Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
Oil filters for 99 SOHC 4.0 engine?
Reply
Thread Tools
Old 08-28-2000, 09:12 AM   #1
David Barnes
Vehicle Specs
(Original Poster)
Talking
Just got a 99 sport with 4.0 sohc 11,000 miles on it.
Reading through the manual Ford says ONLY use Motorcraft
oil filters otherwise 'knocking and engine noise when starting' will occur. My previous explorer sport (95 with 4.0 ) was always changed at Valvoline every 2500-3000 miles and it had 110,000 miles on it when I sold it! Still purred like a kitten! Does the SOHC have some different design that lets oil drop down when it sits overnight? What about running Dura Lube through it? I did that with my previous truck. Suggestions? thanks.
__________________
99 Sport 4.0 SOHC
Black
Leather Interior
CD changer
Good Year tires!!
David Barnes is offline   Reply With Quote
Old 08-28-2000, 09:22 AM   #2
Jornum1
Clifton, NJ
Jornum1's Avatar
1999 Sport 4x4 SOHC
Vehicle Specs
I have a '99 sport Sohc also. I change my oil every 3000 religiously. I have tried a few different brands with my truck, and the only one I had a problem with was fram. It was probably just a one time thing, but the filter woudlnt make a tight seal, and blew oil all over my engine bay when I started the truck up. NOt a fun thing to fix. Especially when the oil gets on your headers and smokes like son of a bitch. I have used mobile 1 filters without a problem. Now I use Ford motorsports. Someone on here did a test, and rated that one pretty high. I use either mobile 1 or castrol syntec oil, and Ford motorsport filters. I have 23k and havent had any problem but that fluke with the fram. ha ;-)
Hope that helps
Jason
__________________
'99 Sport SOHC Auto
Pictures and a list of my mods
Jornum1 is offline   Reply With Quote
Old 08-28-2000, 10:33 AM   #3
AgExplorer
Houston, TX
'03 Sport Trac XLS
Vehicle Specs
Stay away from the DuraLube and any other oil additive. Every engine oil on the market today has everything in it you need to protect your Explorer.
As far as filters, Mobil 1 makes the best over the counter filter on the market today. All have a drain back valve that will prevent the oil from draining back down into the pan. But not all filters are made alike. Fram has not been a favorite of the guys on the board. Inferior construction and materials.
If you want the best, check out AMSOIL.
AgExplorer is offline   Reply With Quote
Old 08-28-2000, 01:11 PM   #4
David Barnes
Vehicle Specs
(Original Poster)
Wink oil filter info
Thanks for the info guys... I will not bother with DuraLube this time around and will try the Ford/Motorcraft filters and we'll see what happens.
__________________
99 Sport 4.0 SOHC
Black
Leather Interior
CD changer
Good Year tires!!
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Engine gaining oil, trans loosing Mike Mac Under the Hood 4 08-25-2003 03:56 PM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
