Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
4x4 Switch Wiring Diagram - '92 Explorer
Reply
Thread Tools
Old 11-17-2007, 11:14 AM   #1
lnstevens1976
Boise, ID
'92 Explorer Eddie Bauer
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
Does anyone have a wiring diagram for the 4x4 Switch in a '92 Explorer?
After installing a new stereo last night (rig didn't come with one when I bought it) I found that I had bumped the 4x4 switch and could get into 4 high (tested).
I couldn't get into 4 Low though and after a bit it stopped working again.
After further inspection upon pressing any button on the switch nothing happens, no click underneath, etc..
I have tested to make sure there is power at the connection, but I don't know what I can jumper to cause it to go into 4 High, Low, or if I even can.
So any help here would be appreciated.
I would rather not buy a switch only to find out it wasn't the switch.
Thanks,
Larry
lnstevens1976 is offline   Reply With Quote
( Join the Elite Explorers )
Old 11-18-2007, 05:36 PM   #2
bugz
Norfolk, Virginia
1992 Explorer
Vehicle Specs
Quoted: 0 Post(s)
Thanks,
Larry
Yea mine does not work either, the owner before me decided to put in a aftermarket radio and cut everything no wiring kits like a normal intelligent person would do, and hard wired everything, I think that's the source of my problem as well, if anyone has any info, let us know!
bugz is offline   Reply With Quote
Old 11-18-2007, 06:05 PM   #3
DeRocha
NEX Vice President
Brockton, MA
DeRocha's Avatar
'93 XLT 4x4
Vehicle Specs
Quoted: 3 Post(s)
...I found that I had bumped the 4x4 switch and could get into 4 high (tested). I couldn't get into 4 Low though and after a bit it stopped working again.
Thanks,
Larry
Did the 4x4 work before? Just because a stereo was installed or missing is no indication of a switch issue.. On 1st generation explorers it is very common to have a broken plastic bumper within the shift motor preventing shifting into or out off 4x4. Check out the FAQ thread shift motor rebuild for lots of good info and pics on fixing this..
__________________
John D-"Search first, Ask questions later" & "You can have my Explorer when you pry the keys from my cold dead hands." <<<Forum Rules >>>*My Truck*
4x4 Trouble Shooting Guide
See how cars work Axle and tire calculators U-joint replacement info/pics
Repair info NEX-New England Explorers NEX: Club Events
DeRocha is offline   Reply With Quote
Old 11-18-2007, 10:56 PM   #4
lnstevens1976
Boise, ID
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
Quote:
I've read that thread so I should explain further.
When I was installing the stereo it appeared the switch had not even been reconnected after removal of the previous after market stereo.
Upon connecting the switch I was able to switch into 4 High. Unfortunately I didn't know how to switch into 4 low.
I drove it and tested it in 4 High, but was unable to test in 4 Low because I didn't know how.
After a few uses suddenly it stopped working again.
Honestly this "Feels" like a good possibility of a switch issue, but I want to trace this down. I don't want to be swapping parts for no reason..........
Or, for that matter, pulling things apart for no reason.
Old 11-19-2007, 12:33 AM   #5
lnstevens1976
Boise, ID
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
Well, I was right and it didn't take a new switch (at least not yet). I pulled the switch apart and cleaned all the connections on it.
After doing this I put the switch back in and the 4x4 works.
4 Hi works perfect, although 4 low makes a nice noise as it goes in which I don't know what that is yet.
Old 11-19-2007, 05:16 AM   #6
YourNameHere
Haverhill, MA
94 Explorer
Vehicle Specs
Quoted: 0 Post(s)
MY lights don't even come on at my switch. Wish MY 4x4 worked...
Everything is plugged in and the fuses are good.
__________________
-P.J.-
Winter Beater: 1994 Explorer XLT 4wd
Summer Car/ Daily Driver: 1998 Mustang Cobra coupe #4941 of 5174 Born on June 19, 1998. 263rwhp/258rwtq untuned, with nonfunctioning IMRC's. Hoping for 285-290 next spring with a much needed tune.
YourNameHere is offline   Reply With Quote
Old 11-19-2007, 07:51 AM   #7
DeRocha
NEX Vice President
Brockton, MA
DeRocha's Avatar
'93 XLT 4x4
Vehicle Specs
Quoted: 3 Post(s)
The above shift motor thread has lots of info on trouble shooting a 4x4 shift problem. As a quick test you can start the engine, press the 4x4 High button, and then listen very carefully for relays clicking from the 4x4 computer (you may need a friend to sit in the rear hatch and listen). If you can hear the relays the shift button is correctly sending its signal to the 4x4 computer. At this point the most likely problem is the broken stop within the shift motor. If you cannot hear any relays you should then test the 4x4 computer.
