Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Ranger - Mazda B-Series Forum > Ford Ranger - Mazda B-Series Forum
Notices
Ford Ranger - Mazda B-Series Forum Ford Ranger and Mazda B Series forums. The Mazda B2300 B3000 and B4000 are clones of the Ford Ranger, with all systems the same. The only differences are trim and a few body parts. This forum discusses Ford Ranger and Mazda B series specific issues. Owners of the older Mazda B2000 B2200 and B2600 are welcome as well.
2001 ranger, at idle, misfires?
Reply
Thread Tools
Old 10-10-2007, 07:48 AM   #1
keith3232
fort worth tx.
2001 ford ranger
Vehicle Specs
(Original Poster)
hello, i've had 1 diagnostic and three separate mechanics look at my truck and no luck, under 1200 rpm it misfires on all cyl. over it runs ok, revs fine etc. tested the egr valve, looks good, fuel lines had pressure, new fuel filter etc. pumps working fine. the last 60k miles my fuel cap light has been on, and no one has been able to fix it, cap is fine, idk if it has anything to do with it. plus at the same time this occured my horn/cruise/airbag control blew. idk? please help. thank u
keith3232 is offline   Reply With Quote
Old 10-10-2007, 09:22 AM   #2
dogfriend
Human-Animal Hybrid
Carmichael, CA
dogfriend's Avatar
'97 Sport 4x4
Vehicle Specs
My first thought is that you have a vacuum leak somewhere. It will cause a misfire at idle because it leans out the air/fuel mixture, making it harder for the plug(s) to fire. At higher engine speeds, the vacuum leak will have less of an effect, because the vacuum lowers as the throttle opens.
Regarding the "fuel cap" light; Is the Check Engine Light on, or do you have a separate Fuel light on your truck? If it is the former, I would get the actual code(s) that are set in the PCM (computer). It is very possible that the code(s) are related to the problem you are having and will give a clue to the source of the problem.
If you can report what code(s) are set on your truck, people here will be able to give you more advice on fixing the problem.
dogfriend is offline   Reply With Quote
Old 10-10-2007, 09:31 AM   #3
keith3232
fort worth tx.
2001 ford ranger
Vehicle Specs
(Original Poster)
yep
i did put a vacuum tester on, and at idle the needle vibrates like craxy. with gas it levels out. there are no visible line leaks. hope its not inside?
Old 10-10-2007, 09:42 AM   #4
dogfriend
Human-Animal Hybrid
Carmichael, CA
dogfriend's Avatar
'97 Sport 4x4
Vehicle Specs
I don't know which engine you have, but intake manifold leaks are somewhat common on the 4.0L as they get older. The 4.0L SOHC engines are famous for leaking o-ring gaskets in the intake manifold.
Check this link for a trick to find a vacuum leak.
Old 10-10-2007, 09:49 AM   #5
keith3232
fort worth tx.
2001 ford ranger
Vehicle Specs
(Original Poster)
yep
yes, i have the 4.0 v6. any guess on cost to fix?, i can change basic alternater, starter etc, but past that i'm lost
Old 10-10-2007, 09:56 AM   #6
dogfriend
Human-Animal Hybrid
Carmichael, CA
dogfriend's Avatar
'97 Sport 4x4
Vehicle Specs
The parts are cheap, but the labor is probably a few hours for an experienced mechanic; probably a couple of hundred bucks. This is something where you can save quite a bit if you are willing / able to DIY.
If you search, you should be able to find some writeups on replacing the intake manifold gaskets.
Old 10-10-2007, 10:25 AM   #7
keith3232
fort worth tx.
2001 ford ranger
Vehicle Specs
(Original Poster)
maybe?
just for grins, could the ac have anything to do with it?
Old 10-10-2007, 12:22 PM   #8
dogfriend
Human-Animal Hybrid
Carmichael, CA
dogfriend's Avatar
'97 Sport 4x4
Vehicle Specs
Quote:
For a misfire, not very likely that the AC has anything to do with it. However, if the truck idles slower when the AC is on, it could point to a problem with the IAC (idle air control) valve.
If you search on IAC, you should get half a gazillion hits.
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Sustaining Power at IDLE CamJ255 Explorer Audio & Navigation 9 06-09-2007 09:14 AM
Poor starts, dying at idle: IACV, Mass Air ?? Explorer Lee Under the Hood 10 07-27-2005 12:47 AM
Hum/moan at idle fixed, '00 XLT SOHC... fgump Under the Hood 3 01-30-2005 08:23 AM
Explorer 2001 XLS... Stall at idle haggus_75 Elite Explorer 911! 3 08-28-2004 10:43 AM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
