Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
No Heat / Low Temperature
Reply
Thread Tools
Old 12-05-2007, 09:56 PM   #1
BWCAW
Portland, Oregon
'93 Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I have no heat, temperature doesn't get above the first mark on gage. I have replaced thermostat twice with no result. Weather has no effect - warm or cold same result. Coolant is fine - proper temp and level. I was thinking water pump - any ideas!
BWCAW is offline   Reply With Quote
( Join the Elite Explorers )
Old 12-05-2007, 10:19 PM   #2
Willard
Bloomington, Indiana
04 Ranger Edge
Vehicle Specs
Quoted: 1 Post(s)
If it was the pump, it would be leaking, and would be overheating eventually (even in cold weather). It is entirely possible you have two bad t-stats, happens a lot. Your best bet is to try another, maybe a better brand. What temp t-stat are you getting?
__________________
Jesse
'94 Eddie Bauer DD/Beater
"Old Faithful" RIP
'04 Ranger Edge DD "Black Knight"
You want to see my face?
Willard is offline   Reply With Quote
Old 12-05-2007, 10:55 PM   #3
BWCAW
Portland, Oregon
'93 Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
If I remember correctly, 185 and 195
Old 12-05-2007, 11:54 PM   #4
suprcharg97
westland mi
93, 97
Vehicle Specs
Quoted: 0 Post(s)
I would feel the temperature of the hoses. (return and feed) This will determine if there is coolant flow. If both hoses are cool to the touch with the vehicle warm then you have a restriction concern. This could be the radiator, water pump, thermostat, collasped hose, blockage in the block itself. Then I would also check the hoses at the ply heater core for temperature differential and apply the same principle as before. make sure there is no FEAD front end acc. drive. belt slipping etc. or other things like a bearing siezed cauing a drag on the system and slowing coolant flow.
Is there a concern with the thermostatic fan itself as well? I converted mine to a electric fan with a thermostat. Coolant mixture is another consideration to take into place.
suprcharg97 is offline   Reply With Quote
Old 12-06-2007, 04:33 AM   #5
walterd140
Ludlow, Massachusetts
'94 Sport
Vehicle Specs
Quoted: 0 Post(s)
Might be time for a heater core if you have no heat inside, but like Devilboy said, check the t-stat again (easier of the 2).
I recall a way to test a t-stat in the house. Something like putting it in a pan of boiling water, then watch if the spring opens the vavle. Can anyone verify this?
Walter
__________________
Intelligence is the ability to listen to almost anything without losing your temper
walterd140 is offline   Reply With Quote
Old 12-06-2007, 05:20 AM   #6
Potomac30
IRMo, SC
1993 XLT 4WD
Vehicle Specs
Quoted: 2 Post(s)
My truck has done the same thing twice. I replaced the first (factory) thermostat with a another Ford tstat at 50,000 miles because the engine would not heat up. Same problem again at 90,000 miles... This time, I put in a Stant (from NAPA). So far, no problems. I hope this one lasts more than 40,000 miles.
Potomac30 is offline   Reply With Quote
Old 12-06-2007, 01:15 PM   #7
marragtop
balt, md
91, 92, 95, and 2000 xlts
Vehicle Specs
Quoted: 4 Post(s)
Put another 192-195 Tstat in. Also, make sure your gauge is working correctly by grounding the sending unit. It should peg the gauge.
__________________
'88 F150 4x4
'91 Explorer XLT 4x4
'92 Explorer XLT 4x4
'95 Explorer XLT 4x4
If it don't = 16 (4x4), it ain't worth driving...
marragtop is offline   Reply With Quote
Old 12-06-2007, 03:29 PM   #8
jtison
W Connecticut
'94 XLT/155 Kmiles 4x4
Vehicle Specs
Quoted: 0 Post(s)
Quote:
Walter
Yep. Verified. Use a meat thermometer to measure the temperature of the water as you heat it up. The opening temperature is usually stamped on the back side of the 'stat. If it's a 195 (that's what I have), it should open right at 195.
It's really bizarre -- but not unheard of -- that you'd get two bad t-stats in a row. Thermostats are cheap anyway, don't skimp here. Buy Stant. Did you remember to use a new rubber sealing ring around the outside of the stat when you reinstalled it?
Anyway, if it's a lack of heat inside the cabin you're complaining about, that's a heater issue. With the engine off, turn up the heater temperature, then see if you can run water into the inlet hose and see what comes out of the outlet hose. Nothing? Then you've got a plugged heater core (at least that's what the old wives say). I've never done a heater core on an EX, but I understand it's a pain.
Good luck.
__________________
"You've become, what we call in the revenge business, 'next'." -- Bea Arthur, Maude
jtison is offline   Reply With Quote
Old 12-06-2007, 06:58 PM   #9
walterd140
'94 Sport
Vehicle Specs
Quoted: 0 Post(s)
Not really JT. Seems you just slide the glove box out then 4 screws later you got core in hand. There is another thread here about bad heat that shows the core in the book.
Here's the link
http://www.explorerforum.com/forums/...d.php?t=184090
On a side note, and with the cold air, how come nobody asks about ac questions? Kidding... frozen Massachusetts here
Walter
__________________
Old 12-06-2007, 08:13 PM   #10
smtcapecod
Cape Cod
1994 Sport
Vehicle Specs
Quoted: 0 Post(s)
Was on another thread on this last night. Wondering, how to tell if it's the temp sending unit vs the t-stat?
