Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2006 - 2010 Explorer Mountaineer 4th Generation > Stock 2006 -2010 Explorers
Notices
Stock 2006 -2010 Explorers Stock 2006 -2010 Ford Explorer Forum. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
TPMS reset
Reply
Thread Tools
Old 11-23-2007, 07:25 AM   #1
ahent
Johnston, IA
'07 XLT
Vehicle Specs
(Original Poster)
TPMS reset
I have a 2007 Explorer XLT. I need to know if the reset for the system works the same way as on the earlier models. They all say that they have metal stems in posts on this forum, but mine (and all 2007's I have seen) has rubber stems. Is the TPMS still in the stem and can I use the magnet to reset it. My TPMS gave a warning the other day and I checked pressure and it was normal in all the tires, drove 2 minutes and greater then 20 MPH and it was still indicating. PITA...Help me out guys (and gals). I hate to take it to the dealer if I can fix it in my driveway in 5 min. If this info helps, it happened in the middle of the first snow storm I have driven through with this Explorer, it was cold out, and thanks to the NHTSA I was freezing my a$$ off trying to clear a fault. Thanks in advance.
__________________
Do or do not, there is no try
--Yoda
ahent is offline   Reply With Quote
Old 11-23-2007, 09:38 AM   #2
gh67
Northern Utah
99 5.0-sold;06 Limited v8
Vehicle Specs
The TPMS is not in the stems...it is a small module that clips to a band that goes around the diameter of the wheel. Don't know of a way to "reset" them. You may have a faulty module or the battery in one of them died.
gh67 is offline   Reply With Quote
Old 11-23-2007, 10:30 AM   #3
ahent
Johnston, IA
'07 XLT
Vehicle Specs
(Original Poster)
So what you are saying is that the reset procedure for the tpms listed at http://www.explorerforum.com/forums/...ght=tpms+reset
does not work for the 2006 and newer explorers. Is there a way to reset the newer TPMS system if it is out of whack, at least something I can try before I have to go to the dealer?
Does the spare have a sensor in it? I didn't check the spare for pressure.
__________________
--Yoda
Old 11-23-2007, 01:26 PM   #4
ahent
Johnston, IA
'07 XLT
Vehicle Specs
(Original Poster)
found some stuff, it appears that 2006+ Ford Explorers use a newer generation TPMS sensor in the tires. It is attached to the wheel with a band and the only way to communicate with the sensor to do a reset or check for a faulty sensor is with a $300-$400 tool that sends and recieves signals from this sensor and can tell the sensor to reset. The sensor is located 180 degrees from the valve stem on the wheel. Sounds like I need a dealer unless one of the local parts stores carries the monitor. Here is the link to the sight with instructions for the reset http://library.motoralldata.com/tech...bHelp/Ford.htm
the 2006-2007 explorer data is at the bottom.
Hope that helps some people, it just pissed me off. Heaven forbid anybody be able to fix their own car...oh lords we can't have that.
__________________
--Yoda
Old 09-29-2009, 12:34 PM   #5
spikedog
Wyoming
'06 XLT
Vehicle Specs
late reply, but here's how to reset TPMS yourself
I figured this all out when I bought a set of snow tires for my '06 XLT. After the tire techs kept breaking the sensors, I got another set of rims and sensors. Now I can put my snow tires on myself, and I should break even dollar-wise in about 4 years.
Sensor Training (Reset Procedure)
NOTE: The tire pressure monitoring system is not affected by wheel and tire rotation.
NOTE: The tire pressure sensor training procedure must be done on a single vehicle, in an area without radio frequency (RF) noise.
RF noise is generated by electrical motor and appliance operation, cellular telephones and remote transmitters, power inverters and portable entertainment equipment.
1.Turn the ignition switch to the OFF position.
2.Turn the ignition switch from the OFF position to the RUN position three times, ending in the RUN position. Do not wait more than one minute between each key cycle.
3.Press and release the brake pedal.
4.Turn the ignition switch to the OFF position.
5.Turn the ignition switch from the OFF position to the RUN position three times, ending in the RUN position. Do not wait more than one minute between each key cycle.
6.The horn will sound once and the TPMS indicator will flash if train mode has been entered successfully. If equipped, the message center displays "TRAIN LF TIRE", hold the TPMS reset tool next to the tire and press the green button down. The horn will sound briefly to indicate that the tire pressure sensor has been recognized by the TPMS module.
7.Within two minutes after the horn sounds, do the same thing next to the RF tire pressure sensor. The horn will beep once to indicate successful sensor training.
NOTE: If the VSM (TPMS module integral to VSM) does not recognize any one of the four tire pressure sensors during the tire training procedure, the horn will sound twice and the message center (if equipped) will display "TIRE NOT TRAINED REPEAT" and the procedure must be repeated.
8.Repeat Step 7 for the RR and LR tires.
When the tire training procedure is complete, the horn will sound once and the message center (if equipped) will display "TIRE TRAINING MODE COMPLETE".
So basically you are fiddling with the ignition key to get it into TPMS training mode, then walking around your car starting at the driver's front tire, across the front to the passenger front tire, then passenger back, then driver's rear tire.
The tool to use is only about $20 from your FORD dealer. It's part number is
#8C2T-1A203-AB. It looks like a garage door opener with a little green button in the middle. There is no need to buy a costly rotunda tool or other universal sensor reset unit. Ford has to provide these reset tools in their new trucks since they wrote in the owner's manual that the trucks come with them.
spikedog is offline   Reply With Quote
Old 12-14-2010, 05:04 AM   #6
Excel
winnipeg
2007 Ranger
Vehicle Specs
Do you know if that same tool works on all Fords ?I have a 2007 Ranger .Ford don't list one for the Ranger .
Excel is offline   Reply With Quote
Old 12-14-2010, 08:59 AM   #7
spikedog
Wyoming
'06 XLT
Vehicle Specs
The Ranger and the Explorer should have the same blue TPMS sensors mounted on the rim with a band. The tool I posted about wasn't listed for the Explorer either. It only became available with the newer F-150's (starting in 2008, I think), and wasn't listed for 2006 or 2007 models.
Actually, I think only because Ford listed the tool in the 2008 F-150 owner's manual as "included", they were forced to make a $20 reset tool available to owners. Otherwise, we'd be at the mercy of the dealers and tire shops with their $300 handheld units.
Old 12-14-2010, 04:58 PM   #8
Excel
winnipeg
2007 Ranger
Vehicle Specs
Thank you for your reply .I still have a good connection at a Ford dealer ,I worked there for the last 30 years .I will try to find out if the F250 tester will work on the Ranger . We will take one out of a new truck and try it . I will post again after I find out .
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
