fordman630
- October 13, 2007
- Baton Rouge, Louisiana
- 2000 Mountaineer
Okay - here's an update to my problem with my daughter's mountaineer. Yesterday my nephew and I went to her college. We had his pressure test kit for the coolant system and some of his other tools - he's a mechanic. What we found was a freeze plug on the head next to the firewall leaking coolant. He said that the factory installs these types of plugs made of steel and some softer metal such that if the vehicle overheats the plug will melt and protect the head. Not sure how that works because it seems like you would want to keep the fluid in. He said it was a tattle tail incase other systems fail to indicate an issue such as the temp gauge goes out and you have a water pump problem or some other problem that is not immediately visiable. Does this sound correct? The problem is we could not find a replacement plug even the local ford dealership didn't have one and we couldn't stay up there. So I took it to a shop still not knowing what caused the overheating or to what extent the damage was.
