Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
Fan Speed 1 and 2 not working????
Reply
Thread Tools
Old 06-11-2007, 07:18 AM   #1
xvprflyboivx
Tobyhanna, PA
'03 XLS Sport
Vehicle Specs
(Original Poster)
I have the manual HVAC and the other day fan speeds 1 and 2 stopped working!!! 3 and 4 work fine...WHAT HAPPENED? anybody have any insight? thanks...
xvprflyboivx is offline   Reply With Quote
Old 06-11-2007, 08:49 AM   #2
gijoecam
Village Idiot
Trenton, MI
98 ExSport, '00 F-150
Vehicle Specs
Blower motor resistor would be my guess. $13 part and 20 minutes to change it.
__________________
-98 Explorer Sport, 4.0 SOHC, K&N drop-in, LEMON in progress!
-'00 F-150, mucho mods
"We need to allow Darwinism take it's course and let the idiots weed themselves out of existance." ~ Rick Horwitz
We must believe in free will — we have no choice.
~ Isaac Bashevis Singer
I'm not smart, just a resourceful idiot. ~ Me
gijoecam is offline   Reply With Quote
Old 06-11-2007, 10:21 AM   #3
xvprflyboivx
Tobyhanna, PA
'03 XLS Sport
Vehicle Specs
(Original Poster)
where would this part be located in my X? can i get the part from any auto parts store? it wierd how my X is only 4 years old and the blower motor is already out...
Old 06-12-2007, 06:55 AM   #4
xvprflyboivx
Tobyhanna, PA
'03 XLS Sport
Vehicle Specs
(Original Poster)
**bump** i would greatly appreciate some advice on where this part is located on my X so I can replace it and save myself a $$$$$ trip to the Ford dealer. Thank you...
Old 06-12-2007, 07:25 AM   #5
gijoecam
Village Idiot
Trenton, MI
Vehicle Specs
Sorry for the sluggish reply....
The service manual lists its location as 'behind dash panel, center', but doesn't show a picture. I've never personally put my hands on one out of an '03, but my guess is that it'll be in the dash near the blower motor. You'll probably need to remove the stereo and trim from the center stack to access it.
Typically they're placed in the plenum somewhere near the blower motor so the air passing through the system can cool the resistors as they tend to get hot while the system is running. That may or may not be the case for yours. Once you have the new part in-hand, it shouldn't be too difficult to track down. You should be able to find it at just about any auto parts store, or www.fastpartsnetwork.com
The other possibility is that your switch went bad. The switch provides the ground path for the motor through the resistor pack. If the switch was bad, you'd have an open circuit in positions 1 and 2, and a closed circuit in positions 3 and 4. If you're looking at the back of the switch, you'll want to check for continuity between pin 15 and the four other pins. If the circuit is complete between pins 9,10,11 or 12 and pin 15, then you know the switch is good.
Hope that helps! Let me know if I can be any more help!
__________________
Old 06-12-2007, 07:32 AM   #6
xvprflyboivx
Tobyhanna, PA
'03 XLS Sport
Vehicle Specs
(Original Poster)
great thank you! i also wanted to add that when in switch 1 or 2 nothing works and no air comes out of the 2-row vents...so it maybe the switch...ill take a look this weekend...at least i have 3 or 4 to work with. i just want my 1 and 2 back...having 3 on w/ A/C you tend to get a little cold...
Old 04-23-2008, 08:36 PM   #7
MI2002EB
Eastpointe MI
'02 EB 4x4
Vehicle Specs
Unhappy Automatic Climate Control problem?
My HVAC sysetm seems to have a ghost... blower speeds randomly change or don't work at all... I think I have the same problem. However, I have the automatic climate control system, do I have the same resistor, or is a different part needed on mine?
__________________
2002 Estate Green Edie Bauer Explorer, purchased in May 2002. Still stock.
MI2002EB is offline   Reply With Quote
Old 04-24-2008, 07:50 AM   #8
gijoecam
Village Idiot
Trenton, MI
Vehicle Specs
With the EATC, you have a blowe speed control module. It's different than the resistor pack.
-Joe
__________________
Old 04-24-2008, 11:22 PM   #9
MI2002EB
Eastpointe MI
'02 EB 4x4
Vehicle Specs
Thanks Joe,
I visited the dealer today... he mentioned a similar part... is the location about the same? The dealer gave me a part number of 19E624... will have to figure that out. Of course the part is more too, 55 bucks instead of 15 bucks.
The dealer printed me off an exploded view of the system, but that doesn't help too much locate the part.
__________________
Old 04-24-2008, 11:37 PM   #10
MI2002EB
Eastpointe MI
'02 EB 4x4
Vehicle Specs
nevermind
Got my answer from this posting:
http://www.explorerforum.com/forums/...control+module
Thanks Joe
__________________
Old 08-20-2008, 11:15 PM   #11
PIexplorer
Davao
03 Sport Trac
Vehicle Specs
I have a similar problem with my 02 Sport Trac. The fan speed only works on position 1 and 4, in position 2 and 3 the fan speed remains at speed 1.
I changed the blower switch (I guess I should have read a bit on the problem here on this forum first) and the problem persists. I then checked the blower resistor and it looks rather corroded. Its part no. F57H-19A706-BA. Its located near the blower motor with the resistor inside the ducting (for cooling). I will try to replace the resistor and hopefully it will resolve the problem. Often here in the Philippines speed 1 is too little and 4 is too much aircon.
__________________
2003 Explorer Sport Trac
PIexplorer is offline   Reply With Quote
Old 08-21-2008, 12:00 AM   #12
PIexplorer
Davao
03 Sport Trac
Vehicle Specs
Fiddled at bit with the resistor and also got fanspeed 3 working, problem is definitely in the resistor. Will see if its easy to come by a new one here in the Philippines.
__________________
Old 08-21-2008, 07:01 AM   #13
gijoecam
Village Idiot
Trenton, MI
Vehicle Specs
Quote:
It shouldn't be difficult to get... Ford uses that same resistor in 90% or more of the vehicles with manual HVAC controls. It should be a pretty common part.
Good luck!
__________________
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
