Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Modified 1991-1994 Explorers
Notices
Modified 1991-1994 Explorers Questions concerning modifications to the 1991-1994 Explorer, Mountaineer, Ranger and Navajo. Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, lift kits, engine swap, transmission swap.
1992 XLT rear brake conversion from drums to disc
Reply
Thread Tools
Old 09-27-2007, 07:37 PM   #1
rdale
92 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
My Explorer is max'd out on the rear drums. I also need front rotors since they are run-out also. Has anybody done a drum to disc conversion on the rear brake system, and if so I would need to know where to purchase a kit and a decent link for performance calipers for the front.
Thanks again in advance for any help.
rdale is offline   Reply With Quote
( Join the Elite Explorers )
Old 09-27-2007, 07:47 PM   #2
carlover
Fontana,CA
'96 XL
Vehicle Specs
Quoted: 8 Post(s)
go to your local junk yard and find a 2nd gen explorer. Pull off the calipers, rotors, brake lines, and mounting brackets for the rear. Its a simple bolt on process.
For the front i dont believe anyone makes performance calipers for explorers. Just get a set of oem replacements. Go with some Hawk pads, and maybe some drilled/slotted rotors if you want extra brake performance.
__________________
Sean.
BTF built explorer race truck in progress.
http://www.explorerforum.com/forums/...d.php?t=216036
BTF-FABRICATION.COM
carlover is offline   Reply With Quote
Old 09-27-2007, 10:59 PM   #3
mikeinri
04 Explorer, 94 XLT (RIP)
Vehicle Specs
Quoted: 8 Post(s)
Hey rdale, welcome to the forum.
I believe I've seen quite a few threads on this topic on this forum. Do a search and you should get a decent amount of info.
I'd be curious how the e-brake cable connects...
Mike
mikeinri is offline   Reply With Quote
Old 09-28-2007, 12:25 AM   #4
Spdrcer34
Bremerton, WA
1992 Explorer XL
Vehicle Specs
Quoted: 10 Post(s)
rdale: This is the STOCK 1st Gen forum....
But to answer your question:
This link talks about taking off the drums found on the Ranger, and First Gen Explorer, and replacing them with the rear discs found on the 95-01 Explorer.
http://www.4x4central.com/discswap.html
And here is the only REAL way to upgrade your front brakes, anything less isn't worth it:
http://img250.imageshack.us/my.php?i...sc04086le8.jpg
__________________
1992 Ford Explorer XL - with a few bolt ons...
Spdrcer34 is offline   Reply With Quote
Old 09-28-2007, 12:50 AM   #5
Exploderpilot
Nuevo, CA (where?)
Exploderpilot's Avatar
07 Titan SE
Vehicle Specs
Quoted: 0 Post(s)
how do those brakes mount? do they bolt up?
__________________
Member of IAVA Iraq/Afghanistan Veterans Association
03 ranger (Traded in for 07 Titan)
92 blazer (The one with all the horsepower)
Exploderpilot is offline   Reply With Quote
Old 09-28-2007, 09:39 AM   #6
mikeinri
Vehicle Specs
Quoted: 8 Post(s)
That discswap link is outstanding. One comment I would add is that since you have to remove the rear axles, replace the axle bearings (and seals?) while you have it apart.
Mike
Old 09-28-2007, 10:55 AM   #7
Maniak
Moderator-Stock 91-94
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
Quoted: 219 Post(s)
moved to propper forum.
__________________
Click HERE to see our Explorer Specs
Maniak is offline   Reply With Quote
Old 09-28-2007, 05:39 PM   #8
ironbandit
Cheltenham, MD
'92 XLT
Vehicle Specs
Quoted: 0 Post(s)
Thanks for the links, I've been eyeballing some Gen2 Explorers in the boneyard for just this reason. Found one and started the pumpkin teardown to remove the axle shafts, and found that it had a limited slip rear in it. That upped the ante. Now I'm looking to do a rear end swap out and take the discs at the same time. Gotta open it up to check the gears first, but then it's just a matter of nuts and bolts. Taking the hoses too.
I'll go check the links out.
__________________
Eric Hess
CO in my mind, MD in reality
1992 XLT 4.0 AT, just < 350K, on the way to 500K
Performance 3" Lift 31x10.5 Coopers on 15" Rims
Edelbrock shocks, Prothane Bushings
ironbandit is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
