#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
remove the center console
Reply
Thread Tools
Old 11-29-2007, 04:30 PM   #1
nomadtgif
Amherstburg, Ontario, Canada
nomadtgif's Avatar
97 Limited
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
CAN remove the center console
how do you remove the center console on a 97 Limited? My amp is bad and I have to change it.
nomadtgif is offline   Reply With Quote
( Join the Elite Explorers )
Old 11-29-2007, 04:49 PM   #2
billz260
Tulsa, OK
'94 Sport
Vehicle Specs
Quoted: 0 Post(s)
not sure, but i bet you need to take the top pieces off before you can get the whole thing out. Look for screws around the cup holder and in the bottom of the storage bins. Be a bit adventurous but take your time and you'll have it out in no time. Might check around the base for screws as well.
billz260 is offline   Reply With Quote
Old 11-29-2007, 04:51 PM   #3
mcpherson
Cumming, GA
'98 XLT, '88 YJ
Vehicle Specs
Quoted: 0 Post(s)
Welcome to the forums!
Use the search, it's your friend.
Here's a few links to get you started on removing the console:
http://www.explorerforum.com/forums/...d.php?t=200795
http://www.explorerforum.com/forums/...d.php?t=199089
http://www.explorerforum.com/forums/...d.php?t=195666
Goodluck.
__________________
Nick, KJ4QIZ
'98 Explorer XLT - mcpherson's Registry
'88 Jeep Wrangler - mcpherson's Build Thread
"If anything can go wrong, it will" - Murphy's Law
mcpherson is offline   Reply With Quote
Old 11-29-2007, 06:57 PM   #4
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 380 Post(s)
Welcome to this forum! I'm sure that you will find everything you will need to know on this forum.
BrooklynBay is offline   Reply With Quote
Old 11-30-2007, 09:03 AM   #5
JoeMahma
Pa.
1997 Mercury Mountaineer
Vehicle Specs
Quoted: 0 Post(s)
Quote:
Just did this to my 97 Mounty. It is SUPER easy. Remove the package tray and cup holders by grasping and pulling out by hand. There is a wiring block located directly under the stereo with a bolt holding it in place. Loosen the bolt until you can unplug the harness. There are two gold colored bolts on either side of where the wiring block was, remove these. Now if you move back until you are at the front edge of the armrest and look straight down you will see two more bolts that are exactly the size and color of the first two, remove them (you may need to grab them with needle nose pliers after they are loose to get them completely out of there) . This is the tricky part. You have to get in the back seat and pull the console straight back and slightly upward to release the two metal "fingers" that are holding the rear of the console to the floor. These fingers slide into a plate that is bolted to the floor that has two slots in it. DO NOT be shy when you are pulling the console to release these. Trust me, it takes some effort. When you get that released, just pull the whole console out through the rear seat, wiring and all. When you replace the console just reverse this procedure but make sure you don't get hung up where those four bolts go in as you are sliding the console forward and back into place. Hope this helps. Good luck!
JoeMahma is offline   Reply With Quote
Old 11-30-2007, 09:05 AM   #6
JoeMahma
Pa.
Vehicle Specs
Quoted: 0 Post(s)
But just to clarify. Your amp should be in the rear of the truck. Maybe a cd changer in the console? If you need to get just the changer out that is totally different but just as easy.
Old 11-30-2007, 08:17 PM   #7
nomadtgif
nomadtgif's Avatar
97 Limited
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
CAN remove the center console on a 97 Limited? My amp is bad
Thank-you all for the excellent information, it will realy make this job easy. Only one more thing, I am not sure where the Amp is located in my truck, I asumed it was under the counsole like my Escort. If anyone knows of another spot that they like to put these amps i would like to know. Anyway thanks again
Old 12-01-2007, 08:32 AM   #8
JoeMahma
Pa.
Vehicle Specs
Quoted: 0 Post(s)
The amp in my truck is located in the rear right of the truck if you are standing with the hatch open looking into the truck. You must remove the interior panel to access it.
Old 01-12-2008, 10:52 PM   #9
nomadtgif
nomadtgif's Avatar
97 Limited
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Question Wiring diagram for my audio system
My question is about a dead amp in my 97 Explorer Limited. I have found the amp and sub Amp under my interior trim, in the back. What I am looking for is a wiring diagram that shows me how the whole system is wired in; I want to check if there are any fuses or fusible links in the system. I also need to know how to check both components to see which one is not working. Since I have no bass tone coming from any of the 4 working speakers and not a lot of volume I think it is my main amp, but I am not sure? Any help you could give me would be useful. Thanks
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
