| Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Massachusetts
1998 Sport 4wd- V6 Sohc
Replacing Torsion bars
I want to replace the torsion bars on my Sport, as the front suspension seems to be shot.
All components are new aside from the Torsion bars which are original. I know the insulator pads are worn down and the bars seem to be worn out as well. The bumps are extremely harsh and bone jarring. The shocks are new extra duty KYB Monomax. It seems that the Torsion bars are not taking up any of the impact energy anymore. The bars are relatively inexpensive. I was wondering if anyone can give me info on how to tell if the torsion bars are bad. Thanks |
#2 |
Knoxville, TN
98 Mountaineer A4WD
They really would not show anything. Do you yet know which you have? Look at the front ends of the bars. The rating is on each, the letter which is on both.
The "B" bars are the stiffest, all 4dr. 4WD's got them. Mountaineers generally got softer bars. I installed "B" bars before dropping and noticed no difference really. __________________ Don 91 Lincoln LSC/SE, 99/93 Explorer Limited 4WD, 98 AWD Mounty with 255/55/18's, big sway bars, and 12.75" x 1.25" rotors. Soon a BW4406, built trans, stereo and interior. The best thing that could help us all, is the Fair Tax Plan. Be American, Buy American (Manufacturer)
#3 |
Elite Garage Builder
McVeytown, PA
'11 XLT
I highly doubt your torsion bars are shot. If they were you would have to crank the torsion bolts way in to keep the ride height correctly adjusted. If they fatigue from age, they will sag, but most likely won't affect the ride quality. The torsion bar is just a spring.
If you have a torsion twist on your truck, that will make it ride significantly harsher due to the angle change in the suspension and the way loads a transmitted to the frame. What tires and tire pressures are you running? That can make a huge difference. The torsion bar isolators just help deaden noise and rattle..they shouldn't change the ride characteristics. As Don said, you can change to a softer torsion bar for a smoother ride, but it will be at the expense of handling... __________________ Moderator..Home Improvement/Explorer 911/2011 Explorer Forum You took my breath away....and now I want it back.... '66 Mustang Coupe, '04 Mustang Mach 1, '08 Focus, '11 Explorer XLT "Ex"plorer's: '92 Sport, '94 Sport, '01 XLS Our Crappy Website |
#4 |
Massachusetts
I will have to look for the letter rating, I have a 1998 Sport with the optional 255/16/70 tires. I run 32 psi in them.
Funny thing though the rough ride seemed to get worse over the last several months? Something has got to be causing it, feels like there is nothing to absorb the bumps in the road. Hard slam most notably on pot holes and larger bumps. Truck never used to be like that. |
#5 |
Old and in the way
Humboldt, Kansas
2000 Mounty
Your new shocks might not be so new any longer--or rather, might have failed.
Might I ask which brand, and how long they have been on? edit-I re read the first post- |
#6 |
Elite In Memoriam
1999 XLT
__________________ Al Franklin My truck My Quest for 30 RIP Al Franklin! 1947-2010. Gone but not forgotten! :( |
#7 |
Dead Inside
Miami, FL
'96 XLT 2WD
Balljoints could be shot. My ride improved dramatically after putting new ones in.
Should do that again soon... |
#8 |
Massachusetts
My balls joints were deemed rock solid by three different independant shops, all 4 were replaced by the dealer at 110, 000mi- truck now has 157k easy miles on it.
I have ruled out the Ball joints, and am thinking it is something with the torsion bars, me thinks the torsion bar isolator pads wore away and the adjustment bolts need to be tightened down a bit to compensate. It seems when I hit a bump that the impact is going straight through the truck, nothing is absorbing it. With the new parts in the front end this truck should ride nicely with no issue. I do have the rear end sag, rear is probably 1.5" - 2" lower than the front. I have decided to go with 4 leafs from a used 4 door X for the rears. I have the new Torsion isolator pads already. I will do the pads and rear leafs and then level the truck off again to see if it helps with the rough ride. |
#9 | ||
McVeytown, PA
'11 XLT
Quote:
Quote:
Remember..it is a truck..it's not gonna ride anything like a Lexus..... I'll ask this question again...what brand and type of tire are you running? Not size...Brand and type..i.e. Firestone Destination LT's.... __________________ Moderator..Home Improvement/Explorer 911/2011 Explorer Forum You took my breath away....and now I want it back.... '66 Mustang Coupe, '04 Mustang Mach 1, '08 Focus, '11 Explorer XLT "Ex"plorer's: '92 Sport, '94 Sport, '01 XLS Our Crappy Website |
#10 | |
Elite In Memoriam
1999 XLT
Quote:
What shocks are you using? __________________ Al Franklin My truck My Quest for 30 RIP Al Franklin! 1947-2010. Gone but not forgotten! :( |
#11 |
Massachusetts
I am using KYB Monomax Shocks. My tires are Cooper Discoverer AT.
I hear what your saying about the shocks absorbing bumps but there also has to be a secondary system, in this case it is the torsion bars. In newer vehicels you have springs teamed with the shocks to help. I don't believe a shock is going to be able to take all of the road force a vehicle experiences, there must be something to help it or split the task such as leaf springs or coil springs. |
#12 |
McVeytown, PA
'11 XLT
You don't get it and you won't listen...Good luck with your problem..I'm done...
#13 |
Fontana,CA
'96 XL
Replace the shocks with some rancho 9000x's and you will notice the difference and even be able to play with the ride a little with the adjustments. Stiffer shocks will give you a harsher ride, softer shocks will give you a softer ride. I have very stiff shocks on all 4 corners and my ride is very harsh compared to the stock shocks.
__________________ Sean. BTF built explorer race truck in progress. http://www.explorerforum.com/forums/...d.php?t=216036 BTF-FABRICATION.COM |
#14 |
Massachusetts
Ok, I will check the shocks.
Thanks |
| Thread Tools | |