Click for larger image
__________________
Old 11-19-2007, 08:20 AM   #8
SensRanger
Ottawa, ON
96 Ranger XLT 4x4 Xcab
Vehicle Specs
Quoted: 2 Post(s)
Am I correct in assuming that if the 4x4 high works, but not 4x4 Low, then the shift motor must be working fine? Everything I've read about the shift motor problem relates to the plastic bump stop breaking, causing the motor to "lose track of itself" and not know what range it's in, preventing any further shifts and often making the 4wd and 4wd low lights blink. But if 4x4 high works and you can shift into and out of it easily, the motor must be fine no? My 4 low doesn't work and I don't know why.
SensRanger is offline   Reply With Quote
Old 11-19-2007, 09:16 AM   #9
DeRocha
NEX Vice President
Brockton, MA
DeRocha's Avatar
'93 XLT 4x4
Vehicle Specs
Quoted: 3 Post(s)
Quote:
Is your question geared related to a 1st generation (91-94) Explorer? Your profile indicates you have a '96 (2nd generation) and this is a 1st generation forum. Anyway if 4x4 high works then you should be good. How Exactly are you trying to engage 4x4 Low? On a 1st generation Explorer you must:
  • 1st be in 4x4 high
  • Transmission in Neutral
  • Clutch depressed (man transmission)
  • Foot on Brake (mph<3)
  • Now Press 4x4 Low
__________________
Old 11-19-2007, 09:46 AM   #10
SensRanger
Ottawa, ON
Vehicle Specs
Quoted: 2 Post(s)
Hi thanks for the reply. Well actually I have a 96 ranger. So its kinda a cross between a 1st gen ex (ie. TTB suspension) and a 2nd gen (most electricals and the interior.) But as far as I can tell the 4wd operation for my truck is most closely related to 1st gen ex's and maybe early 2nd gen? (I have 2wd/4wd hi/4wd lo...none of this "auto" stuff like on later explorers.) I do know my 4wd module is not the boxy one with the test switch/light like on 1st gen ex's. Its the smaller one in the dash behind the GEM. I tried swapping it once, no change on my lack of 4low issue. And the engagement process is the same (neutral, stopped, foot on brake, 4wd high 1st, then try 4wd low.)
But while my High works perfect, no low. The 4WD LOW light does not come on and it just stays in 4wd High. (both come on when you start the truck so I know the bulb works...and I think that means the 4wd module works).
I know the dealer would charge an obscene amount to troubleshoot this. I am wondering about the MLPS switch. Sometimes my reverse lights don't come on. Maybe its also not completing the 'neutral sense circuit' needed for 4low.
Old 02-22-2014, 07:45 PM   #11
Parker60
Ford Ranger
Vehicle Specs
Quoted: 1 Post(s)
Try putting it in reverse to then 4 low thats what i have to do
Parker60 is offline   Reply With Quote
Old 02-22-2014, 08:59 PM   #12
FR-425
Used to be a road here.
Phoenix, AZ.
FR-425's Avatar
1994 Explorer Limited
Vehicle Specs
Quoted: 349 Post(s)
A good clunk into 4 low is normal.
__________________
Watch out for those who try to convince you that it is possible to pick up a turd by the clean end!!
FR-425 is online now   Reply With Quote
Old 02-26-2014, 08:19 AM   #13
DeRocha
NEX Vice President
Brockton, MA
DeRocha's Avatar
'93 XLT 4x4
Vehicle Specs
Quoted: 3 Post(s)
Quote:
Good info..
BTW.. The last post by SensRanger was 7+ years ago.. I hope he figured it out by now
__________________
Old 03-04-2014, 12:44 AM   #14
orange 94
Los Angeles
1994 Ford explorer xlt
Vehicle Specs
Quoted: 0 Post(s)
Good info..
Well...I guess good info is good info regardless of the post date lol.
I just did a search about truck is not going in to low range and this came up. I might have an issue with the switch since it goes in to 4x4 high but not low. I am the second owner of the truck and I know the owner and the truck since it was bought new. It probably went in 5 times max in it's entire life and probably never for the low range.
orange 94 is offline   Reply With Quote
Old 03-04-2014, 01:29 PM   #15
DeRocha
NEX Vice President
Brockton, MA
DeRocha's Avatar
'93 XLT 4x4
Vehicle Specs
Quoted: 3 Post(s)
Did you check out the 4x4 Trouble Shooting Guide?
To Activate 4x4 Low
1st be in 4x4 high
Now Press 4x4 Low
__________________
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
