Ford Explorer Sport Trac Ford Ranger Mazda Navajo Mercury Mountaineer, Ford Aerostar Message Board®
Ford Explorer, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Ford Aerostar SUV Enthusiast Forums
Join the "Elite Explorers Today!"
Explorer4x4 Sportrucks EF Arcade Forums Elite Membership Product Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Repair - Tech - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
Reply
Thread Tools
Old 06-15-2007, 01:46 AM   #1
gmarchlewicz
Rockford Illinois
1999 Sport 2x4 4.0 OHV
Vehicle Specs
1999 Explorer 4.0 OHV Camshaft Synchronizer Replacement
Well, I read through a lot of threads here and appreciate all of the great advice all have shared. I hope to give back soon. I've a noisy camshaft synchronizer and ordered a new one off of ebay. I took the upper intake manifold off, cleaned it out, and set it aside. I am also going to replace the seals/ gaskets while I am at it if I can find them. I went to Autozone, Pep Boys, and O'Reilly. Nobody has just the three little rubber seals. Any advice where to find them? I actually brought the manifold with me to show them. They had no clue. All they could sell me was a complete set of gaskets at $90 dollars. Anyway, back to my main question. Inside the Synchronizer is a half moon that rotates around the perimeter of the synchronizer's "Side Wall". Currently, my old synchronizer is still in place. I took a digital picture just in case. Now, I never set my engine cylinder # 1 position to "Top Dead Center" because I have no clue what that means. I'm figuring this out as I go along. I would imagine that top dead center would put the "Half Moon" inside the sychronizer in line with the largest notch in the synchronizer's side wall. The tool that came with my new synchronizer essentially just lines up the half moon perfectly in the center of the large side wall notch. With that said, can I somehow manually rotate the engine to put that notch perfectly in line with the half moon? I have the engine all torn down at this point with the battery disco'd. Does it make sense to do this? I would think I could then just drop the new synchronizer in as long as those two reference points's positions are identical between the new and old synchronizers. Also keeping in mind that the position of the engine hasn't moved.
__________________
Gary Marchlewicz
gmarchlewicz is offline   Reply With Quote
Sponsored Links (Less Ads)
Old 06-15-2007, 11:40 AM   #2
justanother1
Dover, PA
96 XLT; 97 XLT
Vehicle Specs
When I did this on our 96, I rotated the engine to top dead center (for cyl #1). Put the alignment tool on the new cam shaft syncronizer and installed it. I do not see a problem with installing the new one in the same position as the old one as long as the engine was not rotated as stated above. Just make sure you get this lined up in the proper postion. I beleive this tells the injector when to squirt.
I can not help wiht the seals. Did you check with Ford?
justanother1 is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
Copyright 2010 - 1996 Rick Horwitz Photography
