#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
93 XLT Ball Joints?
Reply
Thread Tools
Old 09-25-2007, 12:31 AM   #1
n0c7
Edmonton, Alberta
1993 Ford Explorer XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
93 XLT Ball Joints?
93 Explorer XLT, V6 4X4, both front wheels have play up and down, solid from left to right. I know in most cars this means its the ball joints, does the same apply for 4X4, or is there something else I should consider? Had the thing aligned over a year ago, always pulled to the right before and after, and they never bothered to mention that the wheels have play. It barely gets any mileage so I'm just finally getting around to giving it an overhaul.
n0c7 is offline   Reply With Quote
( Join the Elite Explorers )
Old 09-25-2007, 01:10 AM   #2
Tbars4
Offroad/Fitness Moderator
anaheim hills,california
Tbars4's Avatar
95 ranger 4x4/ 91 X 4x4
Vehicle Specs
Quoted: 289 Post(s)
...you are correct on the ball joints...right side is a common problem on the first gen's...the steering set up goes pretty regular also...at least they are inexpensive...
__________________
I have Rocks in my head. What's in yours?
'95 ranger xl 4x4 2.3L std cab, 3 sticks Ranger RegistryThe Squirrel
'91 4x4=To much to list, much more to add.. Project "X" and more Pics & Mod's List
How to: Wheels,Tires, & Lifts...
Buy Explorerforum.com Items here
Tbars4 is offline   Reply With Quote
Old 09-25-2007, 01:32 AM   #3
n0c7
Edmonton, Alberta
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I've done regular upper and lower ball joints on cars, pop them off and rebolt. The Chilton's manual says I need some sort of special tool, looks a bit more involved. Any tips? Unfortunately this may be something I need to complete in one shot as we'll be out of a vehicle with my other car requiring more serious attention and I'm using the Explorer as primary transportation. yay.
Old 09-27-2007, 11:25 AM   #4
pokerman11
Akron,OH
'93 Limited
Vehicle Specs
Quoted: 0 Post(s)
I got a 93 EXP 4x4 and have had to change my ball joints about every 60,000 miles (done it three times).
If you have a Autozone nearby they have a loan a tool program to loan you the ball press. I know some other places also do a loan a tool.
If you put the new ball joint in the freezer first overnight, some guys tells you it goes in much easier.
I know harbor freight sells a ball joint tool but also need the 4x4 kit.
Be sure to change both upper/lower.
I used my clintons manual to change also - not that bad of a job - but just need a good place to work on the truck. Also if you need new brake pads - good time to change.
pokerman11 is offline   Reply With Quote
Old 09-30-2007, 05:37 PM   #5
n0c7
Edmonton, Alberta
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Turned out to be the wheel bearings, repacked, tightened, all good.
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
