#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
speedometer out / "OD off" light blinking ???
Reply
Thread Tools
Old 09-05-2007, 01:58 PM   #1
77
tucson az
1996 explorer xlt 4dr 4x4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
hi everyone
I was hoping to get a little help.
I think my vehicle speed sensor is bad or broke.
let me start off with:
I own a 1996 Ford Explorer XLT, automatic trans, 4x4, 4.0 liter, 4 door, power door locks/windows, leather interior, with 108k miles.
I was driving home Monday afternoon from the desert and my speedometer went to 0, I was doing about 40 mph. about a mile later the "OD off" light started blinking. I did not notice a change in performance nor did I hear anything. We got home about five minutes later. I pulled into the drive way shut off the engine and then restarted it. the warning light was no longer blinking, I decided to try it and see if the speedometer was still dead. drove about 20 yards down the street and heard some rattling (kind of like when the U-joints go out). I parked and gave the driveshafts the shake test and they felt solid.
a friend said it was probably the speedometer cable that broke and was rattling (made sense to me). I called the Ford dealer to ask how much for a cable, they informed me that it does not have a speedometer cable but rather a vehicle speed sensor (VSS). Money is tight right now so I figured I could live without a speedometer for a while.
after a little research on the web it seems the VSS does a lot more than tell you how fast you are going. I drove to work this morning to try it out and notice the "OD off" light blinking again and now the "check engine" light is on. also it's shifting gears hard. its gonna need some attention.
first off is there a fuse for the VSS? (it can't be that simple can it?)
can I go to Autozone and have them plug in a code reader?
will they be able to tell me if it's the VSS or something else?
if it turns out to be the VSS where is it located? (I assume on the tranny somewhere but can't find anything on the internet or the owner's manual)
how hard is it to replace?
and
would the VSS going bad make a rattling sound? (which is gone by the way)
any help would be great
thanks
77
77 is offline   Reply With Quote
( Join the Elite Explorers )
Old 09-06-2007, 04:01 PM   #2
SRoberts006
Kannapolis, NC
'96 XLT
Vehicle Specs
Quoted: 0 Post(s)
My sister-in-law borrowed my explorer and hit a log in the road, and had the same thing happen. It was the speed control sensor. Located on the transmission somewhere. We were going out of town, so I just took it to the shop. $200 later it was fixed. About 2 hours for them to do it. Hope that helps.
SRoberts006 is offline   Reply With Quote
Old 09-06-2007, 06:04 PM   #3
77
tucson az
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
thanks
I took it to Autozone, they confirmed it was the VSS.
bought the part there $17 and change pulled the old one out after work. realized I need to change the gear that goes on the front of it, not availible at Autozone, made to the dealer before they closed. paid $20 something for the gear then replaced the whole assembly. the two wires had been stripped, and that's most likely what started the problem. It was kind of hard to get to but that's because I'm a big guy. was too bad getting the old one off, but getting the screw started wasa pain, luckily my 10 year old boy has tiny hands and arms and he got started, then I tightened it.
the whole thing took a couple of hours but that's because I had to go to the store then the dealer for the gear.
runs good now.
77
Old 02-08-2015, 10:56 PM   #4
97XLT4ohv
Sunshine, Alaska
1997 Explorer XLT 4.0 OHV
Vehicle Specs
Quoted: 2 Post(s)
Did your transmission have two speed sensors on it? one in front by the bell housing and one in the rear by the extension housing? If so, which did you replace?
97XLT4ohv is offline   Reply With Quote
Old 02-08-2015, 11:01 PM   #5
Flash
Brisbane Australia
1997 Limited
Vehicle Specs
Quoted: 343 Post(s)
Quote:
It's actually on the transfer case.
The 2 speed sensors on the trans are turbine speed sensors.
Flash is offline   Reply With Quote
Old 02-08-2015, 11:06 PM   #6
97XLT4ohv
Sunshine, Alaska
Vehicle Specs
Quoted: 2 Post(s)
I just looked that up on google and found that it is on the Tcase. Thank you. I'll replace mine and see if it cures my issues. Same symptoms as stated above.
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
