| Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. |
Thread Tools |
#41 |
Wannabe Elite Explorer
harrisville, wv
1996 ford eplorer
I just got my 96 explorer and it didnt come with a overhead display. I was wondering if it was possible to add one useing one from another explorer. . . . . I had a jeep before this and i was able to do that but i dont know about this. . .
#42 | |
Shelby, North Carolina
98 XLT
Quote:
#43 |
98 XLT
0verhead consule--98 Ford Explorer XLT
When I removed the circuit board it appears that one of the 510 resisters is missing..It looks as if it fell off for the base has some old solder..Would this be why my composs and temp indicator is not working...Where can I get this repaired..My dealer says a new unit will cost $500...The wires and solder on the only 510 resister look ok to me...
#44 |
tally, fl
04 XLT
other boards without sunroofs
did anyone figure out the problem for a 95 xlt without a sunroof since the circuit boards are different? The only thing that I noticed that could be wrong with mine is that the lighted display has a burnt spot in one corner. I believe thats the reason its does not work.
Last edited by aricanderson; 12-29-2008 at 06:39 PM. Reason: oh thought of something else |
#45 |
Knoxville Tennessee
1994 Limited
Great write up!!! I just purchased a 94 Limited. And was wondering why mine wasnt working. My console is slightly diffrent than yours, and i didnt have to remove the sunroof moulding. Instead there were 2 screw's in the garage door compartment. Pulled mine all apart, didnt notice any bunt, or solder marks. Did notice that my led screen was burnt in one corner thou. Can this part be purchased as a single unit? Or do i have to buy the whole console?? Time for me to hit the salvage yard's !!!
#46 |
Flunked daycare
outside shovelling snow
................ 96 XLT ™
scubba.steve, the F150 board I repaired had a burnt corner also, but worked fine with it...
__________________ Kent - 1996 XLT - Hypertech Programmer, Gibson Catback, K&N FIPK, Alpine V12 MRV-100M, 8" round 2ohm Kicker Solobaric
1992 Toyota Paseo - Tein Super Street coilovers, Whiteline swaybars 22MM(F) 20MM(R), Prothane endlinks & mounts, VVR poly control arm bushings, K&N drop-in, Dynomax Ultraflo, Gibson stainless tip, Pirelli Winter Carving Edge(F) Kumho HP4 716(R) on steelies |
#47 |
'99 XLT
Great write-up! Thanks a million. Saved me $150+ for new console from dealer. One of my 150 ohm resistors was clearly detached.
Couple other points to add: 1. You should use the same value resistors if you need to replace them. 2. Too much solder can be just as bad as too little... you just need a solid connection. If you get too much on there by accident, use "desoldering braid" to remove it. Available at Radio Shack. 3. Using a small diameter solder makes things MUCH easier. I used .022 diameter. Also available at Radio Shack. 4. Using solder flux will greatly help your solder connection by letting the solder flow easier. "Rosin Soldering Flux" also available at Radio Shack. 5. And I'll just echo the previous comments that a 15-20 watt soldering iron is best. Too much heat will cause the fine traces on the circuit board to lift, and then you'll have a mess. Same applies to reheating the same area over-and-over... try not to resolder the same area too much without letting it cool down completely. Thanks again! |
#48 |
Crawfordsville, IN.
2000 Explorer Eddie Bauer
Overhead Console Fix
Thanx for the step by step instructions and pics. I realy appreciate it. I have a 2000 Explorer Eddie Bauer. I just finished and it works great. I seem to have the same trouble with my radio display. I don't have any display at all. Any suggestions? Chances are it is the same situation as with the overhead compass. A resistor needs resoldered. If anyone has an idea or had the same trouble and fixed it please let me know. Thanx again for the info.
#49 |
Knoxville Tennessee
1994 Limited
#50 |
Stevensville, Maryland
'01 Explorer Sport
Thallarsen,
I also want to thank you for the info and pictures. I found one of the "501" resisters had completely come unsolderd on one end. After a quick trip to radio shack for a $10.00 dollar soldering iron, The one I have have in my shop was to big, did the resolder, checked the display before reinstalling and low and behold I'm back in business. I do have one question. Does the display need to be recalibrated? |
#51 |
SD,CA
96 XLT 2WD 5.0L
My display always reads 140F/60C.I can also turn it on at any time with the key out.I can also roll my power windows down and turn the heater/ac blower on.Does anyone have any idea for a fix? Thanks
#52 |
tally, fl
04 XLT
ok heres a pic of the console that i have for a 95 xlt without sunroof. I have looked over the board. Has anyone found a common problem with this board or could the problem be somewhere else?
Thanks aric anderson
#53 |
Knoxville Tennessee
1994 Limited
Thats the same board in my 1994 limited... i inspected it pretty good, didnt have a magnifying glass though. Everything appeared normal. Mine is still not working
#54 |
tally, fl
04 XLT
quick update. i hooked up 12volts to the overhead unit and the display works so now i'm going to check my ground and fused #10 10Amp hot in run. I believe the problem is in the power coming in. I'll let you know what i find tommorrow. Or maybe its still in the unit itself. I decided to test the board with 12volts on it and i bet you that the problem lies in the ribbon that runs from the board to the display. Every time i touch the ribbon my display goes on and off.
#55 | |
peoria, illinois
'01 f-350
Quote:
just look at whatever board you have and look carefully at the diodes. You'll see the problem. Good luck |
#56 | |
peoria, illinois
'01 f-350
Quote:
#57 |
Raleigh, NC
'99 Eddie Bauer
Thanks for this thread man. When I bought my Ex, the compass/thermostat display was bad. The guy I bought it from said the dealer told him it would be a couple hundred to replace. Undoubtedly, this helped devalue the car a little bit. After resoldering the resistor, works A-OK. Thanks to the OP for finding/sharing this.
__________________ '99 Explorer EB - 4.0 SOHC |
#58 |
Virginia
2011 Ford Explorer XLT
As one poster mentioned, in Chrysler/Jeep/Dodge vehicles you can take an overhead console (junk yard) from a vehicle with more options in it and place it in a lesser optioned vehicle with no problem, as the wiring and computers/sensors are all the same in the vehicles.
Can this be done in Ford Explorer's? For example, can I go to the junkyard and start grabbing parts from an Eddie Bauer/Limited Model and place them in a basic XL Explorer? (same/similar year model)?? How about seats? Can I upgrade to leather seats with electronic seat adjustments, etc?? Thanks in advance for any answers - I'll also keep searching around these forums - hopefully I'll find the right place where modifications/upgrades are located. Last edited by jlrohio; 02-01-2009 at 01:52 PM. |
#59 |
east stroudsburg, pa
99 xlt
perfect. i found the first resistor solder was broken. works great now. directions were very acurate and pics helped with eveything.
99 explorer with sunroof. |
#60 |
99 xlt
just to follow up if your interested. the solder didn't over heat and seperate. it appears from the vibrations in the truck the solder joints crack over time or if the original solder was to thin from the begining. which all manufacturers do to save money. if you look close you will see a jagged edge as if it cracked. when it overheats the edges will roll over and leave a big gap. just an FYI.
| Thread Tools | |
