Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Bronco II > Bronco II
Notices
Bronco II Our Ford Bronco II forum covers maintenance, problem solving, 4x4 issues, and all topics regarding the 1984 - 1990 Ford Bronco II.
Some General Questions
Reply
Thread Tools
Old 08-07-2007, 03:45 PM   #1
broncobilly1989
Santee, CA
'89 Bronco II
Vehicle Specs
(Original Poster)
I'm new to the Bronco II world. I'm new to the 4x4 world too for that matter. I have a couple of questions...
My 1989 Bronco II would have what for running gear, Dana 28 or 35?
I'm positive that the thing is stock.
I'm looking at the James Duff 6" lift for it. I'm going to go with General Grabber 33x12.5x15's for tires. For fender rubbing I am looking at the Prerunner style fiberglass from Mcniell offroad.
What should I use for lockers?
Again I'm new to this world, spent most of my time in the atv/dirtbike world.
Any help is greatly appreciated.
broncobilly1989 is offline   Reply With Quote
Old 08-07-2007, 09:23 PM   #2
SBJ420
Windsor NS
95 XLT
Vehicle Specs
most come with Dana 28 and a 7.5 rear and you will want to change out. If u do have a D25 you will want to get rid of that quick if you are gonna run 33's and up
A D35 is a some what easy swap and cheap, Just bolts right uo. I had to get my Drive Shaft shortened 1.5"
you can find a 8.8 and D35 under any explorer from 91-94 fer sure
If you do swap a 8.8 in from a ex it will or should have a limited Slip "locker" It is locked for the most part, it will "break" under high pressure. Not like break but will slip.
Much better if you are going to be using this to work everyday, with a locker your rear axle will be hard, not so good on pavement
If you got the $$$$ get a Air Locker, can lock and unlock it from inside the truck
I dont have much experience with lockers tho.
Does it have a 2.9L or a 4.0L?
__________________
Rectum, Damn Near Killed Em!
1994 XLT
SBJ420 is offline   Reply With Quote
Old 08-07-2007, 09:56 PM   #3
broncobilly1989
Santee, CA
'89 Bronco II
Vehicle Specs
(Original Poster)
Some Genereal Questions
It has a 2.9L.
Old 08-07-2007, 11:15 PM   #4
SBJ420
Windsor NS
95 XLT
Vehicle Specs
than I think that makes it more possible it will be a D28
__________________
1994 XLT
Old 08-07-2007, 11:49 PM   #5
4x4junkie
So.Calif.(San Fernando Valley)
'94 Ranger, '90 Bronco II
Vehicle Specs
SBJ420 pretty much covered the basics of the D35 swap.
I definitely would 2nd swapping to the Explorer axles if you want to run 33s.
If you get the 8.8" rear from a '95-'01 model, you'll get rear disc brakes in the process. The front has to come from a '91-'94 in any case though. You can also look in '91-'97 4.0L V6 Rangers for the D35 too. '95-'97 models will have dual-piston brake calipers.
I think ARB Air Lockers are well worth having (especially in the front axle, where a fully locked diff can make steering a bit more difficult). Having the air source on hand makes reinflating tires easy when you're out in the woods, too.
You'll also want to regear the axle to 4.56 or 4.88 so the 2.9L engine runs at it's best with the 33" tires (I would recommend the 4.88)
Welcome to the BII world
__________________
'90 Bronco II XLT
5" lift (Skyjacker jeep coils), locked D35 & 8.8", 5.13s, double T-case, 35x12.50s & cut fenders
'94 Ranger XLT
6" Skyjacker, ARB D44 front, Detroit 8.8" rear, Atlas 4.3, 33s
4x4junkie is offline   Reply With Quote
Old 08-08-2007, 08:23 AM   #6
fischerry
THE SOUTH
92 x'sploda
Vehicle Specs
i run just fine on my 33's and with 3.73's.would like to swap for some 4.10's but untill i blow the gear's out i see no need to change.
__________________
TRIK
Southern RockCrawlers
http://s134.photobucket.com/albums/q94/fischerry/
"2nd place,is just the first loser"
88 bII on d35s,8.8 4.0 the good ol' 4.56's. sittin fat on 35" pc at's
fischerry is offline   Reply With Quote
Old 08-08-2007, 04:37 PM   #7
broncobilly1989
Santee, CA
'89 Bronco II
Vehicle Specs
(Original Poster)
Well, Now i know where I can blow most of my earnings from deployments! Thanks for the info guys.
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
