Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer Audio & Navigation
Notices
Explorer Audio & Navigation Audio and navigation systems. CD, DVD, MP3, GPS, Video, Mobile Computer, Speakers, Amplifiers.
2002-2005 (02-05) Explorer rear door panel removal for speaker access HOW-TO
Reply
Thread Tools
Old 07-29-2007, 03:07 PM   #1
GregV8
Long Island, NY
2011 XLT
Vehicle Specs
(Original Poster)
I had to remove my rear right speaker and searched all over this forum. I found the approximate info I needed to do it but there were no pictures or step by step instructions yet.
So I figured if I do it I post my findings up here, I'm sure one day it will help someone.
Don't have rights to upload to this forum so used imageshack... not sure how long the files will stay up there... maybe an admin could copy them over here
THIS INFO IS FOR REAR SPEAKERS BUT FRONT ONES ARE VERY SIMILAR.
1. Remove window controller and plastic piece behind door handle
2. Remove screw in the middle, behind door handle encased in white plastic.
3. Remove screw from bottom of panel and lift the whole thing.
Speaker model number: XW7F-18808-BB
Only 25 W?! wow..
Greg
GregV8 is offline   Reply With Quote
Old 08-10-2007, 01:03 AM   #2
Rammer24
Regina, Saskatchewan,Canada
2005 XLT
Vehicle Specs
What size door speakers are in the explorers? I have a 05
Rammer24 is offline   Reply With Quote
Old 08-10-2007, 01:15 AM   #3
trucku
Queens, New York and living in Budd Lake, NJ now.
trucku's Avatar
2002 Explorer XLS 4.0 4x4
Vehicle Specs
Nice text bubbles.
I thought you had to pop the leading edge of the panel behind the handle first , because it has a clip that will keep the controller from being lifted out.
Nice job
__________________
2002 XLS 4.0 SOHC 4x4. Frantz Bypass filter, Mobil 1 5W30.Perma-cool dual remote (2 full flow PureOne PL30001). Perma-cool remote transmission filter (Pure One PL30001). Scanguage II, Sunpro Oil Pressure Guage
Gen 4 mirrors
"The More Complex The Mind, The Greater The Need For The Simplicity Of Play"
trucku is offline   Reply With Quote
Old 08-10-2007, 01:12 PM   #4
jluv
DFW, TX
'04 XLS
Vehicle Specs
Quote:
Originally Posted by trucku View Post
Nice text bubbles.
Nice job
Not a clip really, but it does have to come out first.
jluv is offline   Reply With Quote
Old 12-16-2007, 04:22 PM   #5
Donner
Natomas/Irvine
01 Sp 03 XLT 4x4s, Scion
Vehicle Specs
Thumbs up Alright!
Just did this, didn't think I could... Anyways, just to add, in the handle area there is a 5.5 mm bolt, same as the bolt at the bottom of the door - used a socket wrench. The speakers used a 1/4 socket wrench to undo.
The question is, if one rear speaker goes bad, do they both need replacing? Are they sold in sets only?
__________________
http://www.explorerforum.com/forums/...d.php?t=240001 For Sale stuff
Donner is offline   Reply With Quote
Old 12-16-2007, 04:31 PM   #6
GregV8
Long Island, NY
2011 XLT
Vehicle Specs
(Original Poster)
Quote:
Don't know if you can buy the original per piece but I just went with an aftermarket brand (Crunch) in which case you have to replace both in order to maintain the balance.
Old 12-16-2007, 04:38 PM   #7
Donner
Natomas/Irvine
Vehicle Specs
Cool Nice!
Thanks! These are aftermarkets, the papers went long agooo... Your instructions made that as easy as pie to remove the all of those parts. Thank you! I'll get another pair, taking the door off was a breeze! So I'll just pop in the other side too... Thanks again!
__________________
Old 12-16-2007, 05:01 PM   #8
Rick500
'02 XLT 4WD
Vehicle Specs
I just put new speakers in all around on my '02 Explorer. The front door panels come off the same way as described here. There are two screws at the bottom of the panel on the front doors.
Rick500 is offline   Reply With Quote
Old 12-16-2007, 05:09 PM   #9
Donner
Natomas/Irvine
Vehicle Specs
That's it...
6x9 all around? So technically the fronts could be switched to the rears, and a better set for up front?
