Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
today my 93 a4ld will not go in any gear Help
Reply
Thread Tools
Old 05-24-2007, 04:48 PM   #1
gtdad
Ewardsville il.
1993 4wd ranger
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
My wife 93 ranger 4x4 4.0 auto was driving great with no problems now when she try to go to work it would not move in any gear when she put it back in park it made grinding sound. what could be the problem Please Help
gtdad is offline   Reply With Quote
( Join the Elite Explorers )
Old 05-25-2007, 03:51 PM   #2
gtdad
Ewardsville il.
1993 4wd ranger
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Can anyone help with this problem or show me where to find help? Thanks Gtdad
Old 05-25-2007, 05:01 PM   #3
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 427 Post(s)
Check the fluid level to start. It might be the Z link if all of the gears are out. That part could get disconnected suddenly. This link has more information: http://www.explorerforum.com/forums/...d.php?t=155599
BrooklynBay is online now   Reply With Quote
Old 05-25-2007, 11:43 PM   #4
gtdad
Ewardsville il.
1993 4wd ranger
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Hi would the Z link also make the grinding sound when put back in park? Thanks for reply
Old 05-25-2007, 11:58 PM   #5
IZwack
Moderator Emeritus
Germantown, MD
IZwack's Avatar
1998 Ford Explorer
Vehicle Specs
Quoted: 2 Post(s)
Quote:
Probably not.
As stated, check the transmission fluid level.
__________________
...how'd the moon get there, how'd the moon get there?
IZwack is offline   Reply With Quote
Old 05-26-2007, 12:45 AM   #6
gtdad
Ewardsville il.
1993 4wd ranger
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
The trans level right on the money also clean anything else thanks for the help
Quote:
Originally Posted by IZwack View Post
Probably not.
Old 05-26-2007, 10:39 PM   #7
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 427 Post(s)
The next step is to drop the pan. Check the Z link, and see if there are any broken parts in the pan.
Old 05-27-2007, 01:54 AM   #8
gtdad
Ewardsville il.
1993 4wd ranger
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks Iwill drop the pan on monday check Z link.And see if I find anything in the pan. I will get back soon to let you know what I find. thanks for the help
Old 05-28-2007, 06:59 PM   #9
gtdad
Ewardsville il.
1993 4wd ranger
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Hi check the pan nothing but clean fluid everything looks good put pan back on add new fluid then my wife said try it in 4wheel low in it right an gear but it won't work in 2wheel 4 wheel high. What do you think it is Please Help
Old 05-28-2007, 08:08 PM   #10
IZwack
Moderator Emeritus
Germantown, MD
IZwack's Avatar
1998 Ford Explorer
Vehicle Specs
Quoted: 2 Post(s)
So what you're saying is that the vehicle is able to move in 4LO but not 4HI or 2WD?
If that is true, then its a transfer case problem. The transfer case isnt being properly engaged in 2WD or 4HI, perhaps broken (or bent) shift fork and so on.
__________________
Old 05-28-2007, 10:54 PM   #11
gtdad
Ewardsville il.
1993 4wd ranger
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Hi do you know any forums that show how to work on this transfer case it's a Borg warner 1354? thanks
Old 05-28-2007, 11:05 PM   #12
IZwack
Moderator Emeritus
Germantown, MD
IZwack's Avatar
1998 Ford Explorer
Vehicle Specs
Quoted: 2 Post(s)
There's really nothing to dissasembling a transfer case.
Though the thread below is for the BW-4405, dissasembly should be pretty much the same so you might want to read it over just to familiarize yourself with the procedure and get an idea of what sort of tools is required:
http://www.explorerforum.com/forums/...d.php?t=182071
__________________
Old 05-28-2008, 11:27 PM   #13
Tbars4
Offroad/Fitness Moderator
anaheim hills,california
Tbars4's Avatar
95 ranger 4x4/ 91 X 4x4
Vehicle Specs
Quoted: 300 Post(s)
...It may also be a cheap fix as found here...
http://www.explorerforum.com/forums/...d.php?t=123542
__________________
I have Rocks in my head. What's in yours?
'95 ranger xl 4x4 2.3L std cab, 3 sticks Ranger RegistryThe Squirrel
'91 4x4=To much to list, much more to add.. Project "X" and more Pics & Mod's List
How to: Wheels,Tires, & Lifts...
Buy Explorerforum.com Items here
Tbars4 is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
