Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
1998 SOHC rough idle
Reply
Thread Tools
Old 10-09-2000, 10:05 PM   #21
Robert
Mesa, AZ
'97 4x4 Sport
Vehicle Specs
Quote:
Originally posted by withers
Anyone know the tsb number? I want to look it up and take it with me to the dealership.
thanks
MIL Lamp On/Codes Stored P0171, P0174, P1131, P1151
Article No.
99-10-4
06/01/99
__________________
4.56 Powertrax No-Slip, SOHC V6, SuperChip, K&N FIPK (#57-2513-1), Borla cat-back (#14748), 2" torsion lift, 3" PA body lift (#853), Monroe Reflex shocks, 285 75R16 BF Goodrich T/A ko, 2WD mod
Earnhardt Ford, Berge Ford, U-Haul
My Explorer
Robert is offline   Reply With Quote
Old 10-12-2000, 03:48 AM   #22
JM Dookie
Tucson, AZ
'96 XLT
Vehicle Specs
Got it fixed!
I took my vehicle in the fourth time for the same problem (rough idle) and they finally fixed it. The intake manifold gaskets had shrunk and caused a vacuum leak. This caused my MAS (which they replaced two times unnecessarily) to give a false reading. I told them that it was a vacuum leak the first time but they didn't listen. Thanks for the input guys, because of you I knew what to tell them to look for. Hopefully you can find a good mechanic who will take the time to diagnose the problem and then you don't have to rely on the Ford dealer.
__________________
96 XLT- 1" TT, Add-a-leaf, 15x7 MB Alum wheels, 31x10.50 Pirelli AT's, K&N drop-in
JM Dookie is offline   Reply With Quote
Old 10-12-2000, 09:23 AM   #23
Ricardo Miramontes
Vehicle Specs
(Original Poster)
Cost of repair?
Hey, Dookie,what was the total cost of the repair, not including the two MAS?
Ricardo Miramontes is offline   Reply With Quote
Old 11-08-2000, 02:51 PM   #24
Jeff
Vehicle Specs
This thread died a month ago but I have new info on my trusty steed that also has the surging problem.
Today, I went to the local dealer and explained what was happening. I did not tell them about the TSB right away. The service department had a mechanic come listen to my story and within 30 seconds he said that early SOHCs had a shrinking gasket problem that has been corrected with a slighty thicker material. He said that it could be a throttle body problem or the MAS but once I explained that I'd cleaned the MAS, he said that he was 99% convinced it was the gaskets because he'd worked on three others with similar problems.
In a way it is a refreshing experience to have a mechanic immediately diagnose a problem because I know there are some posts talking about how the dealers didn't figure it out right away.
Anyway, he's keeping the Exploder overnight so he can run some tests first thing in the morning to confirm the diagnosis when the gasket would have shrunk the most.
They gave me a wimpy Focus to drive but I'm seeing some off-road potential here. It was great over the parking lot speed bump.
[Edited by Jeff on 11-08-2000 at 01:53 PM]
Jeff is offline   Reply With Quote
Old 11-08-2000, 03:36 PM   #25
Robert
Mesa, AZ
'97 4x4 Sport
Vehicle Specs
You should have requested the Expedition of off-road rentals, the Contour! It will take 12" curbs with barely a wimper (going down only though!) It at least sounds like your dealer knows what he is doing though. Yes, testing it when the engine is cold will confirm if it is the manifold o-rings.
__________________
My Explorer
Old 11-08-2000, 04:03 PM   #26
Jeff
Vehicle Specs
I asked for the Excursion of all rentals - the Fiesta but it was in Moab. Sorta like a perverted version of midget wrestling.
I'm seeing a joke here involving Moab and The Rock but I'm too tired from watching the election results to figure out what it is.
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Owners of Early 4.0l SOHC - Poor Performance/Economy and Rough Idle Mark Drysdale Under the Hood 21 11-18-2002 01:02 PM
98 SOHC...Low Rough Idle, Stalls, Bucks.... crawfr1312 Under the Hood 4 09-13-2002 11:18 AM
98 SOHC wont idle at first start of the day.HELP! Magicfan25 Under the Hood 4 12-22-2001 08:22 PM
fuel pressure rough idle Iggy flywheel Under the Hood 2 06-18-2001 09:42 PM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
