Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
4.6L Engine Problems Galore!
Reply
Thread Tools
Old 10-25-2007, 02:14 PM   #1
DavidS
Kingsport, TN
'02 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Unhappy 4.6L Engine Problems Galore!
Suddenly last week, my 2002 Explorer EB 4.6L V8 started running terribly while stopped at a drive thru window. The "service engine soon" light came on. At idle it surges wildly with rpm's bouncing from 600-1200 and acting like it's going to die. It causes the whole vehicle to quiver badly and you can tell it even under way if the rpm's are in the 1000-1500 rpm range. When you come to a stop, the rpm's try to stay around 1000 rpm's until you've stopped then it starts surging up and down again. I took it to Autozone to have it scanned and it showed a bunch of codes:
P0171: Fuel Trim Bank One condition, O2 sensor recognizes a rich or lean condition on one engine bank only.
Probable causes
1. If banks one and two together suspect fuel pressure or MAF Sensor.
2. O2 sensor defective
3. Iginition misfire-repair
4. Fuel injectior problem
P0174: Fuel Trim Bank Two condition.
Probable causes: same as above with addition of Failed HO2S21.
P0300: Cylinder misfire detected-random cylinders.
Probable causes:
1. Ignition system fault
2. Vacuum leak
3. Injector fault
4. High or low fuel pressure
P0316: Crank Sensor condition
Probable causes:
1. Crank sensor defective
2. check connector & wiring to sensor
3. Check trigger wheel for damage
P1131: Lack of bank 1 O2 transitions-lean
Probable causes:
1. Misfire on bank 1
2. Vacuum leak affective bank 1 only
3. Fuel injector problem bank 1
4. Engine mechanical condition
P1151: Lack of O2 switches Bank 2 sensor 1, ECM couldn't adjust fuel trim of a lean or rich conditon.
Probable causes:
1. Fuel pressure high or low
2. MAF sensore dirty/defective
3. Vacuum leak on engine
4. Leaking fuel injector or fuel pressure regulator
Has anyone had anything like this happen to them before? I'm going to clean the MAF Sensor but I can't imagine it causing all this. It's strange that all this started all at once. Do O2 sensors suddenly fail, especially together like this? Any help would be appreciated as my dealer charges a minimum of $100 just to check it out and then the parts and labor for repair. I'd like to do it myself if possible. Thanks to all!
DavidS is offline   Reply With Quote
( Join the Elite Explorers )
Old 10-25-2007, 10:22 PM   #2
wchain
Houston, TX
02 XLT V8 2WD
Vehicle Specs
Quoted: 0 Post(s)
Check your PCV hoses for the P0171/0174. Lean in both banks usually yields a large vacuum leak of some sort.
1131/1151 are related probably to the vacuum leak. Again, check your PCV valve and hose assy. You'll need a 1/4"driver to remove the big engine cover to access the PCV hose.
Good luck.
__________________
02 XLT 4.6L 73K
93 XLT - Sold
96 EB V8 -Sold
04 Mercury Marauder
97 CVPI
95 Mustang GTS
wchain is offline   Reply With Quote
Old 10-26-2007, 12:33 PM   #3
DavidS
Kingsport, TN
'02 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Cool
A vacuum leak it was although not in the PCV valve line. It was in a small 1/2" 90 hose right on top of the intake manifold that was pulling from the intake air and was completely rotten. It was a bear to remove it in several pieces. What it's purpose is I don't know but replacing the hose fixed it. I also cleaned the MAF Sensor while I was in there. The "service engine soon" light is still on even though it now runs fine. How do I go about resetting that light?
Old 10-26-2007, 03:23 PM   #4
JDraper
Somewhat Functional
McVeytown, PA
JDraper's Avatar
'11 XLT
Vehicle Specs
Quoted: 30 Post(s)
To re-set the computer, disconnect the battery for a few minutes. That will clear all the codes.
__________________
Moderator..Home Improvement/Explorer 911/2011 Explorer Forum
You took my breath away....and now I want it back....
'66 Mustang Coupe, '04 Mustang Mach 1, '08 Focus, '11 Explorer XLT
"Ex"plorer's: '92 Sport, '94 Sport, '01 XLS
Our Crappy Website
JDraper is offline   Reply With Quote
Old 10-02-2008, 10:08 AM   #5
shibbz
Cincinnati, OH
02 EB
Vehicle Specs
Quoted: 0 Post(s)
My explorer has the exact same issue.. the 90 degree right angle hose.
I've been looking for a replacement.. I just want to replace the elbow and not the entire part - where did you find this elbow?
Was it truly 1/2" Mine looked 5/8" but it was late and I was tired.
Thanks
shibbz is offline   Reply With Quote
Old 10-02-2008, 04:20 PM   #6
Cgy04XLT
Calgary,Alberta
04 XLT
Vehicle Specs
Quoted: 0 Post(s)
Hey man...if you are having this issue there was a guy with this problem a few weeks ago and he was able to fix it without getting the part from Ford!! Here is a link to the post.....
http://www.explorerforum.com/forums/...d.php?t=217062
Hope thats helps ya out and good luck!!!
Cgy04XLT is offline   Reply With Quote
Old 10-06-2008, 07:27 AM   #7
Beausdad
High Point,NC
'03 XLT
Vehicle Specs
Quoted: 1 Post(s)
the fix
I had the same problem. I went to NAPA and they had a hard plastic elbow that I attached about a 2 inch piece of 5/8 fuel line on either end and fixed the running bad.
Service Engine Light will not go off by unhooking negative battery cable on
3rd gen. You must go to someone to get it shutoff. That is what I was told.
Auto Zone said my MAF and O2 Sensors were the problem. It was actually that elbow. I cleaned the MAF using almost a whole can of MAF cleaner - side note MAF cleaner is the same as brake parts cleaner. I had my light shut off. Drove home. Turned Ex off. Came out next morning. turned Ex on. Light came back on. Now I have to replace O2 Sensors. Only problem. Damn thing has like 4 of the damn things.
Remember the good old days when all you had was a block, Carbueretor, master cylinder, battery and a transmission. TECHNOLOGY SUCKS!!!!!!!!!!!
Beausdad is offline   Reply With Quote
Old 02-24-2011, 11:29 PM   #8
corsair1987
las flores ca
2005 Ford Explorer xlt
Vehicle Specs
Quoted: 0 Post(s)
Please read!!! I need help with my '05 Explorer, engine die's... still :(
2005 Ford Explorer v6 4.0 111,000k
A few weeks ago, I tried to start my Ford, the engine would turn over, then it would die.... so I took it in to the Ford dealership, they did all there checks and found out that the throttle body was bad, so they replaced it... When I drove it home the "gas pedal wouldnt accelerate, then the power steering seized, I turned the truck off and turned it back on, and it worked.. Later that night I tried to start my Ford, then my engine sounded odd, then the "service engine" light came on, then it died.... when I turn the truck on, now it dosnt even turn over...... what is going on?
Please can you guys help? advice anything?....
corsair1987 is offline   Reply With Quote
Old 02-25-2011, 09:25 PM   #9
EasyRhino
Kailua, Hawai'i
'02 Limited 4.6L 4x4
Vehicle Specs
Quoted: 0 Post(s)
Dude, start a new thread instead of piggy backing onto this one. Your symptoms will get folk's attention. Be sure to describe what truck/engine/tranny you have, and be patient. The traffic here is knowledgeable but not heavy.
__________________
Wife's: '02 Limited 4.6L/4x4
Mine: '04 Mustang GT Vert, 2006 C6 Corvette Coupe
EasyRhino is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
