Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Elite Explorer 911!
Notices
Elite Explorer 911! 911! is for situations where your truck is currently out of commission and the owner is in a crisis situation. Members will try to answer your questions asap, no time frame is guaranteed. Only Elite Explorers can post new threads in this forum
Removing Broken Easy-Out
Reply
Thread Tools
Old 09-15-2007, 09:57 PM   #1
V8BoatBuilder
Transplanted Bostonian
East Brunswick, NJ
V8BoatBuilder's Avatar
97 Mountaineer V8 4x4
Vehicle Specs
Quoted: 2 Post(s)
(Original Poster)
(Not sure where to post this, there are too many sub-forums these days.... I digress)
I have a 6mm (small) stainless steel bolt sheared flush into an aluminum block. I tired using an easy-out, but the bolt was jammed harder than I thought and the easy-out snapped off 1/16" below the bolt surface.
Any suggestions on how to drill this mess out now? My plan is to heli-coil.
__________________
-Aaron
Off Road: 97' Mountaineer: V8, 4x4, 4.56s, 4" Superlift, SOA, TrXus 33x12.5
Work: 2015 F250, 2010 E250, 2002 E250
His: 2013 VW Passat TDI, Hers: 2010 VW Jetta TDI. Fill it with diesel, please.
Octopus Yachts, LLC Engineered Marine Electrical Systems
V8BoatBuilder is offline   Reply With Quote
( Join the Elite Explorers )
Old 09-15-2007, 11:20 PM   #2
MountaineerGreen
Towing Moderator
North East Arkansas
MountaineerGreen's Avatar
2012 F150 4x4
Vehicle Specs
Quoted: 8 Post(s)
Do you have access to left handed drill bits?
MountaineerGreen is offline   Reply With Quote
Old 09-15-2007, 11:33 PM   #3
IZwack
Moderator Emeritus
Germantown, MD
IZwack's Avatar
1998 Ford Explorer
Vehicle Specs
Quoted: 2 Post(s)
I would try heating the area (careful though, you dont want to melt that aluminum )
__________________
...how'd the moon get there, how'd the moon get there?
IZwack is offline   Reply With Quote
Old 09-15-2007, 11:35 PM   #4
section525
sextion525
Red Bluff, Ca
section525's Avatar
1975 Ford Bronco 4x4
Vehicle Specs
Quoted: 22 Post(s)
Is it cross-threaded?
__________________
Support the Forum
'13 3.5 Explorer
'75 5.0 Bronco
'04 6.0 Super Duty
section525 is offline   Reply With Quote
Old 09-16-2007, 12:47 AM   #5
manaen
Clear Spring, MD
2011 Xterra Pro-4X
Vehicle Specs
Quoted: 3 Post(s)
is there enough clearance to tack weld a rod onto the easy out to at least get it removed?
or take a dremel with a cutting blade and cut a nice slot to fit a screwdriver in and get the easy out removed. then use left handed drill bits to get the bolt.
__________________
Rusty...
2001 Mounty 4x4 4.0 SOHC 4.10's 180K miles
Current Mods: replacement Engine, TT, Shackle, AAL, Tranny Cooler, Exhaust, Transgo, Air shocks, ATF Temp & PSI ga., Ext Tranny Filter, UD Pulley, E-Fan, BW EPC, Custom Bumper, Body Lift
manaen is offline   Reply With Quote
Old 09-16-2007, 08:20 AM   #6
MountaineerGreen
Towing Moderator
North East Arkansas
2012 F150 4x4
Vehicle Specs
Quoted: 8 Post(s)
I've also heard of using freon to freeze a bolt to remove it, not sure how that works though, or the legality of doing so.
Old 09-16-2007, 09:07 AM   #7
V8BoatBuilder
East Brunswick, NJ
Vehicle Specs
Quoted: 2 Post(s)
(Original Poster)
Thanks for the posts, I don't have access to a welder. I've thought of using my propane torch on the area, but it's very close to gaskets/wiring/etc so I'd like to do that as a last resort.
Where would be the best place to purchase left-handed drill bits? Would they even be able to drill out the hardened easy-out?
__________________
-Aaron
Old 09-16-2007, 11:43 AM   #8
ld50
Oh, the money you`ll blow
British Columbia
ld50's Avatar
93 4 dr 4x4 manual XL.
Vehicle Specs
Quoted: 7 Post(s)
This heppened to me once, I used a carbide bit to drill it out, then re-tapped it larger, don`t know if that`s an option?
__________________
Jim from BC - My Mugshot
All My Mods And How I did Them
ld50 is offline   Reply With Quote
Old 09-16-2007, 12:56 PM   #9
V8BoatBuilder
East Brunswick, NJ
Vehicle Specs
Quoted: 2 Post(s)
(Original Poster)
The easy out is smaller than the original stainless bolt, so if a carbide bit would drill it out than that's the answer.
Think HD or Lowes or Autozone would have a carbide bit?
__________________
-Aaron
Old 09-16-2007, 01:52 PM   #10
manaen
Clear Spring, MD
2011 Xterra Pro-4X
Vehicle Specs
Quoted: 3 Post(s)
yeah I think I got a set at HD last time, or maybe it was autozone hmmm...
