#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
how to replace heater control/bypass valve
Reply
Thread Tools
Old 11-29-2007, 03:40 PM   #1
wangmauler
Shrewsbury, MA
'98 explorer sport rust
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Exclamation how to replace heater control/bypass valve
Hey all. I've read up a bit on this site on how to replace the Heater control/bypass valve (on a 1998 ford explorer sport 4WD 6cyl), but still have some unanswered(and unasked) questions.
I went to CAP and grabbed one, was $21 bucks.
Now i'd like to replace it, but if i cut the hoses that are connected to the stock one(which is faulty), it seems like there will not be enough length left in the hoses to reach, is this true(buy new hoses) or should I be okay(cut and go)?
Also, before i start cutting, what preperation should I do so that not much coolant leaks out? is it going to spit out everwhere when I make a cut?
Thanks guys!
__________________
____________
-wang
1998 ford explorer sport - K&N Air Filter. walmart Baja driving lights. Warrior 153 Shackles(replaced the rusted-debris that "was" my previous shackles). Zip Tie Throttle mod. ABS kill switch. Engline Kill swtich. Fuel cutoff switch. 2" Torsion Twist.
wangmauler is offline   Reply With Quote
( Join the Elite Explorers )
Old 11-29-2007, 03:41 PM   #2
Blee1099
Evil Asian
Elkridge, MD
Blee1099's Avatar
91
Vehicle Specs
Quoted: 10 Post(s)
The hoses are simply just connected to them.. Just yank em off and then re-connect them to the new control valve.
Blee1099 is offline   Reply With Quote
Old 11-29-2007, 04:05 PM   #3
toypaseo
Flunked daycare
outside shovelling snow
toypaseo's Avatar
................ 96 XLT
Vehicle Specs
Quoted: 157 Post(s)
Burp system afterwards.
My local Ford did not burp the system after they replaced mine, so my temp gauge reads colder and/or flutuates alot.
__________________
Kent - 1996 XLT - Hypertech Programmer, Gibson Catback, K&N FIPK, Alpine V12 MRV-100M, AudioControl LC2i, 8" round 2ohm Kicker Solobaric
1992 Toyota Paseo - Tein Super Street coilovers, Whiteline swaybars 22MM(F) 20MM(R), Prothane endlinks & mounts, VVR poly control arm bushings, K&N drop-in, Dynomax Ultraflo, Gibson stainless tip, 15x7 Axis Maglite with 195/50r15 Yokohama S.drive
toypaseo is offline   Reply With Quote
Old 11-29-2007, 06:33 PM   #4
DeRocha
NEX Vice President
Brockton, MA
DeRocha's Avatar
'93 XLT 4x4
Vehicle Specs
Quoted: 2 Post(s)
Ben is 100% correct
Quote:
__________________
John D-"Search first, Ask questions later" & "You can have my Explorer when you pry the keys from my cold dead hands." <<<Forum Rules >>>*My Truck*
4x4 Trouble Shooting Guide
See how cars work Axle and tire calculators U-joint replacement info/pics
Repair info NEX-New England Explorers NEX: Club Events
DeRocha is offline   Reply With Quote
Old 11-29-2007, 07:05 PM   #5
alohamonte
Glendale, AZ
1998 Explorer 4.0 4x4
Vehicle Specs
Quoted: 29 Post(s)
valve
i replaced mine just 3 weeks ago.
i noticed when the heater control valve started to drip onto the exhaust manifold making smoke.
it's an easy fix. I did not drain the system, very little coolant spills out, just a few ounces. Open the radiator cap first to remove the pressure and you'll be fine.
dont cut the hoses or you'll wind up buying new ones. Unclamp them. Twist & pull at the hoses until the valve comes loose. and replace. it's very easy and took me 20 minutes and i'm beginner skill level.
tools needed: plyers and shop towel
__________________
1998 Xplorer 4.0 OHV 4x4, 3.73 L/S, 31x10.5 Good Year Silent Armor A/T, All Synthetic Fluids, Sony Audio System, Yakima Roof Rack w/ 3rd Crossbar, Bilstein Shocks, Silverstar Ultras, Clifford Alarm & Keyless Entry, Throttle Cable Mod, Moog Front End
alohamonte is offline   Reply With Quote
Old 01-14-2008, 08:22 PM   #6
atomixist
Baton Rouge, Louisiana
98 XLT
Vehicle Specs
Quoted: 0 Post(s)
Where is the HCV located on the SOHC? Where did you find out how to replace it also? I need to replace mine but I can't find it.
atomixist is offline   Reply With Quote
Old 03-09-2008, 07:45 PM   #7
j0rdantay10r
Vehicle Specs
Quoted: 0 Post(s)
Hey guys,
I was having problems with my HCV so I replaced it. Now that I've replaced it, I get no more leaks from that area (which was originally causing my car to overheat). I believe I connected everything properly but now the heat doesn't work anymore, it just blows cool air. If I leave the heat on, it opens the valve and that's when my car overheats. If I leave the heat off, the car doesn't overheat and I get no leaks.
