uh60blackhawk
- October 7, 2007
- Scottsdale Az
- 97 XLT 5.0 XLT 4wd
I have a 97 AWD with a bad transfer case. The truck drives ok with the front drive shaft out. I believe the out put shaft bearings are bad because The truck vibrates badly at all speeds I have put in three driveshafts with same results. Front hubs are new as well as both halfshafts wheels balanced tried drive shafts in all positions possible. The front out put shaft has play So I suspect that the bearing is bad. I am planning to change out 4404 transfer case with a 4406
