these types of engines? Is there such a thing as Quad or 5 Overhead Cams? Is it possible to convert a OHV engine to a SOHC or DOHC? Would it be worth it? Thanks guys, I hope you have a lot of solid info on this stuff. Hit me back.
Sean
_____________________________
'95 XLT 4dr 4.0L V6 OHV Auto
Flowmaster 40 series Cat-back
K&N FIPK
Bosch 4+ Platinum plugs
Splitfire ignition wires
SeanM is offline
( Join the Elite Explorers )
Old 08-16-2000, 02:38 PM   #2
niceguy
Vehicle Specs
Quoted: 0 Post(s)
Wink two outa three ain't bad...
You've got most of it figured out already. OHV stands for OverHead Valve. This is the standard configuration for the vast majority of automotive engines manufactured for since the 1940's or 50's.
An OHV engine has a single camshaft situated in the block a few inches above the crankshaft, and is generally driven by a timing chain. The camshaft actuates lifters, which drive the pushrods, which lever the rocker arms, which open and close the valves.
In a SOHC engine, this single camshaft is replaced by a camshaft located on the top of each cylinder head. This camshaft actuates the valves, I believe by way of rocker arms. (I've never actually peeked inside a SOHC valve cover...) This arrangement reduces the valve-train "mass" by eliminating the pushrods and lifters, and probably allows for more agressive camshaft profiles. Valve-train "lash" is also reduced by this arrangement.
In a DOHC, the single camshaft is replaced by two camshafts on top of each head - one for the exhaust valves, and one for the intakes. Some of these engines eliminate the rocker arms, further reducing valve-train mass and lash, with the camshaft directly actuating the valves. Other engines retain rocker arms, but they're small. The performance gains coming in part by reduced torsional stresses on the camshafts and even more aggressive profile possibilities.
On both the SOHC and DOHC engines, the camshafts are generally driven by a long serpentine timing belt. (And Heaven help you if it fails...) I'm not an engineer, so I can't comment on the trade-offs with authority, but it's clearly evident that the additional frictional losses (due to multiple camshaft bearing surfaces) and the belt parasitic loss of the multiple cams is more than made up for in power gains of the OHC configurations. What I do know for sure is that the DOHC in my 3000GT's little 3.0L pumps out 222HP. That's comparable to the 5.0L OHV V8s, at only 60% of the size. (And the twin turbo version runs 300-400HP! Woohooo!)
As for converting your OHV to SOHC, I'd advise against it. Maximum work for moderate gains. I'm not sure, but I think that even the blocks are different between the OHC and OHV engines, so you'd be looking at a complete engine swap (plus computer swaps, wiring harness, etc.) Plus from what I've read here on the board, there are some reliability issues with the SOHC. If I were intent on maximizing HP, I'd do the 5.0 swap and go from there...
Just my 50 cents worth. Others may have additional insight and opinions...
Michael
__________________
'94 XLT/4.0L/Auto/2wd
niceguy is offline
Old 08-22-2000, 01:25 AM   #3
flyguy
Gilbert, AZ
'07 XLT V8
Vehicle Specs
Quoted: 0 Post(s)
Of course that SOHC 4.0 is kind of a kicker. Its no racecar but it has nice numbers. With all the money Ive poured into mods, I still havent touched the HP of the SOHC. Although, if your gunna bother... go 5.0.
nick
__________________
New! 2007 Explorer XLT V8 "Ironman" - K&N FIPK Aircharger, SCT Xcal2 Tune, Zabtek Throttle Body
flyguy is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
The difference between 4.0L OHV and SOHC 97LTD Under the Hood 36 11-18-2010 07:06 PM
v6 ohv to V6 sohc dmgraz Need for Speed! 16 11-17-2003 06:34 PM
4.0l ohv or sohc Which do i have platnumized02 Under the Hood 6 10-13-2002 05:00 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
