| Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. |
Thread Tools |
#81 |
Wannabe Elite Explorer
2003 FORD SPORT TRAC
I have a 2003 sport trac no sunroof with 2- 510 resistors
#82 |
houston, tx
1999 explorer xlt 5.0 v8
Old post. But Wanted to thank Thallarsen again for this one. I don't solder worth a damn but i still did and it still worked.
#83 |
shinnston wv
2000 explorer sport
i printed out the instructions and followed, it worked great i now have my overhead display after 4 month of a blank screen , thanks so much
#84 |
Tyler Texas
91 Explorer 4X4/99 Mounty
New member , just joined to try to fix oue '99 Merc Mountaneer's Compass & Temp Display.
She is really missing it. I hope to get to try this fix asap |
#85 | |
Dothan Al
2003 xlt
Quote:
#86 |
Tyler Texas
fix
#87 |
Excelsior, Minnesota
'99 XLT
When you are taking it apart make sure you DON'T bump the display at all. It will get screwed up very easily. I nudged it just a fraction and now have lines going across the screen. It works but can't see shit cause of the lines.
Good luck though.
#88 |
Dothan Al
2003 xlt
I finished and it worked perfect. Thanks
#89 |
Albuquerque, New Mexico
2000 Limited
Thallarsen Overhead Console Fix
Thank you Thallarsen !!!
Just to update for those still browsing looking for info. This fix is accurate and good as of Oct 2009. Excellent instructions just as posted - a breeze. i have a 2000 Explorer limited w/sunroof and followed the instructions to the letter. The pics and directions were as accurate and complete as can be - helped make the fix as easy as can be. As an aside, i had to run by the dealer to get a recall item completed and I mentioned the overhead console problem and their answer was typical dealer only to replace the whole console at big bucks when your fix only took 15 mins. |
#90 |
Arab, ALABAMA
'01 Ford F350
F350 Fix
I had the same problem with my 2001 F350 I just purchased. I followed the instructions and took the unit apart. Low and behold one of the diodes had the solder connection broken. I purchased a $16.74 battery powered soldering pen from Marvins that came with solder. Ten min later I pluged the unit in and it worked!!! Thanks a million for your complete directions!!!
#91 |
GUAM
1996 EXPLORER/EXPEDITION
I am trying to do this fix right now but cannot locate the diodes with the 501 or 510 on them. Can someone point out the location, left, right middle ect or circle it on the photo with MS paint.
I have this same board in my 1996 Explorer Thanks
#92 |
Tyler Texas
Overhead console circuit board
I did our '99 Mounty 5 or 6 weeks ago, using the tips I found on this forum. I really did go to Radio shack and bought one of those magnifying glasses that sits on the table ($20), also got their 30watt gun and some really tiny solder.
I'm not seeing the two pieces that need to 'touched' in your picture. It took the magnifying glass to see mine. But they really do have the numbers on them and they are sibe by side on the board . As I recall, they are approx 1/8 inch rectangular. |
#93 |
Lebanon, Ohio
'99 XLT 2WD
I too have a non sunroof model... Mine only has one resistor and I also did the solder trick on it and it works great now... Many thanks to the originator and all others... Good Luck
#94 |
Michigan
04 CV LX Sport
In my 95, the display doesnt turn on for a while after its started, sometimes a matter of a minute or two, sometimes a matter of 10 minutes, the compass works fine, but the thermometer just says "OC" can anyone help?
__________________ '13 Dodge Charger RT |
#95 |
97 Eddie Bauer
Very good info, thanks!!!
#96 |
2002 Sport Trac
2002 sport trac overhead console circuit fix
I was able to lift my 510 resistor up with a thumbnail. Once re-soldered it worked great. Thanks for the info.
#97 |
Durham, NC
2003 XLT 4WD
Wow!!!
I think this will probably fix my Compass/Temp display. Just wanted to say "THANKS" for the great job explaining "How to"!! It became intermittent then just went totally out. I'll try the fix tomorrow in daylight.
Thanks again...http://www.explorerforum.com/forums/...es/biggrin.gif Scratch |
#98 |
Tucson AZ, now germany, next is Mississippi
2004 EB4x4v8 & 96xlt2wdV8
Mine had a different board layout, much smaller than other's. Non sunroof 96 XLT.. Two resistors #'d "161". One popped off when I was exploring with a sewing needle.
#99 |
Syracuse, NE
98 XLT
Mine went out a couple of months ago so i got a new one and put it in. Does no good because it doesnt work either and i know it was a good unit. Also my heater blend door dont work along with my blinkers, cruise, and rear defrost. I replaced the multifunction switch and it worked for a couple days before goin out again. Im thinking its a wiring problem so i checked were the harness plugs into the MF switch and those are fine. Where else could this wiring problem be? also all my fuses are fine as i have checked them also. Please help
#100 |
'99 XLT
Thanks!!!
Just read the directions today and fixed my wife's Overhead Console. Awesome details and the wife is very happy.
My first soldering job didn't work. The second time, I just soldering the heck out of it and all it's all good. Thanks again. Later... - Wayne |
| Thread Tools | |
