#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Which O2 Sensor to Replace??? CEL Code P0133
Reply
Thread Tools
Old 05-02-2007, 05:55 PM   #1
ortred
Carson City Nevada
1996 Explorer XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Unhappy Which O2 Sensor to Replace??? CEL Code P0133
I looked through a lot of post on this forum before posting my problem, but I’m seeing a lot of controversy out there further confusing me.
I’ve got a 1996 Explorer 4x4, 4.0L, 6-cylinder with a check engine light (code: P0133). The printout Autozone gave me for code P0133 stated the bad O2 sensor was closest to Cylinder # 1, Bank 1. My Haynes manual says P0133 relates to the “Upstream” O2 sensor Bank 1. So far, I’m pretty sure upstream means the sensors between the engine and cat converter. Underneath my Explorer I found two O2 sensors; one on each side of the Explorer, between each exhaust manifold and the point where they met before the cat converter. The exhaust pipes met just before the cat converter on the right (passenger side) of the Explorer.
My question is this: What side of the engine is Cylinder # 1 on, and which O2 sensor do I replace, driver or passenger side?
Thanks a bundle!
Jason
ortred is offline   Reply With Quote
( Join the Elite Explorers )
Old 05-02-2007, 06:00 PM   #2
aldive
Elite In Memoriam
aldive's Avatar
1999 XLT
Vehicle Specs
Quoted: 0 Post(s)
In a vast majority of cases, when an O2 sensor code such as yours is thrown, the cause is not the O2 sensor.
Have you scanned the function of the O2 sensor(s)?
__________________
Al Franklin
My truck
My Quest for 30
RIP Al Franklin! 1947-2010. Gone but not forgotten! :(
aldive is offline   Reply With Quote
Old 05-02-2007, 06:29 PM   #3
ortred
Carson City Nevada
1996 Explorer XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
About a year ago Ford hooked it up to their diagnostic machine while the code was there. He said he found no problem with the operation of the Explorer, and to simply clear the code and forget it. I done that for a year because the CEL would only come on for a day or two and then go away for a month or more, but now it stays on. I've had Autozone read and clear the code twice in three weeks; the CEL always comes back on the next startup.
Old 06-28-2007, 04:54 PM   #4
jam234
Dallas,PA
2001XLTSPORTv8/4door/awd
Vehicle Specs
Quoted: 0 Post(s)
I had a similar code popping up on my 2001 5.0 and my neighbor who is a ford mechanic took it to work to check the code, it turned out the cat was bad and was replaced under warranty.
jam234 is offline   Reply With Quote
Old 06-28-2007, 07:58 PM   #5
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
Quoted: 2 Post(s)
Looky:
http://www.obd-codes.com/trouble_cod...1-sensor-1.php
__________________
96 Explorer daily driver build-1996 XLT 5.0L AWD to 4x4 conversion complete on 33's
88 BII 5.0L conversion - BII 5.0l drivetrain thread
My Bronco II - 1988 Bronco II 4x4 V8 on 35's - registry and updates
Wifes 07 FJ build - 2007 FJ cruiser locked and lifted
410Fortune is offline   Reply With Quote
Old 06-29-2007, 01:30 PM   #6
mr. Charles
P.N.W.
96' XLT 4x4
Vehicle Specs
Quoted: 0 Post(s)
Talking
.......i had this same problem & code, also, went thru resetting a couple of time's last year..... ............. ..............just got fed up with and just went out and bought 2 ea. NEW one's and replaced them>>>>>BOTH>>>>reset once again, and haven't seen this problem NOR code's come up since... .............. you could just buy one first, ( cuz they are like 40 to 60 a pop depending on what BRAND), and start with replacing the driver's side & reset.......
........< nice link thar 410, wish i would of knew about's that last year.... ....... >
mr. Charles
mr. Charles is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
