Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Error Code P0125
Reply
Thread Tools
Old 12-04-2007, 07:58 AM   #1
osiris_9510
Fayetteville, NC
2001 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Unhappy Error Code P0125
Ok I need some help here. I don't know a lot about cars...
The check engine light has been on for a little while now. I took it to Autozone, had them check for error codes, and replaced the offending sensor, which was the engine temperature sensor. I drove it for 80 miles, and the light came back on.
I took it for inspection and it failed with the error code P0125.
"P0125 - Insufficient Coolant Temperature for Closed Loop Fuel Control"
I thought maybe I bought a defective sensor, because this is the same error code from Autozne. I replaced the sensor with another new one, drive it 60 miles, and the light came back on again with the same error code.
The temperature gauge in the dash doesn't work and hasn't worked since the light came on.
Any ideas? Dirty wiring on the temperature sensor?
One more thing, in the process of all of this I also replaced the temperature switch which is right next to the temperature sensor.
Thanks in advance
osiris_9510 is offline   Reply With Quote
( Join the Elite Explorers )
Old 12-04-2007, 10:11 AM   #2
manaen
Clear Spring, MD
2011 Xterra Pro-4X
Vehicle Specs
Quoted: 3 Post(s)
Have you checked the wiring going back to the PCM for breaks?
If you have an SOHC it should be pin 38 and 91 on the PCM connector
38 is a LT GRN - Signal
91 is a GRY/RED - common
If you already replaced the sensor it may be as simple as a pinched/cracked wire
__________________
Rusty...
2001 Mounty 4x4 4.0 SOHC 4.10's 180K miles
Current Mods: replacement Engine, TT, Shackle, AAL, Tranny Cooler, Exhaust, Transgo, Air shocks, ATF Temp & PSI ga., Ext Tranny Filter, UD Pulley, E-Fan, BW EPC, Custom Bumper, Body Lift
manaen is offline   Reply With Quote
Old 12-04-2007, 10:22 AM   #3
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 417 Post(s)
Welcome to this forum! You could test the gauge to see if it's working if you ground the wire. This should make the gauge go all of the way up to the hot area. How old is your thermostat? If it's stuck open, then the gauge will be low, and the engine will be cool all of the time. This sounds like what is happening. This chart is # 25 in my list of useful threads:
BrooklynBay is online now   Reply With Quote
Old 01-23-2013, 07:46 PM   #4
cary g
NC
2002 Explorer Sport Trac
Vehicle Specs
Quoted: 0 Post(s)
I just bought a very used 02 sport trac and have the exact same symptoms, but have not attempted any repairs yet. Did you ever solve this issue?
cary g is offline   Reply With Quote
Old 01-27-2013, 09:10 PM   #5
cary g
NC
Vehicle Specs
Quoted: 0 Post(s)
T-stat replaced. Light off for now.
Old 05-31-2014, 08:59 AM   #6
jfrracing1
SC
2002 & 01 EXPLORER SPORT
Vehicle Specs
Quoted: 0 Post(s)
fault code
i get that same code but it doesn't make the light come on. my obd2 shows it is p0125 code. it does make it hard to start when the air temp is warm but doesn't affect it when air temp is cold. to original poster, did u have to take the air intake off to replace the temp switch ? i have no room to even get the connector off with it on. i can get the ECT connector off & sensor out though. im trying to figure out which one is the problem.
jfrracing1 is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