__________________
Old 12-16-2007, 05:44 PM   #10
Rick500
'02 XLT 4WD
Vehicle Specs
Yeah, all four speakers are identical.
Old 12-16-2007, 06:59 PM   #11
Donner
Natomas/Irvine
Vehicle Specs
Thumbs up Thanks!
4 noobs all around! 6x8s Pics of the front door to follow!
__________________
Old 12-17-2007, 12:57 AM   #12
Donner
Natomas/Irvine
Vehicle Specs
Here's what can go wrong if you don't do it like Greg shows...
1. I broke the part that goes over the lock while trying to reassemble.
2. Don't try this unless you are capable, I thought I was
These are the new rears... Thanks for the directions Greg! It went smoothly until I forgot about having patience...
__________________
Old 12-17-2007, 01:00 AM   #13
Donner
Natomas/Irvine
Vehicle Specs
These are the old rears...
1. Does anyone know what that crud is around the speaker? It was only on the right side rear...
__________________
Old 12-17-2007, 06:23 PM   #14
Donner
Natomas/Irvine
Vehicle Specs
Cool Thank you!
Quote:
I'm going to try to do the front install today... You're right, it's best to have all new at one time - the front two sound pretty muffled compared to the rear two.
__________________
Old 12-17-2007, 06:34 PM   #15
Rick500
'02 XLT 4WD
Vehicle Specs
The new speakers are great, but they put the factory deck to shame... I think I need a new deck now. :P
Old 12-20-2008, 07:49 AM   #16
imalik
New Jersey
04 Explorer
Vehicle Specs
Thanks for pics, changed my front speakers went very smooth
imalik is offline   Reply With Quote
Old 12-20-2008, 12:18 PM   #17
JohnnyBoy1102
Baltimore, MD
98 Sport
Vehicle Specs
This can be a very easy task if you are patient. try not to break the clips that hold the panel on the door. just dont force anything where its not supposed to go and you should be fine. and yes most explorers have 6 X 8 speakers all around. mine does i know that much.
__________________
98 Explorer Sport, 2 Door 4 X 4. - 2 12 inch MTX magnum Subwoofers (cheap temps)- 1000 Watt MTX magnum Amp ( Again, Cheap temp)- 120 Watt 6 X 8 Rockford Fosgate Punch 3 Way Speakers - Kenwood MP538U Single Din Head unit with USB/ Ipod Interface.- Possible mod coming soon, 2 Memphis Audio 12 Inch Subs. depending on money and time. - All Black Custom headliner- other than that mostly stock.
JohnnyBoy1102 is offline   Reply With Quote
Old 12-20-2008, 06:33 PM   #18
BigAlain
New-Brunswick
2005 Limited
Vehicle Specs
CAN
Thanks for this post. I replaced the back door speakers tonight following these instructions. Only broke one clamp on the switch housing. You gotta slide it towards the front of the vehicle once you pop out the clamp. Otherwise, went smoothly. The housing still holds on fine, so it`s no big deal.
Didn`t go to expensive on the speakers, Ultimate T2-6821 6x8 two way. Very pleased with the sound, and they fit just right.
http://www.ultimate-sound.com/car.html
BigAlain is offline   Reply With Quote
Old 12-20-2008, 09:08 PM   #19
dannyb420
Cleveland, Ohio
'04 XLT
Vehicle Specs
great post, I had to remove my front panel last winter to replace my window controls and could have used this diagram. Its really not that hard but as mentioned take your time with any interior trim so you dont break tabs
__________________
2009 Mercedes C300 Sport 4Matic,1999 Four Winns 298 Vista Twin Volvo 350's
SOLD'04 XLT Tinted windows, 10" Infinity Basslink, custom Sirius satellite mount,K&N Filters throughout,Sylvania Silverstar, eadlights,Fogs,signals w/ clear corners, LED puddle lights, license plate lights, and interior 265/70/16 Bridgestone Dueler REVO,F150 Recovery Hooks
dannyb420 is offline   Reply With Quote
Old 02-01-2009, 05:11 PM   #20
jeremyc653
st pete fl
2001 ford sport trac
Vehicle Specs
just to let everyone know u can eas;y use ten snips and cut the door a little to fit 6x9 if u want the bigger speaker
jeremyc653 is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