Can anyone post a picture of how the hoses should be connected on a '96 model 2 WD Ford Explorer Sport? I will try to post a picture of how my hoses are connected if I can figure out how.
Thanks in advance.
j0rdantay10r is offline   Reply With Quote
Old 05-12-2009, 12:52 PM   #8
baddriver
stuart, fl
08 XLT, 97 Sport
Vehicle Specs
Quoted: 0 Post(s)
on the engine side of this valve.. which hose goes where... it cannot be seen from the pic?
top hose -> manifold and bottom hose -> water pump???
or vice versa???
baddriver is offline   Reply With Quote
Old 11-01-2010, 09:23 PM   #9
help
Vehicle Specs
Quoted: 0 Post(s)
I also need to know how the hoses are ran. The heater control valve blew up a couple weeks ago and I did a work around until I could get the part. now I do not remember how the hoses are connected. Thanks for your help on this issue.
help is offline   Reply With Quote
Old 06-24-2011, 04:45 PM   #10
Leslie72
Texas
2000 XLS
Vehicle Specs
Quoted: 0 Post(s)
How do I burp it?
Leslie72 is offline   Reply With Quote
Old 02-07-2012, 12:37 PM   #11
Prospeeder
Vehicle Specs
Quoted: 0 Post(s)
or vice versa???
yea sombody needs to respond to this, lol i havent a clue which goes where either.
Prospeeder is offline   Reply With Quote
Old 02-16-2012, 08:20 PM   #12
funkylikeagoat
OBX, NC
Ford Ranger
Vehicle Specs
Quoted: 0 Post(s)
j0rdantay10r : Sounds to me like you need to replace the heater core.
To 'burp' your cooling sys. you should uncap your radiator (while cool), allow your vehicle to warm up to op. temp. this should work out any air that may have been introduced during a coolant change or adding of fluids. You will know youre successful if the coolant in your radiator swirling and void of any bubbles.... if yo u dont see coolant swirling then youre a little low so add a bit and repeat!
funkylikeagoat is offline   Reply With Quote
Old 01-07-2014, 05:46 PM   #13
Cardfan99
Shreveport, LA
1999XLTExplorer
Vehicle Specs
Quoted: 0 Post(s)
Don't laugh my valve just started leaking and my 1999 XLT has 252,700 miles on it.
Cardfan99 is offline   Reply With Quote
Old 01-07-2014, 08:24 PM   #14
koda2000
Georgia
2001 Explorer EB 5.0L
Vehicle Specs
Quoted: 1085 Post(s)
i couldn't get my SOHC to burp to save my life after changing the lower rad hose. tried all the suggestions on how to do it. i finally decided to take it around the block. w/in a 1/4 mile the TEMP gauge pegged on high and the radiator puked into the reservoir and blew the cover open. i rolled it home, added about 1/2-3/4 jug more of antifreeze mix (once it cooled down) and then it was fine.
__________________
I reject your reality & substitute my own...
2001 Explorer Eddie Bauer 5.0L V8 2WD
2000 Mountaineer 5.0L 2WD/2000 Expl XLT 5.0L 2WD
2000 Mountaineer 5.0L V8 AWD, 2001 Expl Sport Trac
2001 Explorer XLT 4.0L SOHC V6 auto 2WD (RIP 5/13)
1997 Explorer Sport 4.0L SOHC V6 auto 2WD
koda2000 is online now   Reply With Quote
Old 04-03-2014, 10:57 PM   #15
Napu(StrongWave)
Marrero,La
2001 Sport Trac Gen 1
Vehicle Specs
Quoted: 0 Post(s)
How can you tell if the heater control valve is going bad? I can hear pressure building up around that area every time i start up my engine..
Napu(StrongWave) is offline   Reply With Quote
Old 04-03-2014, 11:03 PM   #16
Napu(StrongWave)
Marrero,La
Vehicle Specs
Quoted: 0 Post(s)
My temp gauge is working fine and the heater works well..
Old 04-04-2014, 11:17 AM   #17
koda2000
Georgia
Vehicle Specs
the heater control valve will leak if it starts to wear out. as far as its operation, vacuum opens it and lack of vacuum allows it to close. when open it allows hot water to flow through the heater core. if your temp gauge reads normal, the heater control valve isn't leaking and you're getting heat - all is good.
__________________
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
