Hokie
Hokius Maximus
- December 14, 2002
- Denver, CO
- '98 TJ Sport
Ok guys, I'm getting tired of chasing this noise in my front end so I figured I would ask for help.
I have alot of road noise/grumbling/rumbling coming from my front end. It is a rotational noise, dependant on speed (not engine RPMs). It sounds similar to what I heard when my wheel bearings were going on my '99 Sport.
I can feel the rumbling in the floorboard, it feels "rough" against your heels/feet
- I have replaced the front wheel bearings, they're nice and tight.
- I had a bad pinion bearing on the front end, so I replaced the whole diff with a low mileage (45-50k unit), filled with Valvoline synthetic blend gear oil.
- I have pulled the front driveshaft and the noise continues: leading me to believe its front end related and not t-case or u-joints. The front u-joint is new as it was required for the 4406 swap and the other u-joints are nice and tight (the front Expedition d-shaft only has 55k on it). I was also thinking that maybe the front Expedition driveshaft was putting too much of a load on the pinion (too long?) but the noise is still there when I pull the d-shaft.
The only thing left I can think of is the CV half shafts. But they usually don't grumble when they're going bad. CV's usually pop when going around corners when they're on their way out (mine do not do this).
Any ideas?
Any ideas?
