Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
Fuel Filter Replacement w/pics
Reply
Thread Tools
Old 09-16-2012, 04:38 PM   #181
xtoolmaker
orlando florida
2003 xls
Vehicle Specs
Talking Flex fuel
My 2003 4.0 is flex fuel.Inside your fuel filler door it should say E85 .I took the easy way out on my filter $20 at my local dealer to install the filter I bought online[made in the USA not China]:
xtoolmaker is offline   Reply With Quote
Old 09-16-2012, 04:49 PM   #182
edwx
Syracuse, NY
edwx's Avatar
'06 XLS
Vehicle Specs
Yeah, my '03 4.0 WAS also a Flex Fuel.
__________________
You'll be surprised at what you'll never have to do if you put it off long enough.
edwx is offline   Reply With Quote
Old 09-16-2012, 06:00 PM   #183
HiImBrian
I'm the Doctor.
St. Petersburg, Florida
HiImBrian's Avatar
2003 Explorer Eddie Bauer
Vehicle Specs
Yeah but the sticker on the inside of the fuel door can come off. Not that it really matters anyways, it'd just be good to know. I'll see if I can find out with my VIN.
__________________
2003 Explorer Eddie Bauer 4.6L V8
MMR Stage 2 Heads - Ported Bullitt Intake - BanksPower TransCommand - CodeAlarm Remote Start - Hunter Brushguard - Custom Roof Basket - 3rd Cat Cutout - Straightpiped/Magnaflow Catback - 3" Body Lift - 2.25/1.75 BTF Spacers - F-150 Towhooks - 2" Wheel Spacers - HID's - 265/70/17's - EGR & PCV System Delete - AND MORE!
My Registry: HiImBrian's Beachcomber
HiImBrian is online now   Reply With Quote
Old 10-07-2012, 05:16 PM   #184
rlb81
Central NJ
2002 Explorer XLT 4WD
Vehicle Specs
The outlet line stinks. After messing with it for 1+ hours with both plastic and metal tools I wasn't able to release it. The 2 lines on the inlet side are simple, why did ford need to make the outlet different? I gave up and I'll just take it somewhere to have it replaced. I can't even get 2 hands up there to mess with it.
__________________
2002 Explorer XLT 4x4
rlb81 is offline   Reply With Quote
Old 10-16-2012, 03:37 PM   #185
wooded19
NH
2002 mercury mountaineer
Vehicle Specs
hello, I have a 2002 mountaineer 4.0 awd with 163,000, and find the mercury site useless for ideas. I found the metal tool usefull for the drivers side single line, but could not keep the retaining spring fully disengaged to remove the line. a real pita! I made a wood shim with a v cutout and a 1/2" hole (to fit over the gas line) out of oak flooring, you have to thin it to 1/2" thick so it fits between the filter body and the tool.i did not jam it hard, only enough to maintain the presure on the spring while i could wiggled the darn line off. I spent 1 hour before this trying to remove the line. There is so little room up there for such a simple connection, I was so frustrated .
wooded19 is offline   Reply With Quote
Old 11-26-2012, 02:20 AM   #186
fbodyrs96
Calhoun GA
2002 Explorer XLT
Vehicle Specs
Finally got mine changed with the little blue aluminum tool, it was still a major pita even with the right tool.
fbodyrs96 is offline   Reply With Quote
Old 12-16-2012, 09:38 AM   #187
jcongdon
Florida
2004 Ford Explorer
Vehicle Specs
Need to change my fuel filter on my 2004 Explorer XLT. We cut the filter off my fiancees 2005 F150. Replaced it with braided fuel lines in that area around the filter. The filter would not come off even with the tool. Hoping we will not have to do the same on this vehicle.
jcongdon is offline   Reply With Quote
Old 12-16-2012, 09:54 AM   #188
xtoolmaker
orlando florida
2003 xls
Vehicle Specs
Hey there.I bought a Made in the USA factory filter online and took it to Don Reid Ford In Orlando they put it on for $20.00.My filter on the 2003 xls had the three hoses and for twenty bucks it wasn't worth the pain everyone seems to have doing it in their driveways.
Old 02-17-2013, 04:21 PM   #189
josherni
Livermore CA
02
Vehicle Specs
Hey there!
2002 Explorer XLS. Just finished replacing my filter. Ford really wants everybody to pay for the replacement service, it was difficult but got it done!
Thank you all for the info
josherni is offline   Reply With Quote
Old 02-19-2013, 05:23 AM   #190
AIRBLUE
Michigan
AIRBLUE's Avatar
2002 Explorer XLT 4.0 4x4
Vehicle Specs
Angry
Quote:
Originally Posted by BigFellor View Post
I just have to say two things. First, this thread has been a ton of help. Second, whoever designed these "quick" disconnect fittings should be kicked in the crotch about 30 times.
