Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
3rd gen Explorer Blend Door Actuator Replacement
Reply
Thread Tools
Old 05-11-2010, 07:45 PM   #161
jakedrew
wisconsin
04 xlt
Vehicle Specs
Quoted: 3 Post(s)
^ well the 3rd speed deal has nothing to do with the blend door actuator .
Happened on my 04 as i only had the fan speed work on "high"/ "4". I just replaced the part in the heater control unit where the knob pushs into / turns. That dail deal. was like 30$.
jakedrew is offline   Reply With Quote
Old 05-11-2010, 11:22 PM   #162
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
Are you saying that you just replaced the Speed Dial Selector switch?
Thanks for you help.
__________________
Rondo - USMC, Combat Engineer, 1983-1996
Click here for a list of my write-ups!
Quote:
Originally Posted by FIND on 4-22-13
Don't mess with Boston. They will drop everything, hunt you down, and then go on like you never existed once they are done cleaning up the mess.
BigRondo is offline   Reply With Quote
Old 05-12-2010, 11:32 AM   #163
mikeinri
04 Explorer, 94 XLT (RIP)
Vehicle Specs
Quoted: 8 Post(s)
Hey I checked my truck for you last night. There is a definite speed difference between 3 and 4. There's a slight difference between the speed of Max vs. normal AC when the fan is at 4. I didn't hear any doors, but you could tell that it was changing from outside air to recirc air.
Hope this helps.
Mike
mikeinri is offline   Reply With Quote
Old 05-12-2010, 01:32 PM   #164
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
Quote:
Hope this helps.
Mike
Thanks Mike. I gotta look into this this weekend.
__________________
Old 05-12-2010, 09:42 PM   #165
jakedrew
wisconsin
04 xlt
Vehicle Specs
Quoted: 3 Post(s)
ya. All i did was pull the knobs off, pull that center piece out. ( kinda have to pry it out/ work your way around pulling). and then take out the i think) two 8mm bolts holding the climate control panel in, un hooked /un plugged everything, popped out the speed dail switch deal, put in the new switch/dail and re assembled everything. tools needed- screwdriver to pry out the plastic center piece and a 8mm socket/ratchet and a little bit of your time.
I just had the blower work on "4". Everyone talks about resistors ( i come from a GM background). Went to the dealer and asked the guy how many of these switch dails speed control deals he sold VS the resistor and he sold about the same. So i gave the switch/dail a try and been working for at least a year now.
but still do some research. I know there is a post about resistors. I am just telling you what worked for me!
good luck
Old 05-12-2010, 10:48 PM   #166
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
Thanks for the info.
__________________
Old 05-13-2010, 08:47 PM   #167
jakedrew
wisconsin
04 xlt
Vehicle Specs
Quoted: 3 Post(s)
ya, keep us updated.
Old 05-24-2010, 01:37 PM   #168
Justin B
Columbus, OH
2003 Explorer Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
Our 2003 Explorer seems to meet all of the symptoms mentioned for a broken blend acuator. Except the clacking noise part. We never had the noise(s), but it will only blow cold air. We have the automatic climate control unit. Could we have something other than a broken blend actuator? Thanks.
Justin B is offline   Reply With Quote
Old 05-27-2010, 01:59 PM   #169
dadude
Phoenix, Az
2002 1/2 XLT 4.6L AWD
Vehicle Specs
Quoted: 0 Post(s)
Justin
I had a blend door problem with mine that was relatively silent and simple. The pivot pin on the blend door broke, disconnecting the actuator from the door. 1st symptom was uncontrollable HOT (Az) or cold (in the mountains in winter) air in the footwell of the passenger side. Made an occasional clunking noise when switching to recirc but relatively silent problem.
You can check by flipping the glove box down (press in by the stop on the side of the box and remove the stop cord if equipped). You'll see the blend door actuator behind (actually in front of) and above where the box usually sits. It's a metal cylinder with a vacuum hose on one end and a flat metal rod (actuator arm) extending upward to the right out of sight behind stuff on the upper end. You almost need a mirror or to stand on your head, but take a flashlight with you and look around in there, you can even see a bit of the door itself. Turn on the power & fan, rotate the air diverter dial back and forth into recirc mode and you'll see the actuator arm move, if it doesn't move you have another problem, if it moves, just follow it. Anyway, the actuator arm connects to a plastic pivot pin on the blend door and you can see/feel where the end of the actuator arm goes onto the pivot and operates the blend door. On mine, that pivot pin was broken but I was able to reposition the actuator arm onto the remaining end of the pivot pin (there was about a 1/4-1/2" of the pin still there) and secure it with a couple of nuts (8 or 10/32nd) to lock it on. That did the trick really a simple repair, just had to do a lot by feel, yoga helps too.
dadude is offline   Reply With Quote
Old 05-27-2010, 05:30 PM   #170
mikeinri
Vehicle Specs
Quoted: 8 Post(s)
...yoga helps too...
Not to mention copious amounts of drinking and cursing...
Mike
Old 05-29-2010, 08:03 PM   #171
Ejectr
2002
Vehicle Specs
Quoted: 0 Post(s)
Quote:
Originally Posted by dadude View Post
Justin
Are you saying your blend door actuator is behind the glove box on your 2002 Explorer? Mine seems to be behind the center console. I looked behind the glove box and I don't see it there. Sounds like you had a problem with the diverter door which controls where the air goes, not the blend door that controls the temperature. The blend door actuator is controlled by the temperature knob and is not vacuum. It's electronic and runs through the computer.
