Ford Explorer Sport Trac Ford Ranger Mazda Navajo Mercury Mountaineer, Ford Aerostar Message Board®
Ford Explorer, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Ford Aerostar SUV Enthusiast Forums
Join the "Elite Explorers Today!"
Explorer4x4 Sportrucks EF Arcade Forums Elite Membership Product Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Repair - Tech - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer > Modified 1995-2001 Explorers
Notices
Modified 1995-2001 Explorers Questions related to modified 1995-2001 Explorer, Mountaineer, Ranger and 2002+ Sports (2dr).
Reply
Thread Tools
Old 07-07-2007, 10:22 AM   #1
Aussie XLT
Melbourne, Victoria
1999 Explorer XLT (Black)
Vehicle Specs
Please Help: Where can I find the pulse wire/tacho wire?
Hi all,
Just completed a LPG conversion on my 1999 Ford Explorer XLT 4.0 SOHC but I can't find anywhere to tap a pulse wire (tacho pulse) from for the gas safety switch. We've tried wrapping a wire around the lead/s, tried going from the coil pack and still having no luck.
I thought there might have been that white diagnostic plug in the engine bay like Aussie Falcons but as yet I haven't been able to find one.
Any ideas?
__________________
1999 Explorer XLT 4.0 SOHC V6 - currently stock but with your help maybe we can fix that
Aussie XLT is offline   Reply With Quote
Sponsored Links (Less Ads)
Old 07-07-2007, 10:53 AM   #2
Turdle
Topless in winter
Humboldt, KS
Turdle's Avatar
1998 Mountaineer MX4 O/R
Vehicle Specs
Could you tap of the synch signal from the camshaft position sensor?
__________________
"I set my standards low, so I am not easily disappointed"
98 MX4 OFF ROADFOR SALE
93 with sky light
Explorerforum license frames here
Turdle is online now   Reply With Quote
Old 07-07-2007, 11:45 AM   #3
wood1
Iqaluit
'93 XLT
Vehicle Specs
I have used a fuel injector wire to supply automatic car starters with a tach signal. They need to be programmed to recognize the frequency of the pulse at idle though. I'm not familiar with the LPG conversion so I don't know if this will help you or not...
wood1 is offline   Reply With Quote
Old 07-07-2007, 07:26 PM   #4
Aussie XLT
Melbourne, Victoria
Vehicle Specs
Thanks guys, jtsmith I'm not sure to be honest but even if we can I'd need to know what colour wire I'm looking for and unfortunately I dont have a workshop manual. We've had a go at the crank angle sensor but again no luck.
wood1 we tried to tap from an injector but that didn't work not sure why.
Any more ides? Anyone?
__________________
Old 07-07-2007, 08:00 PM   #5
rwenzing
Michigan
rwenzing's Avatar
2003 Ranger FX4 LII 5.0
Vehicle Specs
On US-spec Explorers, the factory wire from the PCM to the tach is tan/yellow. You can find it at pin 48 of the PCM, at the 42-pin main engine connector or behind the instrument cluster.
__________________
Bob
2003 Ranger FX4 Level II, 5.0L V8, 4R70W, BW4406 T/C, Aussie Locker front, Torsen rear
Torque Monsters, Magnaflow, duals; Explorer EATC, steering wheel controls, consoles
Bilstein 7100 reservoir shocks, Cadillac/Mustang SVO rear discs, Duff traction bars
CarDomain
Ford owners' manuals ONLINE, then click on "Glovebox"
rwenzing is online now   Reply With Quote
Old 07-07-2007, 08:02 PM   #6
Turdle
Topless in winter
Humboldt, KS
Turdle's Avatar
Vehicle Specs
Pin 85 on th PCM plug--Should be Dark blue with an orange stripe.
This is the Camshaft position sensor signal wire--
I'll try to find the actual tach drive signal--give me a minute
__________________
93 with sky light
Old 07-07-2007, 08:06 PM   #7
Aussie XLT
Melbourne, Victoria
Vehicle Specs
Thanks guys!!!
I was hoping to find a wire in the engine bay to use but I guess I'll take what ever I can get.
__________________
Old 07-07-2007, 08:09 PM   #8
Turdle
Topless in winter
Humboldt, KS
Turdle's Avatar
Vehicle Specs
Quote:
Originally Posted by Aussie XLT View Post
Thanks guys!!!
You will find this in the engine bay--
oh wait--you have right hand drive yes?
where is the main PCM plug? Ours is on the passenger side firewall
__________________
93 with sky light
Old 07-07-2007, 08:12 PM   #9
Aussie XLT
Melbourne, Victoria
Vehicle Specs
rwenzing am I right in saying I can find tan/yellow wire on the big square engine loom connector on the top of the engine/rocker cover?
__________________
Old 07-07-2007, 08:13 PM   #10
Aussie XLT
Melbourne, Victoria
Vehicle Specs
Im not sure jtsmith
__________________
Old 07-07-2007, 08:21 PM   #11
Aussie XLT
Melbourne, Victoria
Vehicle Specs
jtsmith just had a look at the Explorer and as far as the engine bay goes the easiest place for me to get to wiring is that massive black square engine loom plug that sits on top of the engine/rocker cover (U.S. drivers side)
__________________
Old 07-07-2007, 11:12 PM   #12
wood1
Iqaluit
'93 XLT
Vehicle Specs
Hmmm, if you already tried the tach signal from the coil pack, and you had the correct wire, (it should be a tan/yellow at the coil pack and I would probe it with a logic probe and insure it pulses at idle) maybe a tach signal generator?
I have literature that says that that the wire at pin 48 of the 104 pin connector at the ECM that is a White/Pink or White/LtGreen is a tach signal. I know that Bob has this wire as being tan/yellow and he may be right. I haven't had to go to the ECM for a tach signal on an Explorer.
Sorry I couldn't help more...
Chris.
Old 07-08-2007, 02:16 AM   #13
Aussie XLT
Melbourne, Victoria
Vehicle Specs
Could the tacho pulse be digital? maybe that's the issue, maybe my safety switch doesn't recognise it
__________________
Old 07-08-2007, 10:39 AM   #14
rwenzing
Michigan
rwenzing's Avatar
Vehicle Specs
That is the 42-pin connector that I referred to and it should be there. The tach wire is shown as being tan/yellow in the 1999 Explorer Ford Wiring Manual (North American).
The tach signal is generated by the PCM solely for the tachometer and trip computer, so it is likely to be digital. It has nothing to do with the coil pack which has its own independent ground triggers from the PCM.
__________________
Bob
CarDomain
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
Copyright 2010 - 1996 Rick Horwitz Photography
