Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
Code 648
Reply
Thread Tools
Old 06-30-2007, 09:45 PM   #1
bren7176
Downsville Ny
95 EX Sport/98 Ranger
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Code 648
I have a 1995 Explorer the OD light is flashing and I retrieve code 648 incorrect gear ratio-fourth gear. Has anyone had this problem before and what did you do fix this ..Any and all help would be welcome
thanks
Brendan
bren7176 is offline   Reply With Quote
( Join the Elite Explorers )
Old 07-02-2007, 05:39 PM   #2
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 428 Post(s)
Try to adjust the band first. If you can't adjust it, then it might be broken.
BrooklynBay is online now   Reply With Quote
Old 07-02-2007, 10:38 PM   #3
MrShorty
Spanish Fork, UT
92 XLT and '87 Bronco II
Vehicle Specs
Quoted: 10 Post(s)
I'm not real familiar with the 4R55E, but here's what I can say.
Your 4R55E has speed sensors on the input and output shafts of the transmission. The computer "knows" what the gear ratio of each gear should be, so it know what the relative readings of those two sensors should be. It sets that code when it gets the "wrong" reading from one of those two sensors.
1st question I would ask: Is it actually shifting into 4th gear or not? If it is going into 4th gear as it should, then the problem is likely in the sensor circuits. If the computer is commanding it to shift into 4th gear, but the transmission isn't responding, then there's some condition (such as a maladjusted or broken band as suggested by BrooklynBay) in the transmission that is preventing it from responding to the computer's commands.
__________________
Mr. Shorty
92 XLT 4x4
87 Bronco II XLT 4x4
'98 Chev K1500 Suburban SLT 4x4
MrShorty is offline   Reply With Quote
Old 07-03-2007, 04:56 PM   #4
bren7176
Downsville Ny
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Fixed I hope
Well I adjusted the OD band today and took off all the sensor connectors and cleaned them and put back on took the EX for test drive. AS of right now no more flashing OD light one of the 2 thing may have fixed hopefully . Thanks for the feedback and suggestions . Seems to be shifting just fine..
thanks
Brendan
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
