NEWFS02X
- June 25, 2006
- Manitoba,Canada
- 2002 E/B 4x4
Hello guys/gals.
When shifting my 02 EB into drive the rpm drops down to a near stall and then jumps up higher than normal idle speed and you have to hold the brake hard.
Sometimes it stalls completely. Does the same thing in reverse. Sometimes I have to footfeed it to get it past that point and then it is fine.
It runs fine. Starts great. Just when it is placed in gear. Seems like its anticipating the load of the torque convertor and tries to over compensate if that makes any sense.
No CEL. Engine is a 4.0 SOHC. No other drivability issues other than gas mileage has dropped 3-4 mpg on average.
Last year I replaced the DPFE valve. I disassembled that again. Tubes are clear and no condensation.
I removed the EGR and checked it and it functions fine. No abnormal carbon buildup and it seals fine. I cleaned it.
I removed the IAC and cleaned it as well.
The throttle body/plate was extremely dirty and i removed it and cleaned it and the inside of the plenum as far as I could get.
Any ideas before I close the hood and test drive to see if one/more of the above has corrected it?
I plan on running seafoam through it as well.
Thanks..........John
