Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
How To Check And Replace Inner Tie-Rod (pictures & video)
Reply
Thread Tools
Old 09-03-2007, 06:18 PM   #1
Texplorer
Morgantown, WV
Texplorer's Avatar
96 XLT 4x4 4.0
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Well I had a loose tie-rod that I had to replace so I figured I would do a little write-up on it with pictures to hopefully help someone else down the line. I try and remember all the little tricks I used to make it easier.
First off this is a little vid of how you can tell if your inner tie-rod is loose. Grab it and try to wiggle it, if it moves as much as mine does then you need to replace it. (click on picture to play video):
This is what the suspension looks like before starting:
Remove the cotter pin and unscrew the castle nut on the outer tie-rod:
Outer tie-rod unbolted:
Now comes a little trick to make removing the tie-rod easier, unbolt the sway bar from both sides and rotate it up. It gives more room to work with:
Remove outer clamp with some pliers:
Then remove inner clamp with a long skinny flathead screwdriver, sorry I didnt get a pic of it. I needed both hands at this point.
Pull boot back and this is what you should see:
Use a pipe wrench to remove the tie-rod from the steering rack:
This is what it looks like when removed:
Then unscrew the outer tie-rod from the inner:
Outer tie-rod and inner tie-rod separated:
After that just reverse the steps and your done!! Now get in your rig and drive straight to the alignment shop because you will need one, every time you mess with any suspension/steering components you need to get an alignment. Good luck and enjoy saving yourself over $300 doing it yourself.
__________________
2005 F-150 SuperCrew 4x4 5.4L on 33" Nitto TG's
1996 XLT Lifted on 33's SOLD
1996 Limited Stock SOLD
2008 Jeep Grand Cherokee Rocky Mountain Edition
Texplorer is offline   Reply With Quote
( Join the Elite Explorers )
Old 09-03-2007, 07:05 PM   #2
white96x
Rancho Cuc,Ca(home) SLO,Ca(school)
1997 E.B.
Vehicle Specs
Quoted: 0 Post(s)
good write up....however i think i remembering seeing another write up a while back regarding replacing the whole tie rod assembly(outer and inner) and taking note of the distance of the outer tie rod adjustment screw...it needs to be the same distance on the threaded portion of the new inner tie rod as it was on the old..basically you need to have the adjustment nut in the same place before and after...just thought i would add that, i hope it doesn't confuse anyone...but this is a good write up and should either be 'stickied' or placed in the 'how to' forum
__________________
'97 5.0 V-8 2wd, SpinTech, K&N FIPK, Front:Camburg 6.0 with Radflo 2.0x8.5" coilovers, Rear: Deaver's, 33x12.50 BFG AT's, 15x8 Rockcrawlers, 4.56's.
white96x is offline   Reply With Quote
Old 09-03-2007, 07:17 PM   #3
Texplorer
Morgantown, WV
Texplorer's Avatar
96 XLT 4x4 4.0
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Quote:
You are exactly right, I forgot to mention that after you get the whole tie-rod assembly off measure the overall length of the two tie-rods while they are still together. Then when you put the new one on make sure to screw it to the exact length that you measured of the old tie-rod assembly.
__________________
Old 09-03-2007, 08:26 PM   #4
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 411 Post(s)
Good write up! You could add that if you click onto the first picture, it will direct you to the short video clip. An alignment after this is a must. It's almost impossible to maintain the same alignment even if you keep the lock nut in the same place. Send Rick a PM with this link. He might like it.
BrooklynBay is offline   Reply With Quote
Old 09-04-2007, 06:55 PM   #5
CDW6212R
Knoxville, TN
CDW6212R's Avatar
98 Mountaineer AWD
Vehicle Specs
Quoted: 208 Post(s)
Take both old tie rod sets out, both sides. Use one nut from one old set, or buy new nuts if you like. Lay the old tie rod assembly on the ground(left intact to original length with nut), then assemble the two new tie rods, and lay them next to the old assembly. You can make that length very close to the original for that side visually. I've done that before and had the toe in be almost perfect, but still safer going to the alignment shop.
