Ford Explorer Sport Trac Ford Ranger Mazda Navajo Mercury Mountaineer, Ford Aerostar Message Board®
Ford Explorer, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Ford Aerostar SUV Enthusiast Forums
Join the "Elite Explorers Today!"
Explorer4x4 Sportrucks EF Arcade Forums Elite Membership Product Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Repair - Tech - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. No modification questions.
Reply
Thread Tools
Old 05-24-2007, 02:13 PM   #1
Spdrcer34
Trixi & Speed
Bremerton, WA
Spdrcer34's Avatar
Hers:`93 XLT His `92 XL
Vehicle Specs
Front Pass. Window goes down....
I can get the Front Passenger side window to go down, I can get it to go up...but if the window goes ALL OF THE WAY DOWN, it will not come back up.
I have taken the whole assembly out of the door NUMEROUS times trying to track down the problem, to no avail!
I know it's not the motor. I have replaced the bushings with metal bearings. I cleaned the contacts on the motor itself. I can't be the motor, as the window WILL go up and DOWN...the window will go down, and I have gotten it within 1/2" of all of the way down, and it will go back up. No problem. It's when it goes 100% down, it won't go back up without pulling the whole assembly.
Are there any adjustments that can be made? Or do I just need to replace the regulator?
Thanks,
Ryan
__________________
1992 White Ford Explorer XL
1993 Green Ford Explorer XLT
1992 Red Mazda Navajo XL
Spdrcer34 is offline   Reply With Quote
Sponsored Links (Less Ads)
Old 05-24-2007, 02:29 PM   #2
Mutineer
O.D. GREEN?! HOOAH!!!
Athens, AL
Mutineer's Avatar
98 MOUNTAINEER
Vehicle Specs
Does the motor try to bring it back up after going 100% down? ( a humming or grinding noise)
Do the lights dim when you try to bring it up afterward? (meaning the motor is pulling too many amps due to a bind-up somewhere in the mechanism)
Could be the Motor has a bad spot right there on either the contacts in the motor or the gears in the gearbox....
Some pics might help
Daniel
__________________
DANIEL RAYMOND FLOYD
www.floydmotorsports/mutineer
'98 MERCURY MOUNTAINEER: S.A.S., 5.0L, T.M.H.,True Dual, BW4406,
'98 DODGE RAM 3500 4X4 DUALLY: 5.9L 24V Cummins Turbo Diesel, Tow Rig
Mutineer is offline   Reply With Quote
Old 05-24-2007, 11:29 PM   #3
Spdrcer34
Trixi & Speed
Bremerton, WA
Spdrcer34's Avatar
Vehicle Specs
Yes, there is a definite click in the motor like it is trying to push the window up.
My lights are not dimming though.....I have upgraded my electrical system, 2 Optima Batteries, 200A alternator, 1/0 wires from ALT to Bat., Frame to Bat., and Engine to Frame....so it takes A LOT of draw to make my lights dim!
I also thought of the 'dead spot' in the motor, but I have taken it apart numerous times, rotated the stator....same thing all over again....
Pics wouldn't do anyone any good in THIS case...as it LOOKS normal...but SOMETHING is hanging!
Ryan
__________________
Old 05-25-2007, 01:32 AM   #4
Spdrcer34
Trixi & Speed
Bremerton, WA
Spdrcer34's Avatar
Vehicle Specs
okay....
I tore it apart, yet AGAIN!..
I rolled the window UP...then I rolled the window DOWN...then I got it to roll UP again...
Not really sure what the deal is...but for NOW it is fixed. I'll bring this topic back to the top again if it does it again.
Ryan
__________________
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
Copyright 2010 - 1996 Rick Horwitz Photography