__________________
Rusty...
Old 10-09-2007, 12:04 AM   #11
Dre
Chicago
Dre's Avatar
94 Limited
Vehicle Specs
Quoted: 4 Post(s)
did you ever get it out? I've got the same problem now since I snapped one of the transmission pan bolts... I drilled it tonight and will try removing the bolt tomorrow... wan to see what my options are...
thanks,
__________________
Yankee Kustoms
My Gallery
Dre is offline   Reply With Quote
Old 10-09-2007, 01:25 AM   #12
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 411 Post(s)
A torque wrench is like insurance in this case. It could help prevent over torquing the bolts in the first place. A thread repair kit might be necessary to use if the housing gets damaged in the process of trying to get the old bolt out.
BrooklynBay is offline   Reply With Quote
Old 10-11-2007, 07:56 AM   #13
gijoecam
Village Idiot
Trenton, MI
98 ExSport, '00 F-150
Vehicle Specs
Quoted: 10 Post(s)
To get out a broken EZ out, use a hammer and a hardened pin punch. The EZ out will chip right out of there.
-Joe
__________________
-98 Explorer Sport, 4.0 SOHC, K&N drop-in, LEMON in progress!
-'00 F-150, mucho mods
"We need to allow Darwinism take it's course and let the idiots weed themselves out of existance." ~ Rick Horwitz
We must believe in free will we have no choice.
~ Isaac Bashevis Singer
I'm not smart, just a resourceful idiot. ~ Me
gijoecam is offline   Reply With Quote
Old 10-11-2007, 08:57 AM   #14
manaen
Clear Spring, MD
2011 Xterra Pro-4X
Vehicle Specs
Quoted: 3 Post(s)
Quote:
-Joe
however in this instance he is hammering against aluminum, I'm not sure that would offer the impact he needs without messing up the part even more.
By now I hope he was able to remove it...
__________________
Rusty...
Old 10-11-2007, 10:46 AM   #15
gijoecam
Village Idiot
Trenton, MI
Vehicle Specs
Quoted: 10 Post(s)
No, he's hammering against the broken EZ-out (which is hard and relatively brittle) which is lodged in a steel bolt. I've used a pin punch to break EZ outs out of a lot of differrent items, including aluminum. They're brittle enough that they tend to fracture pretty easily.
Also, I forgot to mention it the first time around... A left-handed carbide drill won't help... if anything, it'll drive the EZ-out even further into the bolt. He needs a right handed drill to remove the extractor, then a left handed drill (and/or another EZ-out) to remove the bolt.
-Joe
__________________
Old 10-11-2007, 11:06 AM   #16
manaen
Clear Spring, MD
2011 Xterra Pro-4X
Vehicle Specs
Quoted: 3 Post(s)
-Joe
Ahhh... Good point, I forgot about the remainder of the bolt lining the hole around the easy out.
The big question is, did he get it out, and it seems V8boatbuilder has gone AWOL
__________________
Rusty...
Old 10-16-2007, 06:53 PM   #17
V8BoatBuilder
East Brunswick, NJ
Vehicle Specs
Quoted: 2 Post(s)
(Original Poster)
You totally called it. I was away on business travel, and tried again tonight to get the mess out. I started hammering the ez-out down the hole with a small punch, and it was actually working quite well for a while. But, I was a bit over zealous with my hammering and cracked the aluminum ear right of the cylinder head. The bolt's out, but not the way I wanted.
Looks like I'm part shopping now. Anyone have a cylinder head for an 18hp Tohatsu outboard? Be careful out there guys.
__________________
-Aaron
Old 10-16-2007, 07:05 PM   #18
CDW6212R
Knoxville, TN
CDW6212R's Avatar
98 Mountaineer AWD
Vehicle Specs
Quoted: 208 Post(s)
Sorry top hear that, I have a pair of DOHC Cobra heads which UPS dropped, one head has a back corner ear broken off. I'd weld it back on, I will with mine. Try that alumaloy, that rod which melts with a propane torch, and adheres like solder.
Aaron, did you receive my message weeks ago, about your BW4406? I am still browsing for a good mileage TOD shifting version. Where did you look for yours? I haven't found anything with under about 90k on it?
__________________
Don
91 Lincoln LSC/SE/GTC, 99/93 Explorer Limited 4WD, 98 AWD Mounty, 98 Limited with 255/55/18's, big sway bars, and 12.75" x 1.25" rotors.
The best thing that could help us all, is the Fair Tax Plan.
Be American, Buy American (Manufacturer)
CDW6212R is offline   Reply With Quote
Old 10-16-2007, 08:44 PM   #19
V8BoatBuilder
East Brunswick, NJ
Vehicle Specs
Quoted: 2 Post(s)
(Original Poster)
Sorry about the PM Don, I'll send you one now.
__________________
-Aaron
Old 10-17-2007, 10:02 AM   #20
manaen
Clear Spring, MD
2011 Xterra Pro-4X
Vehicle Specs
Quoted: 3 Post(s)
I would take it to a welding shop and have them weld it back on, a good welder can do wonders with aluminum. As long as the part can be cleaned properly.
__________________
Rusty...
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
