| Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. |
Thread Tools |
#121 |
Wannabe Elite Explorer
Ocean City, MD
'01 Sport 4wd
Not Yet
The instructions and pictures were great. I HATE plastic wire harness connectors but managed to get it apart without breaking more than one tab. Once apart, found one of the 510 resistors missing.
Have to wait now till daylight to search interior of my 01 Sport. If I can't find it, what's the best alternative replacement?? |
#122 | |
Michigan
04 Sport Trac XLT Premium
Quote:
The resistors I bought had a wire on each end, but it wasn't too difficult to solder it in place. My unit is still working excellent! Jon http://1972vega.wordpress.com/ |
#123 |
Excelsior, Minnesota
'99 XLT
I had bumped the display back when i did this fix now there are lines going across the display covering up the numbers and compass. Any ideas on how to get these contacts working again?
#124 | |
Ocean City, MD
'01 Sport 4wd
Small Miracles
Quote:
This evening, I confirmed I can't solder worth a hoot, but still managed to get it on the board, get everything back together and as of now, the display is working fine. We'll see if it's still there after a couple of good potholes. Thanks for the excellent instructions!! |
#125 | |
Channel Islands, CA
1998 Ford Explorer Limite
Quote:
#126 |
Woodleaf NC.
1999 Explorer XLT
Major score !! Had mine fixed in minutes. Thanks a bunch .
#127 |
2003 Explorer Sport
Followed your excellent directions. Sure enough one of the resistors had a broken solder connection. Was able to resolder and am all set. I cant thank you enough.
#128 |
Holiday, Fl
1999 XLT
Exployer overhead console
OMG! what an amazing post! thank you so so much. i've been "lost" for the past year without my overhead console. my husband followed the step by step directions and now i can find my way. i couldn't be more thrilled! it only took about 25 minutes. perfect directions!!!
#129 |
Italy, Roma
2000, 4.0 SOHC Limited
Grazie a tutti siete stati fantastici. Grazie dall'Italia.
Thankyou very much at all. You are fantastics. Thankyou form Italy. |
#130 |
Trenton MI
1999
Thanks Thallarsen
We were driving and my wife noticed that the display was out. She said I guess everything will just keep breaking down. We have 99 Explorer and a new one is not in our plans. It seems as if every week something stops working. Did a search and found your link. The instructions are perfect. What took the longest was getting a decent soldering iron. Checked out Harbor Freight, Home Depot and Lowes. Ended up at Radio Shack. Don't waste any time just go to Radio Shack. They have a large variety of irons and also have the helping hands magnifying glass. Got everything for about $25. Found that both resisters were loose. This was done by using the magnifying glass and screwdriver by lifting up the resister. The resisters are very small and you will need the magnifying glass. Thallarsen must be a electronic expect to have detected the defect. Would have never been able to find the loose connection. Soldered the resisters and reinstalled the unit and got the display back. Would recommend doing a google search for Soldering. It really helped me. You should be able to get a video showing how to do it right. My wife and I cannot thank you enough. She felt lost without the temp. Funny how things like that get to be important. |
#131 |
Logansport, Indiana
1999 Ford Explorer Sport
i have a 99 explorer sport no sunroof and mine has 2 510 resistors opened mine up found one of the 510 was off a lil did the fix now its back to working turned my truck on to see that it was 107 today wayyyyyyy toooooo hotttttttttt lol at least I know what the temp is
#132 | |
Pennsburg, PA
1999
Awesome, easy to do and worked like a charm. Thanks!!!
Quote:
#133 |
Erie, PA
1999 Limited V8
Worked perfectly!!!
At first, I thought this fix didn't work. I turned the key, it flashed for a second then went out. Turns out it was just in the "off" position---doh!
The right resistor looked ok but the left was barely hanging on by a tiny thread of solder. Popped right off when I touched it with an X-acto blade. I ended up doing both resistors. Was a little tricky to reassembleso take some notes or pictures. Thanks! ---Lizard __________________ '99 Limited, 5.0 AWD Full Metal Jacket |
#134 |
Dallas, TX
2001 Explorer Sport Trac
Wow - what great repair help. One of those resistors actually fell of my circuit board, probably due to the love taps I'd give it when it'd fade out. $.99 worth of resistors from Radio Shack and good as new. Thanks for sharing the wealth. I'm sure this part wouldn't be cheap to replace from Ford!
#135 |
Minnesota
98 explorer xlt
Thanks for sharing!
We can tell Thallarsen has some talent for fixin' and writin'! Thanks for the detailed steps. By the way, I found the "fixya" web site was selling this solution for $9.99. It was the exact resistor with 510 printed on it that was the source of the problem. Just a small hairline crack in the solder and I hit it with the iron and now it works. This forum rocks!
#136 | |
Potomac, Maryland
'99 5.0 Limited AWD
Quote:
I've never gotten a cent for this, and I've never asked for it. The hundreds of genuine "thank you's" that I've gotten here is worth more to me than $10 here and there. Almost 5 years ago, when I decided to find out why my temp/compass display wasn't working, I did an extensive search (like most of the folks who have found this thread did to get here). I had discovered somebody else's fix for my Mach head unit display with great results, but I found nothing relating to the temp/compass display. Absolutely nothing. So I delved in with nothing to lose and stumbled across the little weak link in the 510 solder. I figured that I'd share my discovery with anybody else experiencing the same problem. Serious Explorations is the first and only site where I've put this. Since I had gleaned (and still do) so much good advice and valuable information from Serious Explorations, I figured that I'd give back to the community. Glad to be of help
#137 |
Vegas baby!
98 Eddie Bauer
Great instructions
I just did this repair today on my 98 Explorer Eddie Bauer. Don't have a sunroof in mine but aside from the black tab at the back of the console, everything else is spot on.
Couldn't find the proper 1/4 watt 68 ohm surface mount resister, so I bought a 10 pack of 1/4 watt 68 ohm round resisters (the old style with the legs). The surface mount pads are far enough apart and big enough, and with little creative bending, cutting and soldering, my overhead console is working like a champ. For reference, one of my resisters was completely gone. Anyway, great job and thanks for the writeup. SoS |
#138 |
Orlando, FL
1999
Excellent write up ! This saved me hours of diagnosing it myself. A hairline crack in the solder - quick hit with the iron and all is well. Very simple fix - took me less than 20 min start to finish. I just tin'ed the leading edge of my iron pretty well, added a dab of flux to the resister, made contact and about 2-3 seconds later, it wicked from the tip onto the board and connected the resister.
To others - just go slow when separating the white/black cover on the board. The tabs look like they break easy if you're not careful. A small jewler's flathead did the trick. I had no problems! A grateful thank you from me....and a huge thank you from my wife, whose car this is!!! Thank you again! |
#139 |
Boston
99 Mounty 5.0 it's Blue!
This was my project today! Success! Found a dead spider in the console. Putting it back together with out breaking anything was the longest part of the job.
#140 |
Is this the same K. Sims (SimplexGrinnell, Harahan, La.)?
| Thread Tools | |