Ejectr is offline   Reply With Quote
Old 06-09-2010, 08:23 PM   #172
daveleeander
Marietta, OH
02 XLT
Vehicle Specs
Quoted: 0 Post(s)
Mine closes with a thump when you turn the air on. Clicks until then. 02 XLT with 225k miles.
Looks like I'll do the actuator thing.
D
daveleeander is offline   Reply With Quote
Old 06-12-2010, 02:52 PM   #173
Ejectr
2002
Vehicle Specs
Quoted: 0 Post(s)
My wife's problem suddenly went away. She now has Max A/C and heat. Glad I didn't have to tear it apart. Don't know what it was. Maybe a dead mouse blocking the mixer door. She sure gets plenty of those in the vehicle and I have no idea how they get in.
Old 06-13-2010, 01:02 PM   #174
CalebT
Milford Pa
2000 XLT V8
Vehicle Specs
Quoted: 0 Post(s)
Is there anyone who sells just a new gear? That is all i need. The small black double gear
CalebT is offline   Reply With Quote
Old 06-18-2010, 09:06 AM   #175
tsewell
Currently in Montgomery, AL. Wishing to be back in ATL!
2002 Mountaineer
Vehicle Specs
Quoted: 0 Post(s)
US Finally got the actuator out, now what??
Okay, I am having the problem where I have two settings: Heat and Max AC. And even on Max AC, it isn't "refreshingly" icy all the time. and it only seems to be cold out the center vents in the front.
Everything I've read leads me to believe it's an actuator problem. So I got to the actuator, got it out, opened it up and nothing seems to be wrong with it. Nothing broken or missing. The gears turn, but not easily. Anyone have any ideas of what I should do or try? I'm going to sell it soon, so I'm not trying to spend a lot of money, or time for that matter.
tsewell is offline   Reply With Quote
Old 08-03-2010, 04:39 PM   #176
DeSOB
Wilmington, DE
05 'XLT Sport; 4.0L
Vehicle Specs
Quoted: 2 Post(s)
Dorman part for 2005
What is the difference between Dorman part #604207 and #604209? 209 is for manual AC control and 207 for automatic AC controls.
So I guess my real question is what's the difference between manual and automatic? Is automatic the kind where you program in the desired temperature and manual the simple knob?
thanks!
DeSOB is offline   Reply With Quote
Old 08-31-2010, 02:38 PM   #177
Jorgen
Bloomfield Hills, MI
'05 S4, '04 Explorer
Vehicle Specs
Quoted: 1 Post(s)
I just used this how to and it worked great. Maybe an 45 minutes -1 hour start to finish if I hadn't also been doing some other work at the same time and taking my time for a brew ever so often.
The small gear on the smaller of the two black gears was bad. If anyone needs the big black gear or the other components they are all sitting on a shelf in the garage just incase.
Scot
__________________
1969 Triumph Spitfire [Toy/Project]
2005 Audi S4 4.2l V8 6-speed quattro[Daily Driver]
2004 Explorer XLT, 4.0 OHC, Auto, Fully Loaded [Wife's Daily Driver]
1998 Explorer Sport, 4.0 SOHC, Auto 190k [RIP Old Girl]
Jorgen is offline   Reply With Quote
Old 08-31-2010, 08:42 PM   #178
jakedrew
wisconsin
04 xlt
Vehicle Specs
Quoted: 3 Post(s)
are you guys using a ford part or going with a aftermarket part for the actuator?
I personally stuck with ford as the price difference wasnt much.
Old 08-31-2010, 08:51 PM   #179
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
I need to do this before the winter. I'm stuck on A/C, not bad in the summer but I'm gonna need heat soon. Thanks to a lot of great write-ups, I hope I can do it with minimum complications.
__________________
Old 09-05-2010, 11:58 PM   #180
crudster
03 XLT
Vehicle Specs
Quoted: 0 Post(s)
Blend door & Actuator replaced, Excellent cold mediocre cold
Hi Folks,
Last winter i encountered the dredded click of death. I broke down and bought the Heathertreater blend door fix and found that only the actuator was broken - likely the blend door jamming caused the actuator to break..
Anyhow, Ever since the fix (almost a year now), I can't get enough heat from the system. 100% hot on the dial feels like 50-60%. I've actually dismantled the whole fix and checked and the actuator and blend door appear to be working, though contorting ones self like a gymnist reveals some doubt. As with most things - summer = not caring about heat, but now that winter approaches its suddenly more of a concern.
Any ideas?
Tomorrow i plan on pulling the dash panel and watching the arm on the right side of the blend door move. Will see if it moved "enough".
Perhaps it needs a recalibration?
crudster is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
How to: 3rd row seating in a 1st & 2nd gen Explorer project92 Stock 1995 - 2001 Explorers 38 12-21-2015 11:29 PM
3rd gen explorer jcasey007 UK Explorer Owners Forum 9 02-26-2011 12:48 PM
AWD on 3rd gen explorer Hitchhikingmike Stock 2002 - 2005 Explorers 4 05-27-2008 07:11 PM
3rd gen 4x4 explorer bcop Explorer - Ranger Shocks, Suspensions, Lift Kits 2 01-11-2005 10:16 AM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
