EF Swag Store 2013 Ford Explorer Forums Elite Membership Chat Room My Posts Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Offroad Tech Forums > Offroad Explorer - Ranger Projects > Explorer - Ranger Shocks, Suspensions, Lift Kits
Notices
Explorer - Ranger Shocks, Suspensions, Lift Kits Ford Explorer and Ranger chassis related posts. Get help choosing the right shock absorber and aftermarket suspension for your Explorer or Ranger based vehicle.
Tired Leaf Springs
Reply
Thread Tools
Old 09-25-2007, 04:06 PM   #141
MountaineerGreen
Towing Moderator
North East Arkansas
MountaineerGreen's Avatar
2012 F150 4x4
Vehicle Specs
(Original Poster)
I really thought about a SAS, but, I don't have the time or energy or money to do it. Plus, I'd want a narrowed front axle with the same bolt pattern so I could keep my wheels and tires. Not practical at this point since this is my DD.
I did flex it out today and wow. I can drop a tire ~16" without even affecting the rest of the truck. Flex is greatly improved with SOA.
A monoleaf is out regardless, my spring plates are for 2.5" wide springs, my understanding is monoleafs are 3" wide. I was almost willing to try it before I figured that out.
I wonder if some Heep springs would bolt in? I can probably source some if I knew they would work.
I'd really like to get the rear down, and let my T bars out- this sucks.
MountaineerGreen is offline   Reply With Quote
Old 09-25-2007, 04:51 PM   #142
jobunn
Canyon Country, CA
jobunn's Avatar
'99 Sport 4x4
Vehicle Specs
How about the leaf pack from the late model sports, 2001 and up I think? Ford went to a thin 2 or 3 leaf system with overload...not sure if axle wrap would become a problem or not with that setup.
__________________
Joe Bunning
4" Superlift and 1" TT front - 4" Superlift leaf springs rear - 33x12.5 BFG AT's - 4.10 regear - NoSlip lockers - ECU flasher - BW1354 manual tcaseWheelin' Pics
jobunn is offline   Reply With Quote
Old 09-25-2007, 04:53 PM   #143
Hokie
Hokius Maximus
Denver, CO
Hokie's Avatar
'04 Jeep Grand Cherokee
Vehicle Specs
Quote:
You know, I used to argue round and round about how going SOA increases your flex. Glad to hear someone agree with me
I'm running a 3" wide mono-leaf with a 2.5" wide support leaf and 2.5" wide overload leaf : no problems (I think the spring plates on a Sport/4 Door are the same width regardless of which spring width it gets)
__________________
Brett
I get payed to sell and play with Cummins engines
My old '98 MTNR - 5.0 V8 4x4 My old '99 Sport
Hokie is offline   Reply With Quote
Old 09-25-2007, 08:24 PM   #144
MountaineerGreen
Towing Moderator
North East Arkansas
2012 F150 4x4
Vehicle Specs
(Original Poster)
I found a solution I think- Heep XJ rear leaf springs. They are thinner than my stock ones, a tad shorter, and have more leafs. Under load, they are flatter than my stockers. I got them for free, but they are on a rust bucket XJ, a real PITA to remove. I worked on it for 3 hours today, I will go back tomorrow with a sawzall to finish getting it out.
Old 09-25-2007, 08:33 PM   #145
MountaineerGreen
Towing Moderator
North East Arkansas
2012 F150 4x4
Vehicle Specs
(Original Poster)
Oh yeah, my massive a$$ u bolts and spring plates are drilled for 2.5" leaf springs, there is less than 1/4" on each side of the springs between the u bolts.
I seriously doubt the XJ springs will bolt right in and the center pin be in the right place, so I will most likely swap all but the main leaf. I hope this will get me down to a more reasonable height. If they happen to bolt in, I will do just that.
I really hope this works, its a ton of work to remove those old springs and use the shop to change my springs out.
Old 09-26-2007, 09:08 PM   #146
MountaineerGreen
Towing Moderator
North East Arkansas
2012 F150 4x4
Vehicle Specs
(Original Poster)
Well..... got 1/2 way there today. I got the leaf springs out with a sawzall today, removed my factory leaf pack, put all of the XJ leafs except for the main leaf under my main. When I first let it down, it was perfect. Now it has settled out to slightly lower than it was before But, I am going to swap in my factory second leaf for the XJ second leaf and see if its a little better. The leafs are actually completely dearched at this point, so the thicker factory leaf is needed. The benifit is the XJ's overload is not as thick and completely flat, and the third leaf is flatter. I think my factory two leafs plus the XJ third leaf and overload will be the right combo. This way I get flex without excessive height.
Old 09-26-2007, 09:12 PM   #147
Hokie
Hokius Maximus
Denver, CO
Hokie's Avatar
Vehicle Specs
Ha! A Franken-leafpack
__________________
Brett
Old 09-26-2007, 09:17 PM   #148
MountaineerGreen
Towing Moderator
North East Arkansas
2012 F150 4x4
Vehicle Specs
(Original Poster)
I am so tired of tearing my rear suspension apart- tomorrow will be 3 times in one week.
I also had to cut off my tailpipe It ran out between my leaf springs and frame on the passenger side, when I first let my truck down, it was resting on the exhaust.