Do the other side by measuring, and see which is easier or you like better. Regards,
__________________
Don
91 Lincoln LSC/SE/GTC, 99/93 Explorer Limited 4WD, 98 AWD Mounty, 98 Limited with 255/55/18's, big sway bars, and 12.75" x 1.25" rotors.
The best thing that could help us all, is the Fair Tax Plan.
Be American, Buy American (Manufacturer)
CDW6212R is online now   Reply With Quote
Old 09-06-2007, 11:12 AM   #6
Charlie's_93EB
Cat 3 Hurricane Rated
Venice florida
Charlie's_93EB's Avatar
1993 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
Very good, I will PM this to a mod for a sticky..
__________________
1993 Eddie Bauer Member of Ranger roll over posse
Fix your 4x4 herehttp://www.explorerforum.com/forums/...ansfer+rebuild
Charlie's_93EB is offline   Reply With Quote
Old 04-28-2010, 05:50 AM   #7
Krupp
Stevens Point, Wisconsin
2001 Explorer Sport Trac
Vehicle Specs
Quoted: 0 Post(s)
This thread really helped me out yesterday when I did my tie-rod ends. Thank you very much.
Krupp is offline   Reply With Quote
Old 02-20-2011, 10:58 PM   #8
MikeLord
Seabrook, Tx
'00 Sport
Vehicle Specs
Quoted: 0 Post(s)
I have a problem. I was driving through a crowded parking lot, and i hit a comcrete pole with my tire, it bent my rim, poped my tire, and pulled my inner tie rod out of the rack and pinion, the inner tie rod was pulled out of the boot. Can the socket in there be replaced? Any help would be awesome!
-Mike
MikeLord is offline   Reply With Quote
Old 10-13-2011, 08:40 PM   #9
mudbug0426
Allen, Tx
96 XLT V6 OHV 4x4
Vehicle Specs
Quoted: 0 Post(s)
this is really helpful and appreciate the post. i just got back from the alignment shop to get mine done and the tech told me my inner tie rods were shot and the service manager quoted me 235 bucks for labor. now i think ill do it myself, it looks like cake!
__________________
96 Explorer XLT 4x4 4.0 V6, Pacesetter headers, Magnaflow high flow cats, Magnaflow dual exhaust, custom intake, Cragar soft 8s, KYB shocks, 265/70/15 BFG Rugged Terrains
My 96 Explorer
mudbug0426 is offline   Reply With Quote
Old 10-22-2012, 08:03 AM   #10
WatchThis!!
Colorado Springs, CO
01 ST
Vehicle Specs
Quoted: 2 Post(s)
Today a mechanic told told me that the inner tie rod in the right side had "backlash" and needs to be replaced. What the hell is "backlash"? Is it even a real term, I mean this guy is German and speaking better broken English than most but still...parts/ labor total about 260(euro not dollars) so I want to be sure.
__________________
Character is who you are, reputation is who people think you are. Take care of your character and your reputation will take care of itself.
WatchThis!! is offline   Reply With Quote
Old 10-22-2012, 01:53 PM   #11
CDW6212R
Knoxville, TN
CDW6212R's Avatar
98 Mountaineer AWD
Vehicle Specs
Quoted: 208 Post(s)
I'd guess that he means play in the joint. The tie rods only cost about $20 maybe, not much. It takes a big wrench or crescent wrench to loosen them, but it's not a tough job really.
The alignment has to be redone(the toe), and that labor will take longer than one tie rod.
__________________
Don
Old 10-22-2012, 03:04 PM   #12
koda2000
Georgia
2001 Explorer EB 5.0L
Vehicle Specs
Quoted: 1139 Post(s)
Quote:
-Mike
according to the picture, the "socket" is part of the inner tie rod. that's what's being replaced. so yes.
__________________
I reject your reality & substitute my own...
2001 Explorer Eddie Bauer 5.0L V8 2WD
2000 Mountaineer 5.0L 2WD/2000 Expl XLT 5.0L 2WD
2000 Mountaineer 5.0L V8 AWD, 2001 Expl Sport Trac
2001 Explorer XLT 4.0L SOHC V6 auto 2WD (RIP 5/13)
1997 Explorer Sport 4.0L SOHC V6 auto 2WD
koda2000 is online now   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
