EF Swag Store 2013 Ford Explorer Forums Elite Membership Chat Room My Posts Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Rear Driver Side Window Problem
Reply
Thread Tools
Old 05-18-2007, 04:54 PM   #1
Clutchless1995
Alexandria, VA
1995 XLT
Vehicle Specs
(Original Poster)
I have a 1995 XLT that just hit 100,000 miles. The rear driver side window will not operate from either the master switch or the door switch. All other windows operate properly. Could it be the motor? Is there a separate fuse for that window? Does anyone have a suggestion before I decide whether to take the door apart or just ignore it?
Clutchless1995 is offline   Reply With Quote
Old 05-18-2007, 06:11 PM   #2
budwich
Ottawa, Ont
96 XL
Vehicle Specs
well, I always find that if I ignore things, they just go away... :-). You won't be able to solve your problem without going into the door panel and / or door post area. You need to check for voltages at the window motor in question. If there is voltage (and ground) there, then its a motor problem. IF there is not voltage (and ground), then its a wiring problem and it is somewhere between the motor and the splice in the door post especially if your right side rear window works which also takes its "stuff" from the same splice.... likely wire in question is R/LB (at least in my 96 drawings). It could also be the window switch on that door. More checks... :-)
budwich is offline   Reply With Quote
Old 05-28-2007, 05:38 PM   #3
BlueOvalProud
Stamford, CT
'96 XLT
Vehicle Specs
I had the same thing happen to my '96. Try this first before you start buying a new motor; If your other windows are working its not the breaker, fuse or the child safety switch. The backing of the switch may have worked its way loose. Pull off the armrest and look at the switch. The clips still should holding the back in place. If for some reason the clips have let go then the contacts are open regardless where you are trying to operate it from. Barring that, try a voltmeter on the leads going to the motor.
BlueOvalProud is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