30 TIMES MY FRIEND IS NOT ENOUGH. THEY SHOULD HAVE NAILS DRIVEN INTO THEIR BALLS!
If this is a government "required fitting" that would figure!
AIRBLUE is offline   Reply With Quote
Old 02-27-2013, 04:05 PM   #191
College Student
Indinapolis, IN
College Student's Avatar
'03 EB
Vehicle Specs
So I thought I could maybe solve some of my sputtering issue as it looks a though the factory filter is on there at 250,000 miles...I seriously hope it isn't the factory one. I have done a few filters in the past. I replaced the one on our 98 and it was nice and easy right where you can put both hands on it and have more room. Well I was wrong and spent 2 hours on just the outlet side using the expensive metal disconnects. I'll be going home this weekend in order to do this in the garage with the plastic ones that worked previously.
Edit: and I smell like gas I started the car with the fuel pump off...end result when I partially disconnected the first inlet hose the pressure was great enough to pop it the rest of the way off and blow gas everywhere (blew not trickled)
__________________
Mods:
265/70/17 ; Tow Hooks; Telescoping Steering Wheel; Kenwood DDX616; Class III/IV Hitch
College Student is online now   Reply With Quote
Old 03-17-2013, 11:30 AM   #192
scooter3
Arizona
'13 Explorer Lmtd 302A
Vehicle Specs
Just spent about 2 hours trying to get the fuel filter out of my 2004 Eddie Bauer and gave up! Even with the right release tool it would not come off. Truck has 196,000 and don't think it has ever been changed. I will let my local garage deal with the headache for $40! Very frustrating....this is mechanics 101 stuff.
__________________
2013 Explorer Limited 302A
2004 Eddie Bauer Edition
2003 Mustang GT supercharged
scooter3 is offline   Reply With Quote
Old 04-05-2013, 11:56 PM   #193
turblown
Buckeye, AZ
2003 Ford Explorer XLT
Vehicle Specs
Just replaced the fuel filter for the third time (120,000 mile tune up). Here are some lessons learned that I had forgotten and a couple of pics:
  • Practice your setup with the removal tool on the NEW fuel filter.
  • Push the outlet line toward the old filter end as much as possible.
  • Hold the line in place as you get the 5/16" removal tool in position.
  • The tool should insert into the line nicely (but not flush) with about a 1/8" gap.
  • Remember the tool can only go as far as the metal ridge on the filter, so once it is in, pushing harder on the tool does not help!
  • Hold the tool steady on the old filter (up to the ridge) and pull hard on the line.
  • If the line does not release, remember this is a battle between the tool and the line. Pushing/pulling the filter doesn't do much.
  • Continue trying to get the tool as far into the line as possible (pushing) and then pulling the line off.
  • The tool spreads the line open enough to slide over the metal ridge on the old filter.
  • Be ready for gas to run down your arm.
turblown is offline   Reply With Quote
Old 04-08-2013, 10:44 PM   #194
angler3
monroe,ny
2003 ford explorer xlt
Vehicle Specs
my pita is the clip that unlocks and is pushed up . cant get the %$#@&*)^%$#$& to push up.
angler3 is offline   Reply With Quote
Old 05-04-2013, 06:14 PM   #195
wangbungal
miami fl
ford ranger xl 97
Vehicle Specs
any tips how to get it out, what size of fuel disconnect you guys use for the line? mine is a 2003 ford explorer 4.0 v6 xls its has 3 ports
__________________
FORD RANGER 1997 XL
REG CAB 3.0 V6 2WD
STILL SAVING TO GET IT PAINTED LOL,
wangbungal is offline   Reply With Quote
Old 05-05-2013, 05:07 PM   #196
Tyler92
Saratoga Springs, NY
2002 XLT
Vehicle Specs
That's the wrong size tool. The line is 3/8 so you need a 3/8 tool. 5/16 won't go all the way around the line so some of the little clips won't get pushed back.
Tyler92 is offline   Reply With Quote
Old 05-05-2013, 08:08 PM   #197
edwx
Syracuse, NY
edwx's Avatar
'06 XLS
Vehicle Specs
Yeah, I used the 3/8" metal tool like the one in above post. I think it was gold colored, and I got mine from NAPA. Worked good once I had the right tool.
__________________
Old 05-07-2013, 11:06 PM   #198
turblown
Buckeye, AZ
Vehicle Specs
Quote:
I understand it's a 3/8" line. I'm just stating what has worked best for me. I have the tool kit that includes four different sizes (including 3/8") and I have used the 5/16" tool every time. The 3/8" tool seems to be a bit too thick to fit under the fuel line fitting correctly. Hence there are previous posts describing how to file it down a bit. Go with what works.
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