And, one of the big honkin u bolts fubar'ed on me today, that took an extra hour. I cut the extra length off the bolts with sawzall, they are grade 8, hard to cut. Apparently when I ran the nuts back off, it didn't "fix" the end of the bolt, that nut was not going back on without a fight. All the other bolts worked fine. I ended up using a cheater bar, then finally stripped it all the way out. The other side of the same bolt is fine, as well as the inboard u bolt, so its OK for a day or two. Tomorrow I am getting new center pins and a new u bolt for my 3rd attempt.
Old 09-28-2007, 10:27 PM   #149
MountaineerGreen
Towing Moderator
North East Arkansas
2012 F150 4x4
Vehicle Specs
(Original Poster)
OK, third attempt done. The height is about right- no pictures yet though. I do have a problem with it. Spring wrap. The lack of a "real" overload spring causes spring wrap and a bit of a course shudder at highway speed.
I am now thinking of getting custom lift springs and going back SUA.
Old 09-28-2007, 10:39 PM   #150
Hokie
Hokius Maximus
Denver, CO
Hokie's Avatar
Vehicle Specs
__________________
Brett
Old 10-01-2007, 05:56 PM   #151
MountaineerGreen
Towing Moderator
North East Arkansas
2012 F150 4x4
Vehicle Specs
(Original Poster)
Here are the pictures of what I have now. The height is about right, maybe a little high, but now the leaf springs are nearly flat. My pinion angle is wrong, not too bad, but there is a slight vibration. As you can see the springs are nearly flat. It rides like crap, but flexes good.
I have contacted custom suspension about some leaf springs, no response yet. I guess I will have to call them. I don't know what to think about a company that doesn't answer emails though
Old 10-01-2007, 06:02 PM   #152
mounty71
It's green, not gray.
San Francisco, CA
mounty71's Avatar
'00 Mountaineer
Vehicle Specs
I didnt think of this until just now, and i dont know if you'd even want to go this route, but how about putting back on the original explorer springs like you had right after you did SOA, and leveling it out with a 2" or 3" body lift in the front and transitioning to no body lift in the rear? I know a few people on here have done this to match an SOA.
__________________
MATT SCHWARTZ
2000 MOUNTAINEERINATOR REGISTRY
1991 FORD EXPLORER (IN EXPLORER HEAVEN) REGISTRY
mounty71 is offline   Reply With Quote
Old 10-01-2007, 06:06 PM   #153
MountaineerGreen
Towing Moderator
North East Arkansas
2012 F150 4x4
Vehicle Specs
(Original Poster)
Well, I thought about that, but then I'd want 35's, 4.56's, plus my headers would cause issues with the steering shaft. That and my hitch comes through the bumper, and Hokie discovered that factory fog lights don't work with a BL. A whole host of problems created by more lift. Before I do all that, I'll just SAS.
Old 10-01-2007, 07:28 PM   #154
Hokie
Hokius Maximus
Denver, CO
Hokie's Avatar
Vehicle Specs
Well, it wasn't thaaat big of a deal. More of a headache b/c I didn't know I was going to have to take them off. Yeah, I had to loose the factory fogs, but I've got some ProComp 5" lights there now that probably put out more light than the stocker's did.
__________________
Brett
Old 10-01-2007, 07:32 PM   #155
MountaineerGreen
Towing Moderator
North East Arkansas
2012 F150 4x4
Vehicle Specs
(Original Poster)
Yeah, but I really like my factory fog lights.
Still no reply from customsuspension.com, I have sent them two emails
Old 10-01-2007, 09:00 PM   #156
Hokie
Hokius Maximus
Denver, CO
Hokie's Avatar
Vehicle Specs
Do they have a phone number listed? As a general rule, I call first, email 2nd. That way, in the email, you can say "This serves as a follow up to the voice message I just left."
__________________
Brett
Old 10-01-2007, 09:32 PM   #157
MountaineerGreen
Towing Moderator
North East Arkansas
2012 F150 4x4
Vehicle Specs
(Original Poster)
I guess I'll call them- Either that or go back to stiff arse leaf pack and shackles.
$500 or teeth rattling ride?
Old 10-04-2007, 07:39 PM   #158
MountaineerGreen
Towing Moderator
North East Arkansas
2012 F150 4x4
Vehicle Specs
(Original Poster)
Ok back again. Its back to SUA, this time I shuffled some leaf springs around, it seems to be a little less stiff. I let the torsion bars out, even lower than before, so the back doesn't look so high. What I'd really like is sightly larger front fender openings so I can run 33's with no rubbing and not any higher. I'd like to do a Sport Trac front clip conversion one of these days.
I'll try to snap a picture tomorrow.
Great, all this work and expense and I am back where I started
Old 10-04-2007, 08:14 PM   #159
MountaineerGreen
Towing Moderator
North East Arkansas
2012 F150 4x4
Vehicle Specs
(Original Poster)
But, I do have those spring perches on top of my axle still, which gave me an idea. What about coil springs, soft rate of course, and my stock leaf pack? Would that work? Or am I crazy?
Old 10-04-2007, 08:16 PM   #160
Hokie
Hokius Maximus
Denver, CO
Hokie's Avatar
Vehicle Specs
I'd be similar to air ride springs
__________________
Brett
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
