Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
Torque Converter Clutch (TCC) Solenoid test
Reply
Thread Tools
Old 08-08-2007, 07:11 PM   #1
flyinpaw
Cincinnati, OH
94 XLT 4x4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I have a 94 XLT 4x4 with 186,000 miles. It has the original A4LD transmission. The only tranny maintenance is fluid and filter changes at 76k and 167k that I did and a flush/fill and filter change by local garage at 184k. Before the last flush/fill and for the last 8 months the TCC lockup has been intermittent, locking up about 90% of the time. At times it won't lock up when all the conditions for lock up seem to be met. Sometimes it locks up normally and just cruising down a level road at 55 it will unlock for no apparent reason. It also will not lock up sometimes when it should and 5 minutes later, still cruising about 55, it will. I checked for EEC codes, both KOEO and KOER a while back and had none. I will check for codes again tomorrow. The truck also pings under load such as accelerating up a steep hill, not sure if this is related in any way.
I have the ATSG manual for troubleshooting. The first step I plan for diagnosing the problem is check the TCC solenoid while driving. From reading the info in the ATSG manual it seems that the solenoid is normally powered, ie 12v flowing thru the solenoid to the PCM to ground. This allows the TCC to operate with hydraulic pressure from the transmission regulator system. If one of the TCC inhibit modes is sensed by PCM it removes the ground from the TCC solenoid and without power the TCC solenoid ports hydraulic pressure to unlock or prevent lockup of the TCC. Most of the inhibit modes are from sensors in the engine compartment. If one of these sensors is sending a bad signal intermittently to the PCM this could cause the TCC problem. I would much rather change a $25 sensor than a $1200 transmission.
The Chilton's manual wiring diagram has a purple/yellow wire running from the TCC solenoid to the PCM. I've located this wire at both ends and hope/pray that it's the correct circuit. My plan is to cut this wire that completes the circuit from the TCC solenoid to the PCM and splice in my multimeter. When the PCM is not sensing one of the inhibit modes I should see 12v on the multimeter. If the PCM is sensing an inhibit mode then I should see 0v. I hope that this will allow me confirm or eliminate the TCC solenoid as the source of my problem. If the solenoid is causing the intermittent problem then I just have to find the sensor providing the faulty signal.
Can anyone see any problems with my plan? I sure don't want to fry my PCM.
flyinpaw is offline   Reply With Quote
( Join the Elite Explorers )
Old 08-09-2007, 05:52 PM   #2
Maniak
Moderator-Stock 91-94
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
Quoted: 219 Post(s)
thats pretty much how I did it.. only I just stripped some insulation off the wires and use aligator clips to tap the wires.. I was hooked up across the common power (goes to the TCC and 3/4 solenoid) and the ground side (PCM side) of the solenoid I wanted to test.
When the computer grounded the solenoid I saw 12v.. when it wasn't grounded I saw 0v.
~Mark
__________________
Click HERE to see our Explorer Specs
Maniak is offline   Reply With Quote
Old 08-09-2007, 08:24 PM   #3
flyinpaw
Cincinnati, OH
94 XLT 4x4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks for your input Maniak. I'm going to have to wait till the weekend to hook it all up; need the truck to move my daughter back to college. I checked the EEC codes today: KOEO was 111 / pass, CM was 186 / injector pulse width higher than expected or MAF sensor signal voltage lower than expected, KOER was 111 / pass. I'll post more next week after more analysis.
Old 08-09-2007, 08:49 PM   #4
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 427 Post(s)
You could test the solenoid directly from the wiring harness (3 prong connector) on the driver's side of the transmission. You wouldn't have to splice any wires if you unplug it, and test it from there.
BrooklynBay is offline   Reply With Quote
Old 08-10-2007, 08:36 AM   #5
flyinpaw
Cincinnati, OH
94 XLT 4x4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Brooklyn,
Since it's an intermittent problem I want to test it while driving over a couple of days. I don't think it would be a great idea to run the wires under the truck and into the interior. Also, if I have the harness unplugged then I don't think I will get the 3/4 shift or TCC lockup, or do I completely misunderstand the system?
Old 08-10-2007, 08:55 AM   #6
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 427 Post(s)
You are correct about not having overdrive or converter lock up if the connector is unplugged.
Old 08-10-2007, 10:05 AM   #7
Maniak
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
Quoted: 219 Post(s)
I did my test with wires running into the cab. I wanted to know if the problem was the PCM not letting the trans go into OD or if there was some internal transmission failure.
The first time I did the test my solenoid was bad.. The 2nd time I did it (a few years later) the PCM told the solenoid to release and the solenoid seemed ok (has the correct impedence) but the trans wouldn't go into OD. I then knew I had an internal problem on the transmission.
~Mark
__________________
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