__________________
1994 Explorer Sport, bought 9/07 with 69K miles. 5/2010 DONATED due to no sale w/82K miles...
2004 Pontiac GTO
1983 Porsche 928 Euro S 5 spd...310+ HP Ubberauto..
smtcapecod is offline   Reply With Quote
Old 12-06-2007, 09:27 PM   #11
Willard
04 Ranger Edge
Vehicle Specs
Quoted: 1 Post(s)
well, the difference is fairly large, so that's easy. The t-stat is inside the outlet in the top of the motor, and is a little mechanical, heat-activated valve that regulates the flow of coolant through the radiator. It has no input or electrical connections to the computer. The temp sending unit sticks out of a spot on the intake manifold (in a coolant path) and simply tells changes resistance with temperature and that info is taken by the computer or gauge, depending on which sending unit it is.
http://auto.howstuffworks.com/cooling-system.htm
Look at that article, it explains the cooling system, and will show you what the thermostat does. It doesn't say anything about a temp sending unit, but, as previously stated, it is basically just a thermometer that sends it's information to the computer and gauge.
Hope it clears things up for ya
__________________
Jesse
"Old Faithful" RIP
Old 12-06-2007, 09:59 PM   #12
jtison
W Connecticut
Vehicle Specs
Quoted: 0 Post(s)
On a side note, and with the cold air, how come nobody asks about ac questions? Kidding... frozen Massachusetts here Walter
Good to know about the heater core, Walter. Thanks for the link -- it does look easy.
Eh. Who needs A/C? This is New England! Where 14 F is balmy!
__________________
Old 12-07-2007, 09:47 AM   #13
smtcapecod
Cape Cod
1994 Sport
Vehicle Specs
Quoted: 0 Post(s)
Er, I know what they do and how they function. Was inquiring about diagnosing which is the problem causing the low reading. However, that was pretty stupid of me to ask, as it is referenced above (thermometer) and I should just use an IR temp sensor when the vehicle has been run for a while to see whether it is operating at spec temp, or below. Thanks though!
Quote:
Originally Posted by devilboy222 View Post
well, the difference is fairly large, so that's easy. The t-stat is inside the outlet in the top of the motor, an...
__________________
2004 Pontiac GTO
Old 12-08-2007, 04:24 AM   #14
walterd140
'94 Sport
Vehicle Specs
Quoted: 0 Post(s)
IR sensor just shows the exterior heat. Not the internal water temp. There will be a difference between the 2.
Walter
__________________
Old 12-09-2007, 06:52 PM   #15
Altaman
Vehicle Specs
Quoted: 0 Post(s)
Just dropping a line to thank all on this thread
I was having the same low temp/blowing cold air problem.
Changed thermostat: No change (see note below tips to make changing t-stat easier)
Decieded to change heater core: Problem solved I couldn't believe how easy it was. See post in following thread for really easy directions;
$22 Autozone heater core and it started started blowing smoking hot air, temp guage is steady at 1/4 into normal zone.
In addition, the hoses at the old core were so stuck-on(probablly been on since new) I had to cut them to get them off. Luckly there was enough slack hose to reach the new core. If you have to cut your hoses to get them off, check to see if there is enough hose to reach new core. If there isn't enough hose, get about 1 foot of extra hose and some splice fittings to reach the new core. The locaton of the other ends of those hoses is very, very tight and getting them off would be a b***ch. Splicing-on will be way easier!
Note on changing t-stat: As discussed elsewhere there are a couple(1 in particular) bolts on the housing that are very hard to get at.
After getting the belt out of the way, the tensioner moves a little out of the way. Next, remove the top bolt that holds the tensioner assembly in place; take a hammer and punch/large screwdrive and gentlly tap the assemblly up and a little more out of the way, it will rotate at the other bolt that's behind the tensioner pully. This will give about 3/8" that will make all the difference in being able to get at that bolt(you'll know the one). Now, with a screwdriver and using head of the bolt to lever on, gentlly press the small wiring harness against the t-stat housing, This will get the harness out of the just enough so it will not be in the way. With this, the bolt came out pretty easy
When putting the bolts back in, I used a small bit of duct tape to hole the bolt in the socket; most of the tape was on the socket so once the bolt was started back in, the bolt would disengage from the socket.
A few other good tips I got from the forum article:
-Tape the sockets, extensions, wobble drives on so the don't fall off.
-Have a magnetic retriver handy when you extract the bolts
For complete description see:
http://www.explorerforum.com/Singlet...hermostat.html
Thanks again for all who helped
Altaman is offline   Reply With Quote
Old 12-09-2007, 08:38 PM   #16
smtcapecod
Cape Cod
1994 Sport
Vehicle Specs
Quoted: 0 Post(s)
Nice
Good of you to come back around and provide news of the solution and the links!
I have some heat in mine, just takes forever to budge the needle. It'll creep into the normal range if left idling, but goes back down as soon as I start to drive again. So I'm still thinking someone yanked out the thermostat. I have a 180' on order, given that I may be stuck in D.C. traffic jams this summer-- I doubt the ten degrees will cause fuel loading or wear for thermal expansion (or lack thereof) in this thing. Doesn't sound too fun- I hate working around obstructions!
Congrats on tackling and resolving your issue.
__________________
2004 Pontiac GTO
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
